Old 08-27-2023, 12:59 PM
Held for Ransom's Avatar
The pattern I posted is what I got back from Al Knoch. Compared to the original pattern on the mid-'70s ones,
Originally Posted by unruhjonny
/\ wait, i thought the grain pattern was 70-72/73, then it changed??
That reads almost like it changed at or after the mid 70’s…
I stated mid-'70s because of the casting date. I don't know when they went from the "beach sand" pattern to the "light erosion" pattern and I don't know the vehicle year this dash was pulled from (but light green may be a clue, thinking Esprit). This early-'70s dash doesn't have a casting date, unless it's the pressed in number. But does/did have a blue film covering the backside.
ID:	618911   Click image for larger version
ID:	618912   Click image for larger version
So long, farewell.
  #402
Old 08-27-2023, 02:09 PM
SD455DJ SD455DJ is offline
Here is the date stamp on the backside of the original dash (4-8-70), Made in Canada B Uniroyal stamp, and 84/8 chalk mark (???). Not sure if the last pic is clear enough to see the grain pattern, but has a stretched little worm groove look to me.
Hmmm, they are upside down when looking at the backside of the dash, but I rotated the images so they would read right-side up, but I guess they don't stay that way when transferred...
Dennis
ID:	618918   Click image for larger version
ID:	618919   Click image for larger version
ID:	618920   Click image for larger version
ID:	618921   Click image for larger version
  #403
Old 08-27-2023, 02:38 PM
unruhjonny's Avatar
Ok I figured I’d ask just incase;
When I got my car in 1995 it had a replacement (1978+) dash installed;
I pulled this one over twenty years ago from a 1975 Formula - I have understood that it’s not the early pattern;
I just figured I’d ask incase…
Unless something different literally falls in my lap, I wasn’t planning on using anything else.
1970 Formula 400
  #404
Old 08-27-2023, 02:51 PM
Jonny, It sure looks correct to me. Heck, I'd use it if I had it...gladly!
Dennis
  #405
Old 08-27-2023, 04:52 PM
Dennis
Dug them out. See if you think they look the same now. Of course touching them from the screen, they're going to feel the same. LOL.
So long, farewell.
  #406
Old 08-27-2023, 06:32 PM
Mike, Help me out...which one is which...(LOL)?!
Dennis
  #407
Old 08-27-2023, 06:48 PM
Top (black) has casting date of 10-2-73 and grid date of Dec. 1973. Ink stamp MADE IN CANADA INSP-(ector) 13 UNIROYAL front and date of 021174 back.
Bottom (green) has no casting date or grid nor ink stamping anywhere.
So long, farewell.
  #408
Old 10-15-2023, 10:58 AM
Dennis, did this car have the original radiator with the tag? You mentioned a 3 core, so an FM. Do you have a picture?
So long, farewell.
  #409
Old 10-15-2023, 04:50 PM
Mike, I'll have to check...but I'm thinking since the radiator was gummed up pretty bad when we got it, it was a replacement and didn't have the original tags, or else we would have taken pictures of them...and I don't see any pics of the radiator we removed.
Dennis
  #410
Old 10-15-2023, 05:57 PM
A good friend told me about an old radiator repair shop in Ferndale, MI called Ferndale Radiator Repair that still rebuilds/re-cores old radiators and heater cores the old fashioned way. It's good to know a few still exist for our old cars. I do need to have the original 3-core radiator rebuild as it is plugged bad, so will probably take it down there this spring.
Dennis
Dennis
I was just going by this other post. Thanks.
So long, farewell.
  #411
Old 10-15-2023, 08:22 PM
Well, now I'm just going to have to check upstairs to see if I really do have it...lol! I wonder if I was confused with the original 4 core radiator in my '71 455HO Formula...?
Dennis
