#41
Thanks for pointing that out guys I never looked closely
I'll have it checked
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
#42
No one has mentioned anything about the pan and the spots .....fuel or Antifreeze the culprit guesses?????
#43
interesting....does the white stuff have any substance to it?.....if it was fuel I would think it would blend relatively seamlessly with the oil and not look like that....water however, does not blend with oil very well
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
#44
ahhhh......spots......looks like it may be water...keeping oil from it
#45
HAHAHA...yes the white spots or what appear to look like snowflakes which is actually the " metal " baffle plate of the oil pan,,,
Think we might be onto something...perhaps with that head gasket which was also on the same side/same cylinder as what I thought I had the Rod goin on...but the combustion Chamber isn't White like it was getting steam cleaned from coolant and I never had any issues with coolant or temps.......??? The heads were pressure tested so I don't think we have a crack in a head and redone as well so I assume they are flat too but ya know what happens when u Assume The block is a SR block that I had decked to Zero with the rotating assembly... but I will have it all checked ....
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's Last edited by cnc; 01-19-2014 at 12:33 AM. |
#46
Can a Block be pressure tested .....????
#47
Do you have plastic wrap over the oil pan? If that's antifreeze I would think you would have noticed a lot of steam blowing out the exhaust.
#48
Is that chunks of something I see in the one picture on the oil pump screen?
#49
yep.....
#50
[QUOTE=pontiac1981;5111580]Do you have plastic wrap over the oil pan?
No ..............why do u ask.....lol
#51
Is there a lot of forward and backward movement in the crank? Kind of looks like thrust bearing material.
#52
It sure does look like plastic wrap over the pan. I realize it's just the flash reflecting off of the oil, but it looks like plastic wrap. LOL!
#53
Paul there is movement but how much not sure....I don't have anything here to measure that....That was my first thought ....but would thrust bearing failure resonsate to one side of an engine...
What do u think of the oil pan pic...that shiny snowflake pattern is the metal of the actual pan the oil is being separated.....but by what..?????
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's Last edited by cnc; 01-19-2014 at 12:55 PM. |
#54
I know.....
#55
That sucks.
As much as it will probably kill you, I'm going to suggest that you stop pulling that engine apart. If you had a shop build it for you and they want to look it over, this is giving him a perfect excuse to void any kind of replacement work at his cost. I'm not saying that hes going to act like that but people get weird when it comes to money. Just my suggestion.
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies - Build Thread http://forums.maxperformanceinc.com/...615847&page=23 |
#56
A shop redid the balancing job for me when I had THAT problem ...and they assembled the bottom end crank and rotating assembly all new bearings rear main..... I installed everthing else....oil pump pan heads intake ..etc etc.... I only pulled the pan HOPING maybe my windage tray was hitting ...but obviously it wasn't........
#57
IMO, the Felpro head gaskets are not the culprit here. They don't look bad to me. Usually, a blown head gasket will result in steam cleaning the cylinders involved and will milkshake the engine oil. No sign of that here. Looking at the amount of metal in this engine, something else failed. Probably the lubrication system. Teardown and inspection is needed before any real conclusion is drawn. I've been using Felpro gaskets on these engines for over 35 years. Hell, the set I installed on my '65 GTO's 389 in 1981 is still working fine. I banged gears in that car yesterday.
Jeff |
#58
[QUOTE=geeteeohguy;5111818]IMO, the Felpro head gaskets are not the culprit here. They don't look bad to me. Usually, a blown head gasket will result in steam cleaning the cylinders involved and will milkshake the engine oil. No sign of that here. Looking at the amount of metal in this engine, something else failed. Probably the lubrication system.
I agree on the steam cleaning as I mentioned previously..... BUT what is in the pan ( aside from the glitter ) causing the oil to separate like this I'm gonna see about testing the oil in the filter to see what is in it for contamination..... As for the lubricating system its a new pump.... hell everything is new as far as rotating assembly and lubricating from oil pump to Water pump....
#59
As far as noise, if the thrust bearing went and took out the actual main bearing part of it, then I suppose it might be more concentrated on one side or the other. Hard to say. Depending on the type of rod bearing used, it could be that also. Just have to see what the shop says. Hopefully they take care of it for you. Hopefully it wasn't something like the converter didn't get installed all the way into the tranny when assembled, thus taking out the thrust bearing.
#60
I'd like to F***in bang my head .......lol
