#41
I grabbed on of these for my 64 Tempest.
https://www.holley.com/products/engi...ts/71222008HKR It says it's for an LS swap, but with all the adjustment holes on the mounting rails, I'm sure it will work for my Pontiac V8/5 speed swap. I went with this design because of all the adjustability, and the fact that it bolts to the side and bottom of the factory frame, so it should help stiffen the wiggle in that section. I'll mount the trans on a rubber piece, so it'll retain the factory movement-ability.
John IG: @crawdaddycustoms YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos |
The Following User Says Thank You to JC455 For This Useful Post: | ||
#42
PMD engineers most likely didn't want people chippin a tooth on a radical 1st - 2nd shift, albeit at the cost of letting the drive line flop around...
I mean, probably the main reason all the high horse power stuff like RA4's and HO models just fell apart in the street after a good beating. Frank
Poncho Huggen, Gear Snatchen, Posi Piro. |
#44
The 68 - 72 Buick A bodies have the same stamped cross member as the first picture
Sent from my SM-T817V using Tapatalk |
#45
Could it be that Pontiac just carried over the x-member cushioned design from the full size cars? The engineering was already verified and in use.
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
The Following User Says Thank You to KEN CROCIE For This Useful Post: | ||
#46
It never stops! I think I have some of the ripple in my quarter panel that Tom was talking about in the other post. My frame is boxed, though. I don't have the four speed rear control arm braces installed yet. Now this thread has got me wondering whether a 65 with a stick shift and a boxed frame can ripple the quarter panels on street tires just from not having those rear control arm braces installed.
#47
Industrial type machines, large compressors, generators and the like set on springs and other isolators to dampen the effects and save on wear or combat anchor failure. The people at PMD were not dummies, if you want something to function, but would like for it to live past a few hundred trips down the track... well, build it that way. Quote:
Edit - Those braces are well wroth installing, that rear cross member has been known to flex, 'bend' under heaver loads, especially since weathered and 50 yrs old. Frank
Poncho Huggen, Gear Snatchen, Posi Piro. Last edited by 4zpeed; 06-28-2021 at 02:08 PM. |
#48
How much do you think these rubber isolators actually move?
I would astonished if they changed more than 75 thou in horizontal motion, that most likely in events such as speed bumps, pot holes and curbs hit. I think Tom has the right idea; they are there for frame flexing and NVH reasons. The only thing Pontiac could have done better here to me is use clip nuts for speed of install. |
#49
^^^^^ next time I mess with mine I'm welding nuts to the top side bracket.
George
#50
I'd say the reason that the bolted or rubber isolated cross members both work is that they do so very little. The job of the rear cross member is to simply locate the transmission in both vertical and horizontal planes and nothing more. Would be nice to remove torsional stresses from the engine and transmission cases while we are at it, and the rubber isolated mount is better.
If I want to stiffen up the chassis I don't think I would start by taking a bent piece of round tubbing with squished ends and bolting it to a 1/16" unsupported section of frame rail and believe I really accomplished much. If chassis twisting loads the crossmember, then either the thin frame rail is going to flex a little or the rubber isolator is going to absorb it. In either case, neither Pontiac or the others were thinking that their crossmembers were doing anything except supporting the rear of the trans. If I were thinking of changing things, the only logical reason would be to design something that continued to locate the trans but with less weight.
#51
Edit - Some people can start a fight in a empty room... Frank
Poncho Huggen, Gear Snatchen, Posi Piro. Last edited by 4zpeed; 06-28-2021 at 03:34 PM. |
#52
Outboard rubber mount does almost nothing. Harder to install than direct bolt in design. I'd rather have something easier to install that locates, and controls, the trans more positively. Especially when a couple of degrees is miles when it comes to driveline angles. The thing is hand grenade precise when it comes to side to side location. The center rubber mount is totally sufficient to isolate vibration and secure the trans. Not counting on the crossmember completely to stiffen the chassis. Just that every little bit counts. Ever jack up the front of your car and watch watch what the frame does? Now's where someone can jump in and explain to me how the crossmember won't help that. I'll post up what I end up doing. Thanks for all of the input!
#53
Now when you slip the metal clamp over the biscuit, the bottom of the metal clamp is about 3/16 to 1/4" ABOVE the mounting surface of the bracket welded on the side of the frame. So when you install your proper length bolts and nuts, the crossmember is compressed quite a bit and does not "flop around" as some have assumed. So if the crossmember is trapped solidly by the biscuit, there is basically no movement unless the crossmember sees a high load trying to twist the crossmember and that is highly unlikely with the trans crossmember mount also trapping the crossmember and the trans in a "fixed" location. So if you have biscuits that allow the crossmember to move, you bought some crappy parts. The parts, as was posted were most likely there for NVH issues and agree were most likely a similar design to the big Pontiac stuff. But I have always used NOS stuff from Pontiac that I had on the shelf with no issues. So the comments about the biscuits allowing the crossmember to flop around is telling you that you bought some crappy repop parts. All above being said, I did not design the parts, I have just worked with the parts for many years. To assume that I have to explain why a Pontiac engineer did stuff means that the person making that statement has little knowledge of how a Automotive Vehicle is designed and produced. My uncle always said you had Cadillac and then Pontiac as the premium vehicles. The Buicks, the Oldsmobiles, and the Chevrolet vehicle lines were for the people who could not afford the Cadillac or the Pontiac vehicle. To imply that the Chevrolet vehicles was equivalent to the Pontiac in terms of which were Premium vehicles, is a laugh. Lots of misinformation in this thread, mostly made up in the last few weeks. Tom V.
#54
The cross member sets behind that point, where the body is solid. Now if your pulling the front tires off the ground using HP, you may need to re engineer something. The one piece body combined with the frame actually makes for a rigid structure, everything is basically a compromise, the body gets bolted on with rubber bushings. I get what you're talking about, as mentioned previously rubber gets old and aftermarket, well pffft..., but with some performance added you may need to upgrade. Between juggling everything that is needed to manufacture a solid quality product and guarantee performance and comfort, I think PMD has done a pretty good job. Edit - Quote:
Frank
Poncho Huggen, Gear Snatchen, Posi Piro. Last edited by 4zpeed; 06-28-2021 at 07:52 PM. |
#55
Frank
#57
I guess I should try and find a Cadillac crossmember. That way I'm not implying that Pontiac is inferior. Surely the Cadillac design is better since it's a luxury car. Give me a break. I thought we were ALLOWED to have our opinion. But if someone's opinion doesn't match ours it's "misinformation" and we just don't understand because we're not automotive engineers.
I'm trying to improve on the factory design. We all do it. That's Hot Rodding. That's why I started this thread. If you want to get your panties in a bunch, because I question almighty Pontiac and engineers, go right ahead. Take a look at EVERY transmission crossmember you can find. See any rubber booties where they bolt to the frame? I guess the Pontiac engineers 50+ years ago were the only ones that understood driveline vibration (NVH, ooh an acronym!). Sometimes, just sometimes, things get OVER-engineered. Adding cost and complexity to something with little or no gain. I think I may just fabricate a crossmember from scratch. Possibly box the frame where it intersects. Make it a three piece design for ease of removal and installation. Old Chevy trucks had a wishbone crossmember in some manual trans trucks that was riveted to the frame. Very beefy. If I remember correctly, it tied into the bellhousing. Converted one to automatic. Was a mother to get that crossmember out of there. |
#58
Did you post to get some opinions or just state your view point? Just because you don't like it doesn't make it a bad design.
You're allowed any opinion you wish, you know what they say... In the original post you said you never cared for the design. "My '65 Chevelle had a tubular design that I like much better" Nothing wrong with that, grab one from a Chevy... Frank
#59
#60
I apologize if my post seemed sarcastic, we're all Pontiac people here, much love brother. Frank
Closed Thread |
