#41
SC, it's the competitive "spirit" and striving for perfection that keeps us working these combinations to DEATH for many, many countless hours. Of course there are cars out there that are faster, just damned few, and I mean DAMNED FEW in the same state of tune running similiar and/or "conservative" parts. But that is NOT what keeps me in the game, I just flat LOVE having a daily driven car that flat ars ROCKS at the track!
Where many are happy just to get to a local cruise or car show where they can throw up the hood and converse for hours about each others cars, I LOVE TO RACE my car, every chance I get. Making run after run, tweaking, tuning, swapping out parts, testing new ones, etc. Then, on my own time, I visit the websites and post the information for FREE. I'm not at all offended by any of your comments, just wanting to clarify that we are ALWAYS open to suggestions, far from perfect, and never, never think that just because we do something one way or the other, that it is the only way to get the job done. If Robert or anyone else wants to build 8.8 to 1 SCR engines and fill them with "whiz-bang" modern profile cams to bring back all the power, have at it! I've treaded that road a time or two, and couldn't make enough power to run where we are at today, so we took another road, or for a better definition.....just changed course as part of our learning curve, nothing more, nothing less. I've been at this hobby most of my adult life, and have yet to see a RULE BOOK on how we are mandated to set up our cars, as you say, "to each their own".....have a great weekend!......Cliff
#42
I have said this a few times; however, if you build the exact same motor (every aspect), it will make the exact same power (within a 1% or 2%). We are talking about machines; once a combo is known (in every facet), it is easy to repeat the performance. There is no black magic involved. If this were not true, we would have to go through the learning curve every time we rebuilt/refreshed our motors....which is not the case. Now, getting it to the ground is different story. The key word above is they pretty much duplicated my combo. They probably tried a "trick cam"/didn't deck the block/have a *****ty fuel system/different intake and carb/etc/etc. If they had built your motor to the last minute detail, they would be make the same power. Now, getting it to the ground is different story.
GJN 1968 Firebird 400 461 3,580 LBs 3.2k Stall 3.25 1.657 - 60' 11.637 @ 115.45 http://www.youtube.com/watch?v=dEqzw...e=user&search= |
#43
SC,
Again, I will try to address your various concerns. Quote:
In 1998, I returned to police work as an investigator along with a handsome salary increase. I worked part time for a BMW/Mercedes-Benz dealer from 2003 to 2004. I did all their Dinan performance upgrades. I hold an ASE Master Automotive Service Technician certification, Master Engine Machinist, Master Body & Paint Technician & Master School Bus/Air Brake Technician. I keep most of my ASE's valid, especially the School Bus Certification as I do farm labor and commercial vehicle inspections as part of my regular police duties. I was promoted to Sergeant in 2005 and currently serve in that capacity. Quote:
Biggest fan??? Not really, but I do use them on occasion. Quote:
It is interesting to note that Crane recommends their #99840 springs with the aforementioned #96871 Blueprint camshaft. They feature 90 lbs seated @ 1.590" and 235 lbs @ 1.190" lift. Interesting, isn't it??? The spring rates are so similar. The Crane #99840 springs retail for $67.95/set and the springs from www.sivalves.com retail for $48.00/set. Somebody asked me for a cheaper valve spring alternative and I recommended the SI springs, that even Cliff has used in mild street applications and found their pressures to be very consistent. How is that not helping someone??? Quote:
And for the record, there is always someone faster... Quote:
It is likely that I will never subscribe to your point of view on camshaft theory, but I see no reason how you could read the information contained in this post and make the following statement: Quote:
#44
Cliff,
I really do appreciate all the time you put into posting your test results. I know other folks do too. Let me just clarify something here.... I like running the lower SCR combinations with the early intake events because it works well with the poor fuel quality we have out here in the Central Valley. That is in no way intended to show any disresepct to you or your approach and success with higher SCR combinations, longer seat timing and wider LSA's. I'm just putting a street motor together for my car and even though I will dyno it and post the data for conversations sake, it's really the 'seat-of-the-pants' dyno that makes me happiest when I am behind the wheel...Robert Last edited by Z Code 400; 01-20-2008 at 12:58 AM. |
#45
Here is a copy of an email conversation I had with Brian Crower regarding Comp Cams lobe profiles:
Date: Thu, 29 Jan 2004 08:09:57 -0700 Subject: Re: Dynamic Stability From: "Brian Crower" <brian@crower.com> To: "Robert Herndon" <zcode400@sbcglobal.net> Robert, Dynamic stability isn't talked about much because everyone seems to concentrate on lift and duration. Your observations are correct. A lobe profile that is dynamically stable by design will require less spring pressure at all rpm ranges. The current trend is more area under the curve and fast ramps. A certain company in Tennensee likes to employ super fast acceleration rates but the only way to slow the velocity over the nose is with higher and higher spring tension. There is no way in the world that raising the valve spring rates can make a good cam lobe profile out of a bad one. A dynamically unstable profile is just bad. Oval track racers know this all too well, but drag racers are often oblivious to this fact because drag engines only run for short periods of time. Have you ever wondered why the profiles are so different between the two types of cams? Drag racers are willing to use higher spring loads for the benefit of a fast ramp profile even if lobe life is shorter. Heavy spring rates and thick wall pushrods will get you by for a while but eventually things will start breaking. I agree with you that valve spring loads should be kept under 300 lb whenever possible with flat tappets. If you are running a Pontiac with solids you might also be interested in our #66962X980-16 CoolFace lifters. It is piddle valve style and is a legitimate Pontiac lifter. We can even put the EDM holes in your solid lifters for $70, but you must remove the pushrod seats first. Thanks for your interest in Crower, Crower Cams & Equipment Co, Inc 6180 Business Center Court San Diego, CA 92154-5604 USA Tel: 619-661-6477 Fax: 619-661-6466 www.crower.com |
#46
Here is another example of Comp Cams cutting edge Beehive Valve Spring technology.
These are #918 springs from a Chevrolet LS1 and Comp is experiencing a rash of failures, so much so that they have 'redesigned' the springs and changed the color codes. The red stripe #918's were the old version and the 'blue' stripe 918's are the improved versions. The problem is, they are still breaking, even when employed at far less than their maximum lift...Robert Last edited by Z Code 400; 01-20-2008 at 04:12 AM. |
#47
I dont lend much validity to second hand correspondances like that. And I gotta wonder how "Brian" or crower feels about you posting that Email without their explicit permission? As for the beehives,,,dont use them,,,never have,,,never will,,,regardless of who is making them... And again you give no info where the pic came from,or why they broke. I had a big long post Robert,but I just blew it off,but your like a tenacious little dog trying to pick a fight or something,well I could care less about all this dreck,and likely will just go right on about my forum browsing. What do you do,save all your emails so you can read them over and over again,then dig them up and post them here when you get all bent outta shape over something like this? CYA. |
#48
SC,
I see this forum as a sort of informational buffet. You take what information you need or that which you find helpful and abandon the rest. I have no desire to fight with you...None whatsoever. But, I must ask....Why do you continue to question my intellect and my motives??? You challenge me that I do not post enough 'hard data' and even make light of the fact I have had conversations with industry experts and when I offer you a sample of some conversations, you scoff openly, even when the information contained therein is quite general and widely accepted. When someone tries to share information openly and you state that they have "offered nothing" of benefit, I find that to be very closed minded and unfair. I do not agree with many of your approaches to camshaft theory, but I do not ever infer that you have nothing to offer the forum. I was confused by that comment because it was so contrary to the spirit of this post. I am most certainly not 'bent out of shape' about anything and I am not quite sure where that comment came from. I have no vendetta with you and I am not trying to make you look like a fool or a liar to the forum at large, something you seem to have little reservation in doing. Recently, I have even watched you begin to challenge Cliff, who has shared a tremendous amount of information openly in this forum, to include your preference for 'hard data,' all in the interest of helping and educating others about the Pontiac hobby. I must admit that I was surprised by that approach. I think after all these exchanges, it is obvious that you will never be satisfied with anything I can offer, unless it subscribes directly to your point of view. Having said that, I see no point in further debate with you...Robert Last edited by Z Code 400; 01-20-2008 at 04:37 AM. |
#49
Why do I question some of your postings here? Because they defy any sort of logic I can follow often. Quote:
Your a LEO,you know nothing is true till it's proven so,and verifiably so. And you never trust a suspect to tell you the truth. It's common skeptiscism,are you not familiar with that concept? Quote:
If I cant independantly verify it on my own,it's real hard for me to take anything at face value without any supporting evidence. And you know any "controversial" stuff like that Email will likely be denied as SOP after being posted on a forum like this,even if it is 100% true and accurate. If they (Brian or Crower) wanted to post that sorta info,there is absolutely nothing stopping them,except good business sense,and possibly some legal liabillity. I could care less about this tirade against comp and those XE lobes,I dont use them so it really does'nt hurt my feelings on the subject much,but you tend to lump the good in with the bad and throw them both out with the dishwater. Sorry,but that I dont agree with. Quote:
One more thing:
If you cant,than quit bringing that up in these discussions. If you mean looking at all the cam specs instead of just one or two cam specs,well go right ahead and call that my "theory",me I just call that common freakin sense... |
#51
Lately, there has been a lot of discussion about the metalurgical quality of the currently available valve lifters on the market. That discussion also includes the reduction of ZDDP in most of the commercially available engine oils. Having read as much as I can find on the subject and reading many of the posts in this forum dealing with camshaft failures, I thought it might be interesting to compile some first hand data with respect to the lobe failures that seem to be quite high in frequency.
My personal experience (locally) has revealed accelerated lobe wear with the #995 springs, even when the pressures are verified and they are installed at the correct height. In at least (2) separate incidents, I found the 1.65:1 rocker arms were added, which drove the #995's far beyond their 'normal' 372 lbs of open pressure. Having taken all of this into consideration, I think we can classify the Comp Cams lobe failures into three catergories: 1. Lobe failures with #995's that are correctly installed and broken in (cause?) 2. Lobe failures with #995's that are incorrectly installed at 1.600" (pressure) 3. Lobe failures due to high-ratio rocker arms with correctly installed #995's (pressure) We can obviously dismiss catergories #2 & #3 because they do not represent an oil or metalurgical failure, but what about catergory #1 failures??? Has anyone successfully been able to operate any of the XE grinds into safe, yet elevated rpm's with less than Comp's recommended spring pressures??? I would find the answers to these questions very interesting...Robert |
#52
and I may skip thru a lot of the post, but I always take time to read the ones from Cliff. He seems to have as much "real time" knowledge as anyone else you'll find. I completely copied his advice from an earlier column for my 455.
455 .030 zero decked Crower 60919 197 H-O heads and intake 800 cfm Q-jet Ram Air ported exhaust manifolds He seems to have a lot of actual back to back dyno experience and I appreciate him taking the time to post it for free.
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas |
#53
1968 Firebird 400HO convertible 1971 Trans Am 4-speed, white/blue |
#54
At a true 9 to 1 static CR and manual transmission, the 60243 cam will be just about right. You might consider adding Rhoad's lifters in lieu of advancing the cam.
Ken Crocie would be the one to comment on the HC-02 for that application, I've never used one, but I know that Ken has used them with Rhoad's and high ratio rockers in 455's and made power very similiar to hydraulic roller grinds.......Cliff
#55
#56
GM has been using them in a few different ap's since the early 80's.
#57
The original Olds 215 al. engine had "bee-hives"!
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
#58
Beehive springs cutting edge? More like as old as the Pontiac V8!!! I used to have a T Bucket with the old buick V6 and it had Beehive springs!!! It was out of a 61 Buick. Actuly wouldn't mind having it back!! Got like 34 mpg and would bark the 33x18.50's in every gear. Even had a heater and defrost unit in it.
#59
Posted by Z Code;
Agreed...However, Billy Godbold of Comp Cams has said that his company has re-invented the beehive to such a degree that their 'cutting edge manufacturing processes' makes all other forms of the spring obsolete...Robert Nothing like marketing your product !!!! But the proof is in the results in customer hands. Marketing and claims only go so far. |
