Old 02-18-2010, 05:47 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
Originally Posted by 666 the legend View Post
...Why is there BLUE OVER SPRAY on the inside of wheel well..?? is this suppose to be there..??
Yes. The factory was very generous with the overspray. I had a 74,000 mile '71 T/A that had been sitting since '81 and was undercoated when new. When I peeled off the undercoating the frame rails where cameo white.
  #42
ccie3611 ccie3611 is offline
yes,the overspray on the frame rails is correct.
  #43
Old 02-18-2010, 05:49 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
ccie3611 - how about a first name? Easier to "talk" on the boards that way.
By the way, Rick (who posted earlier in this thread) is close by, and y'all could really help each other out. Rick is in the middle of restoring his '72 455HO Formula (bought from myself a few years back), and he's doing an AWESOME job of it. I'm certain that he could help you out with the resto job on your M22 car, and your survivor T/A would be a great reference for him.
Regards,
"455HO" Lloyd
  #44
Originally Posted by Lloyd-TX View Post
Argh - just noticed that the "unobtanium" correct rear upper A/C compressor bracket is missing.
Dunno if your M22 car has the correct bracket, so here's a couple of pics . . . As you can see from these pics, the correct bracket is "scalloped" to clear the passenger side air cleaner snorkel pre-heat tube.
Proper repro hard fuel line from pump to carb is available from PY, and fits well.
Lloyd - i guess when the a/c compressor was replaced the braket was swapped for some reason. I do have the correct bracket for my other car and yes they are very hard to find.
  #45
Old 02-18-2010, 05:52 PM
Lloyd, yes Rick has conected me and we are going to hook up in the spring. and by the way my name is Brent.
I think i saw your blue formula at Swell Pontiac at the DAPA PSN show a few years ago - very nice.
  #46
Old 02-18-2010, 05:56 PM
weranc55's Avatar
weranc55 weranc55 is offline
Yes that is suppost to be there.
  #47
Old 02-18-2010, 06:01 PM
Lloyd-TX's Avatar
Thumbs up
Hey Brent.
Welcome aboard!
If you saw my Formula at Sewell, that would have been at the 2005 PSNs. It was just sitting on my trailer down from the show car area. I had raced the Formy on Saturday, and was showing my Shadow Gold 72 GTO WW5 car at Sewell on Sunday. Off topic, here's one pic of my GTO at Sewell that day. Alas, my Formula's condition has deteriorated greatly in the nearly five years since you saw it.
Name:	DSC01215 small.jpg
Regards,
"455HO" Lloyd
  #48
Old 02-18-2010, 06:03 PM
Hey Brent.
Welcome aboard!
yes thats right, i remember talking to you about the GTO very nice and you told me you had the Formula on the trailer - wow has it been 5 years.. boy time flies!
  #49
Old 02-18-2010, 06:04 PM
Lloyd-TX's Avatar
Brent - if I recall correctly I've heard that Barry Martin, Sonic Motors, is reproducing (or has reproduced) the scalloped HO A/C bracket. Might give him a shout. I seem to recall that Rick may have some info on this as well.
Regards,
"455HO" Lloyd
  #50
Old 02-18-2010, 06:07 PM
wow - i wouldn't think anyone would repro that bracket, there just aren't that many people that need it. i will look him up thanks!
  #51
Old 02-18-2010, 06:08 PM
Lloyd-TX's Avatar
Question
(Off topic once again) Ah-hah, I found a pic of my Formy on the trailer at Sewell in '05.
Name:	DSC01227 cropped s.jpg
Regards,
"455HO" Lloyd
  #52
Old 02-18-2010, 07:37 PM
7072PMD's Avatar
7072PMD 7072PMD is offline
THANKS FOR THE ENGINE/CARB PICS. WHERE DO THE 3 RUBBER VACUUM LINES GO TO. I MARKED THEM IN RED ARROWS. THANKS ANTHONY
Name:	72 ENGINE 4.jpg
  #53
Old 02-18-2010, 07:51 PM
on your pic the bottom line (on the right of the splitter) goes to the distributor vac advance. the second (on the left of the splitter) goes to a check valve that connects to the Dash AC controls, the other i don't know. i took the pics a few months ago and the shaker is back on right now.
  #54
Old 02-18-2010, 08:38 PM
7072PMD's Avatar
THANKS! WHEN YOU GET TIME IF YOU CAN SNAP PICS OF THE VACUUM ROUTING OF THE OTHER 2 LINES. IT LOOKS LIKE THE PASSENGER SIDE SPLITTER OFF THE BACK OF THE CARB GOES TO THE LINE OFF THE FIREWALL?? THE TCS SWITCH VACUUM LINES LOOK CONNECTED TO ITSELF WHICH SEEMS WRONG??
  #55
Old 02-18-2010, 08:49 PM
njsteve's Avatar
njsteve njsteve is offline
That was usually the way people would bypass them in the old days. But the problem is then that you are running full engine, not ported vaccuum to the distributor at all times.
I also see that he has a piece of hose with a screw in it on the front nipple of the TCS solenoid. That is actually suppoed to be the open end of the solenoid that just has the little foam filter slid over the open port. I believe it was designed as a relief so the solenoid could release, from a locked vacuum position.
In the photo below, the red arrows feed vacuum to the TCS solenoid. The green arrows feed the vacuum check valve (circled in green) and on through the firewall and to A/C & heater door selector. The blue arrows feed the vacuum line that runs to the distributor. You can also see the foam flter on the front nipple.
  #56
Old 02-18-2010, 09:10 PM
looks like my vacuum lines have been re-wired a bit :-)
Thanks for the info
  #57
Old 02-18-2010, 09:18 PM
njsteve's Avatar
No problom! Awesome car.
Can you get us a shot of the front of the alternator and the date code on top? I want to see if it is the open-face or closed-face style.
  #58
Old 02-18-2010, 10:00 PM
keepat's Avatar
keepat keepat is offline
Steve
Great diagram thanks for posting the info. It looks like I guessed correct on my lines.
Brent,
Is the flange on the bottom of the endure nose original and is it unpainted or painted as it looks like its blue in one of your pictures. See link below for more on this question.
Thank you for all the pictures!
Pat
http://forums.maxperformanceinc.com/...d.php?t=624471
  #59
Old 02-18-2010, 10:02 PM
the survivor TA has a replacement alternator, however my other TA i'm restoring had the original alternator (that is i believe it is original) - see the pictures. of course as you can see it has been restored by a local shop, i'm not sure the fan should be black.
ID:	197756   Click image for larger version
  #60
Old 02-18-2010, 10:09 PM
Originally Posted by keepat View Post
Steve
Brent,
Pat
i just went out to the garage to take a look and it definitely is not painted like the reset of the nose but it does have a blue color to it
