Old 01-06-2023, 09:15 PM
SD455DJ SD455DJ is offline
Kent, 1.65 rocker arms will require you to enlarge the pushrod passages in the heads since the fulcrum distance is moved towards the stud (closer). I would go with a cam swap myself (2802 or equivalent). Get the Hy-Lyft Johnson lifters that Paul Kippen carries, I believe. You can still use your 1.50 rockers with that cam, but you'll also need to install stronger 7/16" studs and poly-locks to adjust the lash. You would need to do the same thing with the 1.65 rocker arms.
Glad to hear new RA manifolds and Pypes exhaust are working for you.
Dennis
Old 01-08-2023, 01:19 PM
KSZR KSZR is offline
Dennis
Has that cam changed? Summit has it as 298/303. The pontiacpower cam list online says 282/292. Both at 224/234.
Old 01-08-2023, 01:50 PM
I'm sure they are the same cam. That core is sold by almost every cam dealer, but the Summit version is the least cost...usually. You'll see that the seat numbers vary a bit from supplier to supplier to make it look unique, like a special grind.
I forgot to mention that going to the 2802 cam, or any aftermarket cam with greater than .450" lift, you'll need new valve springs to accommodate the higher lift (120# seat pressure/280# open is plenty).
Dennis
Old 01-25-2023, 09:40 AM
Dennis
Do you like the R or just the standard Johnson Hy-Lyft?
Old 01-25-2023, 09:45 AM
Kent, we typically just buy the standard 'S' lifters and 'zero' lash/adjust them (1/4 turn past no movement up/down in the pushrod cold) with polylocks or crimp nuts. The 'R' is the quicker bleed down lifter ala' Rhoades, so noisy.
Dennis
Old 01-25-2023, 09:52 AM
Dennis
Thanks Dennis.
Stupid questions,
When adjusting the lash do you need to have valve being adjusted closed?
Should the new lifters have run a bit to get oil into them or does that matter?
Been a while since I did this!
Kent
Old 01-25-2023, 11:22 AM
For a new cam & lifters you need to follow break-in procedure: you should apply the moly lube past on the cam lobes & lifters, adjust each lifter when it is on the base circle (so valves are closed), reapply moly lube after lifter adjustment, set #1 to TDC, prime your oiling system with the distributor out with a drill and priming tool to fit on the oil pump drive shaft (counterclockwise rotation), reinstall distributor to #1 with 12 degrees advance on the timing marker.
Dennis
Old 02-12-2023, 07:23 PM
Got a chance to run with the drag radials today. Picked up .4-.5!
Quite a gain, broke well into the upper 13s.
The Following User Says Thank You to KSZR For This Useful Post:
Old 02-13-2023, 12:17 AM
Congrats on the 13's.
Old 02-13-2023, 08:09 PM
X2!
Dennis
Old 02-13-2023, 08:40 PM
Thanks guys. Basically tied with the Mach E now! Might need to go to the strip next summer to settle it.
Old 02-14-2023, 10:27 PM
67drake's Avatar
67drake 67drake is offline
Hey KSZR, I just noticed this thread.
So I’m not clear, did you end up doing a cam swap or no?
Congratulations on the 13’s.
13.95 @ 102.1 on street tires @ 4055lbs.
Old 02-14-2023, 10:47 PM
No, still running the 068. Thanks for your input on the tires!
Mickey Thompson drag radials on some old spare honeycombs.
13.87 was the best of 2 runs.
Old 02-15-2023, 01:53 PM
67drake's Avatar
What was your MPH and engine RPM at the end?
Old 02-16-2023, 01:42 AM
99.86
I think around 4900 but not exactly sure.
Old 10-27-2023, 09:57 AM
Put the wing back on in black. And some 70.5 stripes to match it and the interior.
ID:	622310   Click image for larger version
Old 10-27-2023, 01:18 PM
KSZR, Love them stripes! They look great.
Dennis
  #38
Old 10-28-2023, 10:21 AM
Thanks!
The car has been evolving since I started on it in high school.
Fun to change and improve what I want, while trying to stay true to it being a Pontiac!
