#41
I'm quite certain that Mac McKeller said they simply added more "dwell", or iron to the 068 cam lobe ramps to get more duration, but not increase the lobe height of .281" thereby creating the squared-shoulder appearance of the lobes compared to milder cam lobes. Mac said this wasn't his best idea for a street HFT cam since it needed higher spring pressures to control the lifter flying off the shoulders at higher rpm's and crashing back down in the back side of the lobe.
The SD455 motor utilized 1.812" installed height springs like the RAIV's with enough pressure to control the harmonics of the 744/Y cam. Spring info is on page 11, not 13 in the H-O manual. Dennis |
#42
.....a 541596 421 Super Duty McKellar #10 solid lifter camshaft.
The valve timing specs are pretty much identical to the RAIV '041' hydraulic lifter cam with 308/320 advertised duration, but with lower valve lift values of .445" intake and .447" exhaust using 1.65 rocker arms. Just thought I'd post this as a visual so others might better understand what some of the factory 'square lobe' cams looked like. Intake lobe. ![]() Exhaust lobe. ![]()
#43
![]() Quote:
Thanks. |
#44
![]() Quote:
It's been awhile, but if memory serves I ran .012"/.014" lash. Best shift points with my combo were right about 5400 RPM. From what everyone is saying, that 041 roller was a bit more "radical" than the 2802, which makes sense as it had 6 more degrees duration and a bit more valve lift.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
#45
B-man, That is the ultimate Pontiac square lobe I'm talking about. The 744 and Y cams aren't that severe, but certainly more noticeable compared to the 066/067/068 cam lobes and even the 041 'T' RAIV cam! You can visualize the additional material needed to make it a higher lift lobe like the RAIV cam and become more 'egg' shaped.
Thanks for posting those pics (I also have an NOS #10 cam too). Dennis |
#46
![]() Quote:
Dennis |
#47
![]() Quote:
OEM Cam PPI values: 066 @ 199; 067 @ 205; 068 @ 221; 744/Y @ 244; 041 @ 259 (252 @ 0.400" lift) Aftermarket Cam PPI Values: 2800 @ 224; 2801 @ 243; 2802 @ 250; Old Melling SPC-3 @ 246; New Melling SPC-3 @ 227 Lowest to highest PPI ranking: OEM 066 @ 199 OEM 067 @ 205 OEM 068 @ 221 Summit 2800 @ 224 New Melling SPC-3 @ 227 Summit 2801 @ 243 OEM 744 @ 244 Old Melling SPC-3 @ 246 Summit 2802 @ 250 OEM 041 @ 259 Observations: 1) The new Melling SPC-3 Cam (actually discontinued recently) is fairly equal to the OEM 068 cam and Summit 2800 (221/224/227 PPI's not respectively); 2) the old Melling SPC-3, Summit 2801, and OEM 744/Y cams are fairly equal (243/244/246 PPI's not respectively); 3) the OEM 041 cam's PPI would be greater if we used the RAIV head cfm flow values and 1.65 rockers...guessing maybe a PPI value of 280-ish. Well, take it for what it's worth and enjoy. We had fun playing with this. Dennis |
#48
Another observation is the Summit 2802 has a slightly higher PPI value than the old Melling SPC-3/OEM 744/Y (250 vs. 244/246) and not too far above the 2801 rated at 243 PPI...interesting.
Dennis |
#49
![]() Quote:
Dennis |
#50
That's interesting Dennis. Sure makes that 2802 look pretty good from that standpoint based off the numbers.
Really looks like it works nice in your 455. I'm surprised at how well that engine did with small valve heads. Your comment to Will.....are you having some detonation issues? |
#51
![]() Quote:
Dennis |
#52
For comparative purposes do you have a PPI value for the Crower 60243?
http://ultimategto.com/rest05cars1.htm |
#53
![]() Quote:
The compression ratio with what I'm doing should end up around 9.2-9.5 depending on how far the pistons are down in the holes. I don't think the RAIV makes sense for this engine. I'm not going to port the heads. They've been gasket matched and the bowls cleaned up/blended already and I don't want to put any more work into them. I'll probably sell them at some point. As mentioned, this is just a holdover engine until I can get around to putting together the 4" stroke engine I really want, so I want to find a cheap shelf cam to throw in it that will work well and I want to keep the shift point at 5K or lower due to it being a stock bottom end with unknown mileage. I was thinking of the Crower 60916 or 60242 also, but they're just a tad smaller and more expensive though I do think the 112 LSAs would be better for boosting midrange power and keeping the shift point lower.
#54
Will, with 9.2 to 9.5 compression the 2802 would be a great choice. Make sure you get valve springs that can accommodate the higher lift (.466"/.488"). You only need 120 lbs seat pressure and 275 lbs. At .500" lift. You will only need to rev to 5200 rpm which is perfect for the 455.
Dennis |
#55
![]() Quote:
Dennis |
#56
Frank, I see the 60243 has 228/235 degrees duration at 0.050" and .480"/.490" lift, so rough interpolation would put it somewhere in between the 2802 and the RAIV cams.
Dennis |
#57
![]() Quote:
#58
![]() Quote:
What kind of timing did you find it liked on the dyno with those numbers you posted? Wondering if you found what I usually experience with dyno time on an engine that is on the "edge" octane wise. Usually what it runs best with on the dyno is more than what I wind up with in the car because the operating conditions are so different. |
#59
![]() Quote:
Dennis |
#60
Thanks Dennis,
I've been down that road with engines that are on the edge so I understand what you're trying to do. Based on what you are experiencing with a 455, it seems that 2802 might work pretty good with pump gas 10:1 engines that are say,,,,400-428 ci?? Since the cam should act a little bigger in those engines. I'm just thinking out loud, with the 10:1 455's, the go to camshaft seems to be the RAIV stick with rhoads lifters to tame down the low speed characteristics, then it probably wouldn't be a stretch to think the 2802 could work in the same way for the smaller 400-428's without being too radical?? Just a thought. |
