![]() Quote:
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share |
Windowed or non-windowed inlet seat makes no difference as long as fully functional.
The non-windowed seat appeared 1975 in the M4-type Q.jets for better control of fuel slosh in the bowl. An old Q-jet with leaking inlet seat, leaking well plugs, fuel percolating or flooding at shut off due to fuek lines too cloose to hot parts of engine may make the engine start easier when cold as the intake will be "primed" by the fuel that leaked into it. A newly properly maintainanced Q-jet wont have those issues and may not start as easy. |
Seriously, How many people actually " Fully depress , and slowly release the accelerator pedal", JUST ONCE ????
Be honest...... I manually set choke under hood and pour in some fuel. Hit the key. Engine Usually runs long enough to pump fuel into bowl and keeps running on high Idle. Have worked in a GM dealership and watched people, especially men, and they "almost" always do 2 things related to cars and bikes. 1. Pump the gas pedal like they have to suck fuel out of a well thats down 20 ft below the ground. 2. Rev the engine up and down and slip the clutch on and off as if they need to help get the car or bike rolling, or are scared to let the clutch. Yeah Slipping the clutch for NO reason. Have had to change carbs, or carb bowl section many times for excess wear, and even tried the springs on the accel pump seal. Wear is bad when its dry. Have had to change clutches WAY prematurely due to slipping by owner.
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather |
![]() Quote:
I bought my owners manual as an NOS Canadian printing many years ago, and spent time reading it over and over... Asking prices for these (the English version that is) now are plain nutty.
Couple cars here I don't even use chokes on and they still start pretty easy when cold outside. Usually pump the throttle a couple times and 3-4 crank revolutions and it'll fire to life. Don't have to monkey around very long to keep it running either. Usually will idle on it's own within a minute of running without the need for a choke.
If cars are more finicky than that then there are some tuning issues to be addressed. Usually not enough idle timing (assistance with vacuum advance is a big help) or the idle circuits on the carb are way too lean (I find this all the time with todays fuels and stock carburators). Using todays fuels I find the idle circuits need to be fattened up to be happy. Usually starting issues are a combination of both of these scenarios. If you have a dry carburator that's a completely different problem. Gas isn't going to evaporate in 2-3 days, it just isn't. I don't even have an empty carb after 2 weeks of sitting. I've even left the nomad sit for a couple months and when it comes time to move it, I only have to crank it for a few seconds and the fuel pressure gauge comes right up and it fires off. It just sounds to me like you either have a carb that leaks, a fuel pump that drains back, a fuel pump that looses it's prime, or maybe a rubber line somewhere sucking air, or maybe a fuel system that doesn't vent properly and as it cools off it sucks fuel back to the tank, or some other strange anomaly. |
So I've been lookin into other electric pumps apart from the Airtex I posted before....
Contacted Facet, who supplies pumps for Holley and they suggested their 60106 POSI-FLO, which is the same thing as Holley's Mighty Mite 12-427 ![]() ![]() Question Would I have any issues mounting one of these pumps vertically? I'd want it to be completely hidden without cutting any of the hardlines, so I was thinking about just extending the rubber lines and mounting it behind the quarter kinda like this (some high quallity rendering, I know) ![]() |
Does that need a relay though? It cant draw much current? Great Location Idea.. really like it .
if you want it out of sight, why not put it somewhere near were the hard lines are connected together (with sections of rubber hose) in front of the tank?
It looks like 1.5 amps so you should be good without a relay. Toggle switch or tie to ignition switch.
Electric pumps, to be as effective as they can be, need to be as close to the tank as possible. They are excellent pushers but terrible suckers. Which is why generally with an electric they recommend having a much larger pickup line in the tank vs the feed line to make life easier on the pump.
Relay not required as long as the switch is rated to handle it, however, i use a relay for just about every circuit I wire up (force of habit)
I also like to use the smallest buttons/switches to keep things hidden or at least look OEM As for pump location, as FJ said, its generally better for the pump to be as close to the tank as possible and as low as possible (which is why you see many track cars with a fugly pump hanging down low behind a tank) I have a HUGE 250GPH pump on my Road Runner and hate the way it looks, but there's no hiding that monster. That being said, with the minimal use this pump will see, I think anywhere in the system will just be fine for priming |
That car always had carb problems. I ran a reman service replacement on it for a while and it ran better. The carb I sold it with is the original RAIII 4 speed carb original to the car. I kept the service replacement.
I rebuilt the original carb twice. It'd run better for a while.. then go back to running crappy again. I was afraid of sending it out to a professional as that is a very rare and expensive carb. I was afraid it'd get lost.. or I wouldn't get the right carb back.. It always started with a couple pumps if it sat for a week or two and would go to high idle and kick down.. Any more time than that it took some cranking and pumping to get it going. Wasn't a big deal to me... just an old car.. When its running right.... that car is a screamer... it rips!
![]() 1973 Formula SD455 - #'s auto orig paint 1972 Trans Am - 4 speed orig paint 1974 Formula 400 - Ram Air automatic 1966 2+2 convertible - 421 4bbl automatic 1967 Grand Prix - 4 speed orig paint 1967 GTO - 4 speed orig paint 35k orig miles Last edited by 71GP76TA; 11-09-2021 at 01:14 PM. |
![]() Quote:
Happen to know if it has windowed seat in it currently? Apart from the bowl leaking down, I haven't had any issues with it Ordered up a high flow non-windowed seat for it, but if the electric pump fixes the initial start problem, I probably won't tear into it. |
![]() Quote:
I was having problems with hesitation when i put my foot in it. After I rebuilt the carb it was fine but eventually went back to doing the same thing. Probably kept me from hot rodding it.. LOL..
![]() 1973 Formula SD455 - #'s auto orig paint 1972 Trans Am - 4 speed orig paint 1974 Formula 400 - Ram Air automatic 1966 2+2 convertible - 421 4bbl automatic 1967 Grand Prix - 4 speed orig paint 1967 GTO - 4 speed orig paint 35k orig miles |
![]() Quote:
A new plunger and seal ( usually with a sealing spring) will make it ok for a while, but eventually back to leaking by on a hard throttle push. The wear is at the top, first 1/2 inch of travel. Had a bunch of these on warranty and that's how original carbs got replaced on many cars.
How would the soft rubber or leather skirt of an accpump plunger wear out the zink alloy or aluminium accpump bore, and within the warranty time?
Never seen this on 40-50-60 years old carburetors with hundreds of thousands of miles on them. |
![]() Quote:
Zinc, and or Aluminum is NOT very hard. Usually the upper part of this area would wear the most as well as the hole in the air horn. This was Not just Q jets, 2bbl and Mono Jets did it as well. You may not be able to tell by looking, and the rubber/leather skirt was pretty forgiving. Gm eventually put springs in these to increase the pressure to the side wall. This did make up for some of the wear. Worn carbs, the problem comes back, and so does the customer, to the dealership. Just something to look at Carefully and up close next time you have it apart. Usually scoring and discoloration is present, usually on the side facing the Fulcrum of the plunger lever up top. I can envision more wear taking place now, vs then with fuel evaporation taking place. Just something to carefully look into if you have it apart.
#38
![]() Quote:
Never thought about that.. (duh).. I'm guilty of pumping the sh** out of it when it wouldn't start... I'm sure I didn't help matters any.
#39
![]() Quote:
I haven't noticed any hesitation, but she did respond better to a little more timing after I installed the Breakerless setup Some random dash cam footage just rippin around a bit https://www.youtube.com/watch?v=nfTsxIxwyIY Quote:
Figure I'd replace it if/when I swap out the non-windowed seat Which shaft length do I go with? https://quadrajetparts.com/quadrajet...-c-128_22.html |
#40
1967-74 Pontiac Q-jet, except 455S.D., uses 2.745" length pump assembly.
455S.D. uses a 2.556" pump assembly. 1975-79 uses a 2.572" pump assembly w/garter spring. And, pumping the pedal is never a good thing for various reasons, unburnt fuel flushing oil-film in cylinders is one, leaving the seal at bottom of pump bore another, but it will seldom if ever wear the bore out. |
