Old 03-25-2022, 07:37 AM
comanchefirebird comanchefirebird is online now
Comanche built fall of 68 is 10C, the TA is 06A
Old 03-25-2022, 10:38 PM
necdb3's Avatar
necdb3 necdb3 is offline
Mine is a 3 hole bracket.
Old 03-28-2022, 04:44 PM
trmjr1 trmjr1 is offline
Just took a look at my original '69 TA and it has three bolts (4th week of October '69 build).
1969 Firebird 400 Convertible
"We have got but one life here. It pays, no matter what comes after it, to try and do things, to accomplish things in this life and not merely to have a soft and pleasant time." - Theodore Roosevelt
"Light travels faster than sound. That is why some people appear to be bright until you hear them speak." - A father's words of wisdom to his children
Old 03-31-2022, 07:15 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
Originally Posted by A Schab View Post
Scott,send me your e-mail and I will send you a picture. I don’t know how to post one on here. You could post it here for others then.
See this thread and if it helps to load picture...
https://forums.maxperformanceinc.com...d.php?t=856938
So long, farewell.
Old 03-31-2022, 07:18 PM
My swivel...
ID:	587671   Click image for larger version
ID:	587672   Click image for larger version
So long, farewell.
Old 06-02-2023, 08:24 PM
tekheavy's Avatar
tekheavy tekheavy is offline
So I just received my aftermarket Reverse Lockout Rod from Ames. Part number FR684T. For my 69 4-Speed Bird. Could not get it to fit. Each side fits by itself in it's prospective holes, but once one side is in, the other side would not fit. And I think I see why. See pics. The first pic is the side that goes in the arm on the tranny. It's 90 degrees to the rod. Second pic is the side that goes in the swivel arm. It is more like a 45 degree bend. It seems like if they we're both 90's it would fit. Could some who has a original one or a pic of an aftermarket one that fits please let me know if this looks right before I call Ames for a refund or replacement?
Name:	Reverse lockout 1.jpg
ID:	613593   Click image for larger version
Name:	Rverse lockout 2.jpg
Old 06-02-2023, 11:39 PM
A Schab A Schab is offline
Send a PM with your email and I will send you a picture. I still don’t know how to attach a picture here.
Old 06-03-2023, 08:19 AM
tekheavy's Avatar
PM sent. Thanks.
Old 06-03-2023, 07:38 PM
tekheavy's Avatar
Another PM sent. Forgot to give you my email address.
Old 06-03-2023, 07:54 PM
I sent them to you.
Old 06-03-2023, 08:56 PM
tekheavy's Avatar
I sent them to you.
Thank you very much.
Mine looks very similar to that if not the same, but for some reason I cannot get mine in place. it is as if one of the bends are wrong.
Old 06-06-2023, 03:50 PM
StevenK StevenK is offline
I had same problem with the AMES replacement lockout rod in that barely fit but caused the linkage to bind. I found an original rod in my parts bin. The Ames rod is off several degrees from fitting properly.Not sure you can bend it to fit unless you heat it up with a torch.
Old 06-06-2023, 04:03 PM
tekheavy's Avatar
I called Ames a couple of days ago and they said they had no returns on this part number. Did you return the part?
They requested I send them a bunch of pictures of the rod with different angles, which I did. Just waiting to hear back from them.
Just hope they are not comparing mine with other ones they have in stock, because they all could be wrong at this point.
Old 06-06-2023, 05:24 PM
No, I never returned the part as I could use it later after I tweek it if need be. Shipping is half the cost of the part now a days anyway! I did compare them side by side, never took a pic, but saw the Ames was off several degrees. Not as bad that it would not install, but my linkage may be worn more that yours.
Old 06-06-2023, 06:08 PM
tekheavy's Avatar
I am hoping that if Ames realizes the part they sent me is defective, that they will pay for return shipping.
Hey, I guy can dream.
The Following User Says Thank You to tekheavy For This Useful Post:
Old 06-09-2023, 10:11 AM
Default 69 Fb reverse lock out
The reverse lockout rod from Ames for the 69 Firebird is wrong but if you work it with vice and go up and down underneath the car about 12 times you should be able to get it to work we did with ours
Old 06-09-2023, 02:06 PM
tekheavy's Avatar
So you're saying it's just like every other aftermarket part?
