Some may need a Pontiac bell housing besides a flywheel. One I used needed a manual flywheel. Other a flexplate was OK
![]() Quote:
Thanks guys, alot of good information. |
It's not hard to see if the dyno numbers are fudged. Simple math with the BSFC and Lbs. Per Hour of fuel will give you a real number and you can then check that against the correction factor to see if it's reasonable for the condtions.
If the BSFC and Lbs. Per Hour are not listed on the dyno sheet (I've seen many that are not) then take those dyno numbers with a grain of salt. |
![]() Quote:
![]() Quote:
While most of this information is not of an use to anyone it is just an example of what is saved. This is a Big Block Ford which I believe was dynoed at West Tech. Stan
You generally get multiple pages printed. All those things are measured, it's just a matter of whether they choose to print it.
If I don't see it presented with the rest of the data, I don't put faith in the numbers. |
Also some places if you bring a thumb drive will give you a copy of the "SFD" files. That is what happened for the example I posted above. I also know some members here have gotten their "SFD" files because they have been nice enough to have shared them with me. That being said you do need the Super Flow Win Dyn software to look at the "SFD" files.
Stan
My last shop that used a Superflow you could out them on a USB and open it up using a free download form Superflow and look at every page of data like Stan said. Dyno operator did not know how to so I walked him through it .
