#501
All of you guys do a heck of a job thinking "outside the box" with a awesome enthusiasm but don't you think it's time to make the box bigger?Or make it bigger inside the box we already have?
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz “It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life” Notre Dame Head Coach Marcus Freeman 69 GTO NHRA Super Street Car 2860lbs 10.854@160.12 in Brainerd MN 7/2024 |
#502
Just got back from camping and I sure was hoping he would've made the show. Great to see a production style Pontiac running those number, very curious/excited to see what happens next year...
Johnny US Army Retired 1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac Last edited by Johnny406; 09-04-2016 at 09:54 PM. |
#503
About 1.5" longer?
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926} |
#504
One disadvantage of stretching the bore spacing inside the existing block dimension and increasing the bore to 4.400" is the removal of even more material from the main web area. Very careful machining would be needed to try and keep bulkhead material in the block. This is another area where a deep skirt billet block has a real advantage. To be optimal, race after race, a production based shallow block is a real handicap. The solid aluminum IA II block addressed the main bulkhead issue by making the bores for the sleeves stepped and very short, leaving much more material around the main web. Made it very difficult to hone for the sleeves but the effort is worth it. Making the bores 4.650" minimum for sleeves, may leave the bulkheads very thin.
#505
Not a bad run for a non promod pontiac engine! If someone would just sponsor him and build a pontiac promod engine he would competitive period!!!!
Albert Marquez 1965 GTO TWIN TURBO DCI RA5! |
#506
And what does a Pontiac pro mod engine look like??
#507
My RA5 head was designed with the opportunity to use a larger intake valve without shrouding. A 2.400 will fit with a 1.700" exhaust on a 4.400 bore and the intake valve can be as much as .230" from the cylinder wall if done correctly. Here is the math: 4.400"-Intake valve 2.400"- exhaust 1.700"- distance between valves .030"- exhaust valve distance from cylinder wall .040"= .230" I don't think for a turbo application that you will need anything bigger than a 1.700" valve to make enough HP. If you do then shrink up the intake to cylinder wall value a little and make it bigger. It can be done. I have a NASCAR RO7 cylinder head here at the shop right now that the intake valve is .210" away from the cylinder wall and the exhaust valve looks as it may even rubber the cylinder wall it's that close.
Don Johnston DCI MOTORSPORTS LLC 330-850-5050 shop 330-628-3354 cell Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!! |
#508
So far with a 6.364 looks like it would be #1or#2 maybe #3 in Top sportsman.........you know that class Curt Geise has been chasing year in and year out with his twin turbo Pontiac Powered GTO since what 2009?And Curt is pretty dang killer on the tree (by bracket racing standards)and pretty killer on a .400 tree in super gas....just tells me he knows how to stage a tt car....do it consistently....and cut down the tree......and he's been chasing it for a while now there's plenty of documentation out there that support that.
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz “It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life” Notre Dame Head Coach Marcus Freeman 69 GTO NHRA Super Street Car 2860lbs 10.854@160.12 in Brainerd MN 7/2024 Last edited by S/st 54; 09-05-2016 at 01:14 PM. |
#509
Depends on what you mean Jason. If you're talking bigger bore centers then my vote would be no. You might as well run a bbc at that stage. It's way cheaper.
#510
Out of curiosity,you could ask them. There 4.75 bs looks like it is maxing out tolerances to achieve a wider bs. IDK |
#512
... well, that's good question, which is not really simple to answer ...
... one of the advantages of the other brands 5.0 borespacing is they get to 526c.i. with much less stroke, therefore allowing a shorter deck block and still have enough room to put a good piston, pin, and ring pack in the engine ... ... if a Pontiac ProMod is to be considered, and if the std. 4.620 b/s is used, then obviously more stroke is required to achieve the same c.i. because of the smaller bore, so now to run an adequate piston, rod and ring pack, you now need a taller deck block because of the bigger stroke, which also makes the engine heavier to some degree, but the smaller bore will shroud the 2.400 intake valve more than the larger bored 5.0 b/s engine using the same 2.400 valve, which is not optimum either ... ... the CV-2, Visner's, or the Warp 6's would be my choices for an adequate cylinder head on this 4.620 b/s Pro Mod application, but if one is to consider increasing the Pontiac b/s to 5.0 b/s, which means a billet block and billet heads, the question Scott asked is now simple to answer at this stage, as it won't look like Pontiac at all, because no high end shop that builds NHRA Pro Mod engines is going to design a 5.0 b/s inline wedge head to go Pro Mod racing, so now what heads are left to consider for the 5.0 b/s Pontiac ?? ... ... obviously the current billet heads are going to be the easiest to adapt to the larger b/s as they can be easily changed in CAD to match 5.0 b/s, all the welding needed to do this to a 4.620 Pontiac casting would be, well, kinda not smart ... ... but the question that begs now, is after increasing b/s to 5 inches why would we not modify the cam tunnel and lifter bore configurations at the same time, we're already to the point of billet blocks and heads, so this now opens the door to a totally different cylinder head design to go hand in hand with the modern lifter bore and cam tunnel configurations, basically at this stage the "DOMINOE" effect has begun heavily and the engine becomes something radically different from where it started, and what you would find is the further one goes down the path of altered bore spacing and the changes the components go through, the more the engine will look like what the NHRA Pro Mod guys are already running ... ... the fact they call them Chevy engines is quite hilarious to me, they couldn't be further from it ... Last edited by Anderson Port Development; 09-05-2016 at 03:17 PM. |
#513
You made my point exactly Bill.... Once you start making all the changes needed, its no longer a pontiac, its simply a current pro mod engine...
#514
just like a real promod engine but with the word pontiac on the valve covers......
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
#516
... Lol, and there's the short and sweet version ...
#517
Just like a nitro Toyota...
Johnny US Army Retired 1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
#518
Hit the quote button instead of reply button to throw out a random thought.....my bad Scott.
#519
So I guess this thread was put to rest after the past weekend...lol
#520
I think the next step is Justin chiming in.
GTO George |
