#41
i just looked at current valvoline dex/merc bottles & at their website & didn't see anything related to "not intended for traditional transmissions" just the pre 2006 GM & other dates for ford etc. heres a link that shows close ups of thh current bottles at walmart. https://www.walmart.com/ip/Valvoline...allon/45514404 |
#42
Had to laugh while thinking of a friend who had a ~1990 chevy pickup back in the day, and was convinced that the recommended ATF was too thin for the transfer case. He used 80/90 gear lube and of course was then rebuilding the case a few months later. He lived in the southern US so it probably lasted longer than it would have durning the MN winter months!
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
#43
The wording was actually on the back of the gallon jug. It also states for auto so can't see why someone would intend to buy for a manual tranny. But, as long as some are using this with no issues, I know what I need.
#44
maybe they changed bottles or label info? this is the back of a walmart gallon jug n the link i posted.
#45
DEX I--DEX II--DEX III--MERCON.
The Allison when in tow-haul mode has the convertor locked 2nd gear and up. There also a deep pan option: https://www.amazon.com/Genuine-Allis...7838720&sr=8-7 When I had my 2004 Duramax I upgraded to this and it went from a 7 quart drain to a 12 quart drain. The gasket is reusable.
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
#46
ATI Super F 20 weight, recommended by my trans builder
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
