Old 01-22-2018, 10:21 PM
fyrffytr1's Avatar
Originally Posted by Tempest View Post
Well, if that is the situation, go for it, You have a great looking car that looks 'complete', so why not go for the posi and lay down 2 stripes.
Thanks. One other reason for the switch is some of my friends have Chevys with posi and I need to uphold the GTOs honor.
Old 02-12-2018, 01:07 PM
teecee teecee is offline
Default 2.93 gears
hi guys...new to the thread....am finally after 10 years building out my 67 hdtp......my biggest concern was the 2.93 gear set...after reading this thread....I think ill keep them and add the posi unit...I was hoping to find either a 3.08 or 3.23 ring and pinion set to fit the mid carrier and add a posi unit [as most of you probably know...good luck w/ that]....any way looking forward to wasting a bunch of time going through the site
Old 02-12-2018, 02:43 PM
GT182's Avatar
GT182 GT182 is offline
Phil, here's what I have for the change to the 3.36 ratio.
Have a professional do the swap.
Richmond Ring and Pinion Bearing Set - RMG - 831D401
Motive Gear Performance 3:36 Ring and Pinion Bearing Set - G882336
Auburn Limited Slip HPS Limited Slip Unit - Sorry but I can't find the part number.
National Bearings Axle Bearings - RW-507-GR, and Seals - 85945 You'll have the axles out so change them.
Valvoline 85W-140 Limited Slip Gear Oil
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 02-12-2018, 02:49 PM
Which rear used 30 spline axles?
Old 02-14-2018, 04:53 PM
vidguy's Avatar
vidguy vidguy is offline
I just went the other way for the fun of it. I never drive the car long distances any longer.
I removed a 2:73 Olds "O" type 8.5 Posi for 3:42's in the same housing.
I will say that the old 400 in the GTO had no issues with the Spin and Grin factor even with the 2:73's
I'd run them again.
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
Old 02-14-2018, 05:59 PM
Talking 2.93
I'd run them again.
I have fantasies of taking my ride on rte 66 cross country when its finished.....previously when my car was on the road I couldn't go 50 miles w/o a cooling problem....I tried every trick in the book to solve....the final diagnosas was burnt up bearings which required a new block...so ten years, an unscrupulous restorer, and two financial crises later, ive got my car back and intend to have it on the road this summer...good luck to me!!!
Old 02-14-2018, 10:36 PM
fyrffytr1's Avatar
Welcome to the forums. I am basically finished with a 7 year restoration but for the posi-traction. Start a thread and post up some pics of your ride.
Old 02-18-2018, 10:53 PM
ReelFun's Avatar
ReelFun ReelFun is offline
Not trying to hijack the thread but I would like a little education. Can someone post a photo of a "carrier"? Is that the ring and pinion housing? In other words , if I hada 2.93 rear end and wanted to make it a 3.55 what would I need to change or could I change that rear end to a 3.55? Just trying to learn here.
1965 GTO
389 Tri-Power
4-Speed
Johnny
Old 02-19-2018, 12:50 PM
gtospieg gtospieg is offline
You would need to change the carrier to a "3" series...the carrier is the chunk that actually holds the ring gear, clutches, bearings, etc.(and bolts in to the rearend housing) Hope that helps.
Old 02-19-2018, 10:05 PM
ReelFun's Avatar
So the housing would work I would just bascially be changing the internals in the "pumpkin"?
1965 GTO
389 Tri-Power
4-Speed
Johnny
Old 02-19-2018, 10:11 PM
Correct...
Old 02-19-2018, 10:29 PM
ReelFun's Avatar
Thanks. Not planning on changing anything now, just trying yo learn.
1965 GTO
389 Tri-Power
4-Speed
Johnny
