Old 06-08-2015, 11:09 PM
ricks63 ricks63 is offline
Pretty sue i have both will have a look. Thanks
  #42
Old 06-09-2015, 01:52 PM
Default 63 door panel pics
Here is a few pics of the door panels i listed, passenger is really nice, drivers has a few small tears around window crank hole but easy repair and a little issue with one bottom corner where it may have gotten wet. Back panels are nice, these are still worth restoring for someone who wants original panels rather than the aftermarkets. I have a lot more pics i can text if you need.
Name:	63 tempest door panels 001.jpg
ID:	400017   Click image for larger version
Name:	63 tempest door panels 002.jpg
ID:	400018   Click image for larger version
Name:	63 tempest door panels 006.jpg
  #43
Old 06-14-2015, 08:28 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Default Wiper arm Shafts and pivots for sale
I have a real nice NOS matched pair of wiper arm shafts for sale. These fit all 1961 Tempests and 1962 Tempest & Lemans. I am pretty sure that these will work on any bodystyle. 4 door, 4-door Wagon, 2 door coupe or convertible.
I would like $100 for the pair.
Name:	1961-62 Tempest Lemans Wiper Arm Shafts R&L Sides_NOS.jpg
ID:	400470   Click image for larger version
Name:	1961-62 Tempest Lemans Wiper Arm Shafts R&L Sides_NOS-1.jpg
ID:	400471   Click image for larger version
Name:	1961-62 Tempest Lemans Wiper Arm Shafts R&L Sides_NOS-2.jpg
Peter Serio
Owner, Precision Pontiac
  #44
Old 06-14-2015, 08:49 PM
Default 1963 Tempest or Lemans Rear bumper guard brackets
Here is a matched pair of lower support brackets for the optional rear bumper guards. All I have is these brackets. They came off of a '63 Lemans. I am not sure if they would work on a '62. I do not have the chrome guards.
These parts are used. They are left and right side specific. You sometimes see the chrome guards for sale but often missing these brackets.
I have glass-beaded, primed and painted them. I took a photo of the parts before I removed them from underneath the car if you need to see the position along side of the frame rails. I would like $50 plus postage for the pair.
Name:	1963Lemans Rear Bumper Guard Mounting Brackets_PYs.jpg
ID:	400473   Click image for larger version
Name:	1963Lemans Rear Bumper Guard Mounting Brackets_PYs-1.jpg
ID:	400474   Click image for larger version
Name:	1963Lemans Rear Bumper Guard Mounting Brackets_PYs-2.jpg
ID:	400475   Click image for larger version
Name:	1963Lemans Rear Bumper Guard Mounting Brackets_PYs-3.jpg
Peter Serio
  #45
Old 07-06-2015, 08:16 PM
KJB's Avatar
KJB KJB is offline
I have a couple items available that are cost prohibitive to ship. However, I do have a friend who is going to Norwalk and will take these items for delivery. He will only take them if they are presold and prepaid. So the prices are prepaid to Norwalk.
1963 V8 torque tube and torque shaft. This is correct for the 1963 with a V8 automatic only. The torque shaft has good bearings and the torque tube still has the factory insulation on the top. $150
Four original wheels that fit the 1963 Tempest and LeMans. The only difference between these and the 1961 and 1962 is the way the poverty hub caps fit. The 1961 and 1962 use clips for the poverty hubcaps while the 1963 has nubs on the wheel itself. I don’t think there is a difference if you are running full wheel covers. These wheels have a set of new Firestone 6x70x15 tires mounted. I wanted them in case I ever wanted to show my 1963 LeMans totally stock but I never did mount them. These wheels are available with or without the Firestone tires. Your choice but the price is the same with or without. $160 for the set.
  #46
Old 07-06-2015, 10:44 PM
GaryK's Avatar
GaryK GaryK is offline
Hi Keith,
61's are the rims with the clips, 62-3 are the same. Your wheels will fit all 3 years.
Gary
  #47
Old 07-07-2015, 06:25 AM
KJB's Avatar
KJB KJB is offline
Originally Posted by GaryK View Post
Hi Keith,
Gary
Thanks for that update Gary.
  #48
Old 07-19-2015, 06:33 PM
ronk455's Avatar
ronk455 ronk455 is offline
Default 62 Tempest Lemans parts
Some parts left over after selling my 62.
Dis-assembled 62 motor (thick) block, code 76Y. 150.00
Used windshield. 50.00
Rubber windshield gasket made by Soffseal, used. 50.00
Set of 4 full wheel covers 20.00
Generator. 40.00
Stock single outlet master cylinder, new. 20.00
Dual outlet master cylinder for Scarebird conversion. 20.00
5 headlight trim rings. 15.00
Stock radio, works. 5.00
Trim for tops of rear quarters. 40.00
All prices plus shipping.
Norwalk delivery possible.
  #49
Old 07-19-2015, 09:43 PM
wojo1963 wojo1963 is offline
Default Items for sale
Sent you a pm
  #50
Old 07-22-2015, 08:43 PM
ronk455's Avatar
Default Pictures
Here are a few pictures of some of the items for those that have asked.
I also found another wheel cover. It is a set of 5 now.
ID:	403505   Click image for larger version
ID:	403506   Click image for larger version
ID:	403507   Click image for larger version
ID:	403508   Click image for larger version
  #51
Old 07-22-2015, 08:45 PM
ronk455's Avatar
Default Valve Body
I also have a valve body and governor for the 2 speed automatic. $80.00 for both
  #52
Old 07-23-2015, 05:33 PM
Default Parts for sale
I will definitely take the wheell covers. I will also take the single master cylinder and bezels if they are compatiable with the 1963 lemans. I believee the cylinder is, but not sure about the bezels. Thanks.
Jerry
  #53
Old 07-24-2015, 01:23 PM
ronk455's Avatar
PM sent to wojo1963
  #54
Old 08-04-2015, 03:35 PM
JohnFromVentura's Avatar
JohnFromVentura JohnFromVentura is offline
Default NOS PONTIAC 1963 LEMANS RIGHT TAIL LAMP LENSE 5954262
NOS rt. side tail light lens:
http://www.ebay.com/itm/321818979112...84.m1555.l2649
  #55
Old 08-07-2015, 11:27 PM
Sanduners's Avatar
Sanduners Sanduners is offline
Default 3 speed and a 4 speed differential available
I have a 3 speed and a 4 speed differential available. Both have 330 ratio. These both came in a car purchased, the car was a stick, now an automatic. Both ring & pinons look great, bearings run smooth and no sign of damage. The part numbers are the same yet one shows GM1 and the other GM2. The 3 speed (white one) has the letter "P" stamped in one location, the other a "1". The 4 speed (blue one), "Y" and "4". (Last photo is the 3 speed)
Asking $250 each (obo) plus shipping. Thanks.
See more photos here:
http://forums.maxperformanceinc.com/...d.php?t=764553
  #56
Old 09-06-2015, 08:59 PM
Poncho-V's Avatar
Poncho-V Poncho-V is offline
Default '62 LeMans Parts
Ok, guys, I haven't had a lot of time to deal with this stuff. Still need to sell. Lots of good stuff, including hood with all PONTIAC letters, and trunk lid not pictured.
http://forums.maxperformanceinc.com/...4&d=1426199557
http://forums.maxperformanceinc.com/...5&d=1426199614
http://forums.maxperformanceinc.com/...2&d=1426199489
http://forums.maxperformanceinc.com/...3&d=1426199526
http://forums.maxperformanceinc.com/...6&d=1426199857
  #57
Old 09-26-2015, 08:12 PM
Sanduners's Avatar
Default Original Pontiac Air Cleaner Snorkel
For sale, hope someone can use this snorkel. For the 4 cyl motors.
http://rover.ebay.com/rover/0/e12000...AMOTORS%3A1123
  #58
Old 09-26-2015, 08:49 PM
tom s tom s is offline
will post here.I need the transaxle seal for the shifter rod and the bellows boot that goes around the rod and attaches to the diff.Tom
  #59
Old 10-15-2015, 03:27 PM
Default 63 Lemans Right Tail Light Assy
Very nice 63 Lemans Right Side tail light assy, includes good lens.
http://www.ebay.com/itm/321893679668...84.m1555.l2649
  #60
Old 10-16-2015, 04:35 PM
This should work?
