Old 01-11-2022, 08:28 PM
Aus78Formula Aus78Formula is offline
I believe the valves were supplied by Kelsey-Hayes and did similar vehicles. I don't know that any were the same part or substitute, but may have found their way into a few non-popular models for collectors. Of course, using the same casting doesn't tell of any internal tweaks, but they'd need to identify the differences somehow. The threaded lines may not be the same either. It may be easier to reverse-engineer, find out which models use the same brass block offered now and if internals etc match.
Old 01-11-2022, 09:25 PM
burd's Avatar
burd burd is offline
A buddys getting 3 birds in to part out, if you can wait. Ones a 1980 recro ta.
I won’t mention names, no one seems to know the guys that are always at the Big swap meets ��
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here
Just Say No To 8” Flakes
F ire B irds
Old 01-12-2022, 11:05 AM
78w72 78w72 is offline
what is a 1980 recro ta ??
Old 01-12-2022, 11:28 AM
burd's Avatar
It’s the one I may buy the seats from.
F ire B irds
Old 01-12-2022, 11:57 AM
Mike Davis's Avatar
Never seen an 80 Recaro's
I have seen an 81 with factory Recaro's
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 01-12-2022, 12:12 PM
burd's Avatar
Omg. It was a typo.
F ire B irds
Old 01-13-2022, 01:54 PM
77 Canamman's Avatar
Lightbulb
Originally Posted by Mike Davis View Post
Thanks Skip and Scare. I may go that route. I am trying to make this thing look like a 100% stock TA under the hood. Keeping the 4.9L on the scoop etc. I let my 10yo daughter pick how she wanted to do it. She chose the sleeper route.
Here is the current valve that was on the car.
Have that one rebuilt...
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 01-25-2022, 04:29 PM
ta6point6's Avatar
Sorry for hi-jacking thread but does anyone know if the Cadillac 4 wheel disc proportion valves are the same as the Pontiac 4 wheel disc valves? There is a guy who has one for sale from a 1980 Caddy and he says it is the same as the Pontiac proportioning valve. I actually looked at it but I do not see any part numbers on valve.
going bandit-Reynolds style
Old 01-25-2022, 06:49 PM
The Caddy Eldorado is a FWD car, different weight bias and characteristics.
Old 01-26-2022, 07:56 AM
Maybe if the reference being made to 1975-79 Sevilles, which was essentially a Nova in Cadillac trim.
Old 01-26-2022, 11:16 AM
ta6point6's Avatar
Makes sense but I bought anyway it was only 10 maybe a Caddy guy would want it.
Old 01-26-2022, 02:14 PM
Original 79-81 4 wheel disc Bird prop valves were cast iron. Over the years I've pulled & used the 4 wheel disc prop valves off quite a few '78-79 Sevilles. Also have pulled numerous nice used '79-81 T/A 4 wheel disc prop valves & even a few nice appearance original 4 wheel disc boosters. For my '79 w72, am reusing a very clean original 4 wheel disc booster i pulled 30 years ago off a '79 403 car.
marketed at least 20 years ago, the brass construction Delco Morraine 4 wheel disc prop valves were first used I believe in early 90's GM 4 wheel disc applications. Then the aftermarket got involved having their knockoff brass prop valves & boosters made for the bug smacker crowd.
Old 01-26-2022, 03:34 PM
Mike Davis's Avatar
Were the originals cast brass?
