#41
....Case Reopened by DCI:
#42
(I didn't do it the first time, because it was froze in there, and rusted away..., but, now I know how important it is to NOT read oil pressure at the pump housing.)
'78 T/A W-72 400 w/468" forged stroker kit. '07 Solstice GXP (Turbo) '81 4spd Vette '03 VTX-1800c |
#44
#45
#46
#47
So, on a brand new motor, w/ RAIV 80lb pump, would it have been normal to slam >100psi on cold startup?
#48
Neither the crank or rods showed no signs of discoloration, in fact I was amazed that the crank bearing surfaces were still smooth. Would a brand new Eagle crank have out-of-round and/or taper problems?
#49
No, I don't have the bypass plugged,,,, should I???
#50
Chevy & Pontiac - 1955 |
#52
sorry to hear, i know i dont have the money in mine you have,but it hurtz all the same. never trust the machine shop, they have bad days too!did a motor for my buddys 66 gto 25 years ago,just a 389 rebuild,they tanked and installed brgs. but left a gally plug out.i didnt catch it. did the same thing.learn the hard way,20 lbs at idle 0 at 2000.sorry bud.
#53
Well,sounds like pics wont be fourth-coming if it all got shipped off to the machine shop.
Here's my thoughts,I always prefer to break an engine/cam in with a straight weight oil (I saw you used multi vis???),in temps warm enough to ensure good oil flow naturally,of course prime the engine (you did this,good)etc.,etc. My advice now is this,if one is experiencing odd oil/bearing problems:Take some oil samples! And send them off to a lab to see what they can find. It's a waste of time trying to guess what may be wrong. Ask me samples should be kept for/from the first 5 or so oil changes,then if problems arise you can go back and check those samples and see if the problem was sudden,or cumulative,after that,periodic testing is still a good idea to follow the engines health. From the sounds of this,ie. all the babbit gone,no rod/crank discoloring I would venture to say something (a corrosive condition or such) caused the bearings to "delaminate" or such and loose the top layer,but trying to discern that from one pic of a rod bearing and some debris in an oil pan is almost a laughable prospect. You stated the engine never got over 160 degrees,well,that's not exactly the best thing,this leaves a significant amount of moisture in the crankcase often as the engine does'nt get nearly warm enough to fully evaporate the moisture in the crankcase,this often leads to the possibillity of corrosives forming in the oil,this is often a common problem with alcohol burning cars. This often requires close monitoring of the oil and it's condition to watch for excess moisture buildup. And certain oils can react differently than other oils,especially when additives come into the picture,care must be taken so as not to create a "toxic cocktail" for your engine by playing with the oil make-up and engine operating conditions to the point where there is no way to know what might be going on with it's vital fluids. But this is just some WA speculation,same as the rest of these comments. And in the future,if anybody reading this wants us to give some advice,please provide better pictures if you expect us to have even a remote chance at being able to have some idea what may have went wrong. Bret. |
#54
thinking about sending my oil to the lab...especially since a similar thing happened with my last engine.
where might one find such a lab that would be able to analyze one's oil? What would be the best way to ship, and how much is needed for testing? after all, you'd think that if I got the oil directly out of the pan, the oil that first came out would have the most sediment in it...as it has already settled near the bottom. |
#55
Kendall dealers once provided the oil testing service, free to their customers. I doubt they still do, but you might ask. Or maybe Brad-Penn offers it, since they took over the old Kendall facilities in Bradford PA. |
#56
Around here it's very difficult to find a shop that can competently grind a crankshaft. I certainly wouldn't trust ANY aftermarket crank right out of the box. Due to the experiences I've had in the past I look for a few things when checking a crank before putting it into the engine.
First is surface finish and radius on the journals. They better be shiny. The more polished the better. They shouldn't have a "satin" look to them at all, you should feel no roughness with your fingernail going across the grain of the polishing. They should have adequate, full radii where the journal meets the counterweight. Mic the rod journals, checking for taper and roundness. Mic the mains, checking for taper and roundness. If everything checks out, set the crank in the block with only the upper halves of the end bearings in place (make sure they're well lubed as are the journals). Put a dial indicator on each journal and rotate the crank by hand. That needle better not move. There is a shop around here that can't seem to grind the mains all on the same centerline and their polish job looks like it was done with 100 grit. The journals are round, but the dial indicator test shows them to be all on different centerlines. Their crank grinder must be wore out. I don't understand how any engine they build survives. It took two bad cranks from them before I learned my lesson. There seems to be only one good large shop in this area. I've heard of small shops where some guy bought a crank grinding machine and does really good work for only a few customers, but so far I have yet to get hooked up with one of these guys. For now I rely on a large commercial shop that so far hasn't screwed me over, but I still double check all their work.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
#57
The oil clearance spec's people are talking about above appear to be stock RAIV spec's:
1970 RAIV Rod: 0.0015-0.0031 Main (1-4): 0.0012-0.0028 Main (5): 0.007-0.0022 Is that what we need to run, RAIV clearanses? P.S. Just a side note, I was talking to my boss who used to drag race Pontiac's many years ago and he said that the oil clearances was more than likely ont the problem in my case because he ran his engines on the tight side and never had a problem spinning his destroked 400's to 8,000rpms BUT he drag raced NOT road raced. From what he could tell my issue was because of oil starvation from braking and cornering.
Uneasyrider “To find yourself, think for yourself.” ― Socrates “The unexamined life is not worth living.” ― Socrates “Wise men speak because they have something to say; fools because they have to say something.” ― Plato |
#58
FWIW,
The "true" Eagle "kit" comes with Clevite CB743H bearings. These are considered the best bearing for the job. If your "kit" had "P" series or other brand than Clevite, it wasn't an Eagle kit, it merely had some Eagle parts in it. We deviate from the kit by deleting the main bearings (full-grooved Clevites) and adding Federal Mogul 3/4 groove. Aside from that, we let it alone... Jim |
#59
Did you all that have had failures all run std bearings if so the crank was never fixed from china and did you pay to have align bore did you ck clearance yourself and not with plastigage were your charged to recon. the con rods if not they are usually to tight on the low side of tolerance I found it's better to buy the tools needed and ck behind everyone Go to the shop measure your crank housings and crank and bearings that will tell you what the clearance was [same brand bearing this matters] My ohio kit was even off balance they allow as much as 7-8 grams for oil weight
#60
The machine shop had to rebalance the crank, repolish the thrust surface, and polish the rear mail seal sweeper grooves. However, after alot of talk time with him today, we are begining to think the bearing clearances were not checked. I assumed he did it, especially since I told him to check thrust clearance, rod side clearances, and make adjustments as needed. I thought with all the prep work I paid him to do, that checking the bearing clearances was included... (like line honing on his Sunnen machine, boring & honing cyl w/torque plate, short fill Hard Block, decking block to .005 in the hole, hot tanking, magnafluxing, pressure testing, balancing the entire rotating assy, install cam bearing, light porting E-Heads, port matching intake, and so on... so with all the work I had them do, I assumed the simple act of checking the bearing clearances was done by them. HUGE LESSON LEARNED!! NEVER ASSUME ANYTHING!! So, this time, I will recheck anything that I can check!
