#41
Brian Baker:
Ever think of turbo charging that funny car??
DOC'S TA Turbo 535, CV 1 heads. Built by Cerralli Competition Engines Tenth Anniversary (Van Nuys) restored. Tenth Anniversary Barn Find (Norwood) Both 4 speeds! |
#42
455 pump gas 0.030 0.010 factory crank 10.99-11.3s shifts at 6100 525 hp on dyno 550 based on best mph.
500 IA2 Ohio billet 4.21 stroke 4.350 bore 695 HP 20 dyno pulls not in car yet. Ohio billet 4" and forged 4.21/3.25 for next Pontiac projects. 470ci/409 W motor 4.325 bore/4" stroke Eagle forged had to be turned , final assembly this week shooting for 500-550 HP
#43
Factory block 4.230 bore
Old Eagle cast 4.210 stroke, 3.25 mains Has outlasted 1 block, and made as much as 950 RWHP, currently Making 580ish RWHP. Needless to say,this was the last year for this crank. ![]() |
#44
Previous 400 used a factory 350 non N crank,about 550HP at 7000rpm for over 300 passes in a 'weak' 557 block,it's still running in another car.
New 421 turbo combo has an AP Scat 4.00" forging,hoping for around 12-1400HP. I'd have no qualms about using a 3.75" Armasteel crank in a high HP turbo combo if I could keep the rpm down to 6000. |
#45
IALL block with Crower billet crank,aluminum rods & Ross pistons
4.356 X 4.25 hair over 505 CI 803 HP spin to 7,800 at times 10.05 @ 135 MPH Also have a Butler forged 4.50 ....for next bulid ??
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. ![]() Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
#46
Blasphemy!
![]() Doesn't fit in with what I wanted to build, a nostalgia funny car that is as period correct appearing as possible.
#47
Brian, You'll need the Mustang Pony on the Horn button..to be period correct.
#48
Butler (SGI, I think) Forged, then Cryo'd.
4.50 Stroke, weighed 75 lbs, before balancing 3.25 main 4.32 Bore Shift at 7500, traps at 7700. Makes about 960 hp
1978 Pontiac Grand LeMans.......out next year Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs. |
#49
Not sure where the controversy is?
73 455 block, N103 crank, cast lines in the crank were filed, blended and polished to perfection, then cut 10/10 balanced and nitrided to provide larger clearance than OEM... The block got the same treatment on all casting lines, lifter valley included, no casting flash anywhere... 4.185 bore, 4.21 stroke, 463 cubic inches... Just wrapped up my 5th season with this engine, 837 passes, about 10-20 break-in street miles back in 2006 and then all bracket racing, mostly 660', some 1320' passes. Launch @ 2500, 1-2 @ 6000, 2-3 @ 6000, traps around 6000 w/373's... Close to 600 HP maybe...
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
#50
More pics...
#51
4.360 bore
4.25 stroke IA2 Crower Billet Shooting for 1700-1900HP- Twin turbo Engine and parts should be back in my hands tomorrow. Woo Hoo! |
#52
Hey 455FB1969...the prep on that block and crank looks very nice. FWIW, when I was running the Discomobile with the nitrous engine, the 455 block I had was of '75 vintage and began life as a 2-bolt. Drilled it for splayed caps, filled it as high as I could and still be able to run coolant through it and deburred it similar to yours.
#53
4.15 bore 4.5 stroke Scat
701 RWHP at 5100 rpm 8.74 @ 155 mph @ 2950lbs Drive it all over, 900 miles in 27 hours this year on the power tour |
#54
4.155 bore, 4.0 stroke forged scat from the dude. was going to go 3.75" billet but that's another story...
shooting for 750 hp. turbocharged and injected on e85 1970 400 block |
#55
Crower billet
4.375 bore/4.250 stroke,
6.98 @ 199mph 4.53 @ 164mph |
#56
Factory Pontiac cast crank, later vintage, no "N" on it anyplace. Mated up to lightweight "I" beam rods and light weight JE pistons. Making a solid 550hp or a tad more, daily driven and raced on occassion.
I've never worried about the factory cast cranks, but they are becoming difficult to obtain, so we have been using the Star Galaxy forgings for the past few years, zero issues at any power level......Cliff
#57
Crower billet, stock block
800 HP at flywheel
505 KRE HP head 2x4 HP 1000s 60' 1.33, 5.78 @ 120.88MPH in 1/8 9.11@149.8MPH in 1/4 |
#58
![]() Quote:
I hear you. I just became so damn addicted to that turbo power ![]() Look forward to seeing it when its done.
#59
Thanks for the vote of confidence, but...although this car has been in the high 5's back in the day on fuel, the chassis will only cert' to a 7.50 by today's safety standards. That's why I'm sticking with a conservative combo.
#60
Building a '60 389 block, splayed center four bolt caps, filled block, 4.155 Ross dished, forged Ohio 3.75 crank and GRP aluminum 6.625 rods. To be turbocharged thru 325 cfm KRE D-Ports . Horsepower?--we'll see.
Dude, why the post? Can you shed some light on the "controversy"? Been a lot of combos displayed here and no explaination. Mark L
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build. |
