For what you are trying to do I would consider just buying a Tomahawk. The intake made from SD Daves fully ported HSD.
It will take a whole lot less to get to where you want to be and I bet very little difference in performance. I ran one down to 11 flat in a 9-1 455 with a 850 DP carb sitting on a 1" Super Sucker on top of a 1" open spacer. It outran my gasket matched T2 intake with ease. |
Hey Paul I noticed in the picture of the manifold you ported for the 315 cfm head the wall between runners 1 and 3 is bevelled to direct more air to runner 1, same is true for runners 2 and 4 with the bevel forcing more air to runner 2. Is this done to compensate (as 1 and 3 are longer runners) to get them to flow more to match the flow of the shorter runners 2 and 4?
1972 GTO 468 2 Bolt Main w/Eagle rotating assy SD Ported 295 KRE D Ports 10.8 CR OF Hydraulic roller w/ 1.65 stainless rockers Performer RPM Intake Holley 3310 780 Vacuum Secondary TH400 with 10" Continental Convertor 8.2 BOP 4 pinion 10 Bolt with 3.36 gears 11.428/118.95/1.618 |
"... in a previous intake comparison dyno test on a similar engine with a Tomahawk and a Torker II with a 950HP and 1 " spacer, the Tomahawk was within a few hp of the Torker II."
https://www.sdperformance.com/newsStory.php?newsID=44 In the link note the big difference between the two intakes when a Q-jet was involved with the Tomahawk. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 01-03-2023 at 04:27 PM. |
I guess the big question before you spend a lot of time grinding is what are you HP plans? Since an untouched plenum can go 550 or more are you going to be there?
Within that link I posted above...
474ci engine running a set of 290cfm CNC ported KRE D-port heads with 10.2 to 1 compression with a 236/245 duration hyd. roller cam (Old Faithful). Torker II has a square bore plenum so we installed a 950HP Holley on top of it with a 1" open spacer for the last test. The Torker II didn't disappoint and produced 554hp @ 5500rpm and 584 lb ft @ 4500 rpm. .
As mentioned the T-II doesn't need a lot of help and can support big HP and even rival the Victor/Dominator to at least 600hp.
What is does REQUIRE is at least a 1" open spacer to see full potential. Same with the Tomahawk. IF you really want to get your feelings hurt test a single plane intake with a spread bore carb on it without a spacer. They are bad enough with square flange carbs and no spacer, but the huge secondary throttle plates from a Q-jet ot TQ sticking deeper into the plenum area than the front plates causes turbulence and distribution issues that can cost you a LOT of power.........
With a 950 carb. It surprised me as my other motors was with victor intakes same carb and HP. GT GT |
