His last sentence "even with my fans running non stop 195 is at low as it would go"
Tells me he has a pair of electric fans. What has changed is anyone's guess until he responds to questions or gives more information, but for sure the Cold Case radiator is more than up to the task. Something else is amiss. |
The Following 2 Users Say Thank You to Formulajones For This Useful Post: | ||
With that said, I saw a similar situation on dad's car that I posted in my old thread about it way back when.
The cold case fans running non stop would only get the engine down to about 190 degrees and basically hit a wall, the fans would not shut off, even when it was running down the road. It ended up being the shroud itself being a huge restriction. Once the large open factory mechanical fan shroud was installed with a stock 7 blade clutch fan, leaving the Cold Case radiator in place, the engine won't get above 175, and in cases where ambient temps are below 80 degrees it'll run between 158-162 or so. Last edited by Formulajones; 01-24-2023 at 01:52 PM. |
The Following User Says Thank You to Formulajones For This Useful Post: | ||
Cold case
That post above is what I was referring to.
Basically copied what he had proven. Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, DUI HEI and Ram Air pans and RARE Long Branch Manifolds |
Jeff |
So back with some updates. And sleep. Made this one harder on myself due to the lack of it the last few days and trying to rush things.
Got my ir gun out again as a previous post had mentioned. Did this in the beginning and saw the temp difference from the gauge but chose the incorrect reading. I assumed the ir gun was faulty as it’s nothing special, old and has been kicked around for years. Checked it this am and it’s within 3 degrees. Bottom line I didn’t think this one through very well before I assumed it was parts I had just changed. I believe it’s the sending unit for the temp gauge. The gauge reads correctly for what the ohm level is in the sending unit but the sending unit ohm level is too high for what the coolant temp should be. My water crossover never gets above 185 as is. Fans cycle on and off as they should so I called nvu for a new sender. Apparently they no longer support it and have switched to a different one years ago. They scavenged the old sender from mercury marine / faria so at least I was able to order them from somewhere. Will update again when I get the new sender. Only “downfall” I can saw with the cold case is the champion had more coolant capacity. But not by a lot. Sent from my iPhone using Tapatalk
77 T/A- poncho 400| T-10|3.23| I beams|Hyper flat top pistons|Kre heads|Scorpion rockers|Xr276 hydro roller|Rpm intake|Smi qjet|Subframe connectors|Rancho sways|Mcleod super street|hydro clutch|More i cant remember |
