#41
She made it sound like they are a general purpose adapter that is somehow driven into the flared fitting. Then you screw the new o- ring types into it.. Some kind of malleable metal.. Maybe I have it backwards though...
I'll know more when I get them. Took a $10.00 flyer on them to see. I am a little confused too, but she knew exactly what I was asking for. Apparently she gets calls like mine often? I'll report back with pictures. If these dont work I may price aeroquip or russell, or heck.. I'll cut and flare!!
-- James Work '67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake." '75 Formula 400 - Daily Driver - Running with my Home Built 455 and TH400 Details here: http://forums.maxperformanceinc.com/...d.php?t=588372 |
#42
The offroad crowd buy them alot.
Derek B. Current best: 11.97@110 1.65-60' !!! '74 ventura, ![]() ![]() 1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram. ![]() |
#43
I talked to the guys at a small industrial/agricultural supply place close by and they can do the hoses for me by re-hosing the ends I supply. I have the o-ring ends that came with the unit and I have the inverted flare ends currently on the hose between the pump and the box. I split the old hose have the two ends mated to the appropriate o-ring ends, in the proper orientation, with new hose custom fit to length. No cost mentioned but they did an 1/2" air hose with 3/8 npt ends, 6' long, supplying all the parts and I think it was only $27, IIRC. So putting my ends on two hoses less than 4' long shouldn't cost me more than $20. This looks like one concern out of the way.
FWIW, Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters ![]() “Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill |
#44
![]() Quote:
Stewart
#45
James:
I was looking for something to use as a bushing in the pedal pushrod hole like you did. Couldn't find anything in hard nylon or such so started scoping my junk bins. Found a locking collar that fit the ID of the pushrod, opened the ID up to 7/16" and narrowed very slightly. A solid bushing will work well. After I'd done this I kept on looking for other stuff and found that a GM brake caliper bushing, the one the mounting bolts go through, has an OD that is just about a perfect fit in the pushrod, has the right ID for the stud on the pedal but needs to be cut down in width to about .250". So if you want a solid bushing ... FWIW, Stewart
#46
![]() Quote:
FYI I got the Lee Manufacturing adapters the day after I ordered them. I am still not sure how they work as I dont know what the end of a "New" power steering hose looks like. I'll go pick up the 2 that Old Goat used and see.. But it appears that you drive these adapters into the flared fitting and it gives the O-ring hose a modern end to pull tight to. I think for it to work the new hose has to be able to screw into the same Threads on the "old" pump/gear. But what changes is the interior; there will now be a fitting (nipple kinda thing) in the middle of the hole sticking up for the hose to tighten against. Still a bit confused but I will take a picture tonight of them and maybe try them out. I have a busy weekend so I dont know how much I can get done..
#47
By the way I may have you get set of hoses made for me. That might be a sweet deal. You might have to start sellign those to Hydroboost swappers!
I need to be more resourceful.. There probably are ag shops around here that would make hoses cheaply as we have lots of ranches... but the hose shop here wanted $150.00 or so as a ballpark figure.. I'm not cheap, just trying to spend carefully. $20.00 here, $50.00 there, and pretty soon you could of bought some nice leaf springs or a rear end!
#48
Vidguy,
If you want, I can get the hoses here possibly, flare the ends and strighten the bends like I did, then ship them to you. Or, PM me with your phone #, and I'll tell you how I did mine. It's not that hard. Charles |
#49
![]() Quote:
Stewart
#50
Well I got the vacuum booster and m/c off today. The mounting plate on my HB unit will only need two holes drilled. The bottom two holes are the right size and position to fit over the pedal mount bolts. My measurements on the length of the pedal pushrod indicate that I may not need much, if any, spacing to have pushrod and pedal hole line up properly. I will have to re-do all the brake lines from the m/c to the calipers though. Little if any way to make the lines co-ordinate with appropriate ports otherwise.
I plan on combining this swap with the S10 rear disc conversion. I know an adjustable proportioning valve is the best setup but I read in one of the other HB threads on another Forum (don't remember which one) of a guy who had the TA 4 wheel disc setup stock and then installed a HB unit. He said the combi valve was pretty much dead on for balance. Is the TA 4 wheel disc combi valve a good one for this setup? Are they even still available? Stewart
#51
Good going!
I had a picture earlier in this thread that showed the measurements of my 75 Formula Studs. They aren't Symmetrical. One side is farther apart in the vertical dimension then the other. Not sure why... I found the hoses that Old Goat 67 Used in his 67 GTO. I wonder if the approximate distance (therefore needed length) is close to the same on the two cars: A-Body 67 GTO and F-Body 75 Firebird Formula. I'm going to measure tonight. Here are the prices of the hoses at www.Rockauto.com $25.79 - Gates 36366630 $19.92 - Gates 357640 Thanks for the offer Charlie, I sent you a P.M.
#52
OK I got my two hoses from Rockauto. I spoke with Old Goat 67 on the phone! And I am going to try to re-flare these myself and bend them to fit like he did. I have a wedding to attend this weekend so I dont know how much I'll get done. I'll let you know.
#53
Well darn it since I mounted my Hydroboost the opposite as Old Goat, Cylinder near Fender, these hoses were a BEAR to bend and fit... I only tried bending the one...
I am resorting to making my own out of Aeroquip TFE hose. Anyone want my Old Goat 67 Hose mod Hoses? $43.00 shipped. One Brand new the other bent just a bit on one end. Cost me $54.00 shipped.
#54
I don't think I would have even attempted this. Why? High valve covers? Drian hole is there for a reason.
Please don't blame me. How bad are the hoses screwed up, I may want them still. Charles |
#55
Not blaming you buddy! Just that my install turned out to be different. You were super helpful. One hose is new one is bent a little bit that's all.
#56
Here's a couple of pix of my install so far. The unit went on with minimal fuss. I had to open up the firewall hole slightly but nothing other than that. The pushrod lines up with the manual brake hole in the pedal
![]() Once I cut down the OEM combi valve bracket and re-drilled the holes, my new disc/disc combination valve fit perfectly and the lines to the calipers/wheel cylinders needed only minor tweaking to line up. The pressure hoses are just to see if the routing is close. A couple of lines from the M/C to the combi valve and I'm set. Previously I had mocked on the inner fender and while clearance may be a little tight for the lines to the combi valve, they will fit. Now it's time to order the B-body spindles, 1LE rotors and new calipers for the front and the appropriate S10 parts for the rear disc conversion. FWIW, Stewart
#57
Good job! I bought the hose and fittings to make aeroquip lines a few weeks ago. Made one line and am waiting to put the motor in and get the new Power Steering pump in before making up that line. Will do this soon.
#58
Time to convert mine to HB .
Can you post part#'s or what they came off of...... Astro vans? Ive got the B Spindles , single piston calipers looking to get at least 2 piston calipers & 1LE rotors next also .
1972 T/A 455 TH400 (sold) Formerly..... Dreambird72 |
#59
![]() Quote:
There are other units that can be used as well. Do a search and you should get all the information you need. Stewart
#60
Here are a few shots of the Hydroboost installed and pretty much ready. the motor is just getting the final wrapup items.
I used the TFE hose and made the ends myself using Aeroquip reusable fittings I bought online. The hose I bought from an ebay seller who had some extra I guess. I bought the fittings mostly from sweetperformance.com. Thanks to everyone that helped and shared info. I'll let you know how they work.
