And, what size tubes for D-port? |
There is no doubt that with lower compression numbers and the lower cylinder pressure numbers that is made that you want as little back pressure as possible to impede the Exh gases/ pressure from getting out of the cylinder.
In light of this I agree with the statement that with motors under 9.2 to 1 you need a good flowing Exh system more and more as your compression sinks!
Well, if you are going to produce a tri y, will one be made for a 71GTO 455 with round port heads, P/S and A/C? I would be VERY interested!!!!!!
Great info on headers vs ram air manifold and good down pipes.
http://www.hotrod.com/articles/hppp-...-vs-manifolds/
1979 Trans Am 307 RWHP 380RWTQ 13.8@103 1979 400 Block, 1970 Heads, Unknown Cam, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base SOLD 1968 GTO convertable project. 400 auto with air. west coast car . Not started in 15 ..update now running (around block spinning tires all the way. Have a lot of cosmetic work to do winter of 17/18 1969 GTO 400 4 Speed this a complete project. Rebuild will start in spring of 2017. SOLD |
Hey Lee, what cam are you using? I see the basic numbers but wanted to know which cam. I am putting together a low compression 455, I was going to use the Ram Air manifolds, now you have me thinking that, maybe I should use my Tri-Ys. Didn't realize low compression motor could take advantage of the headers.
Although I designed the cam with the use of headers intended, my software doesn't have a function to simulate tri-Y headers, so this was a bit of a leap of faith for me. I had to enter data like it was a 4-tube design, and it came pretty close. The software predicts flywheel numbers, so they are higher than the numbers obtained on the chassis dyno. I've told a few people that the simulations usually show the rpm to be a bit higher than what is actually measured, but the overall curves tend to be rather accurate. Anyway, here are pictures of the actual chassis dyno results (also shown in the original post) along with the curves predicted by the software (comparing 1.75" headers to log manifolds with a more restrictive exhaust).
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
and Larry, any chance for a d-port set for '69-'72 GP?
'70 GP Model J 462 Butler ported 87cc Edelbrock D-ports RPM intake with Holley Sniper 2 CompCams 236/242 hydraulic roller Tribal Tubes tri-y headers TH400 13" Continental "Jim Hand Special" 3.50 9" CurrieTrac, 245/45-18 Front, 275/40-18 Rear |
I've known Larry for about 20 years, and if he brings a header (or ANY product) to the market, then I'm sure he is going to put a lot of effort into it, as he has done with his other WFO products. But please, contact him directly
I conducted my own testing, on my own dime, with nobody looking over my shoulder, and nobody knowing the results until I shared them with everyone. If the headers had lost 5hp, I would have reported that as well. Honestly I've always been a bit dubious about tri-Y designs, and this test was partially to satisfy my own curiosity.
I currently own EA Plus, EA Pro and Dynomation 6 EAPlus loves crazy long exhaust duration. Notice the low end difference 3000 to 3500 RPM - chasis dyno vs sim. Crying for a 3500 stall converter. Last edited by pastry_chef; 12-12-2017 at 10:53 PM. |
We've seen improvements near 40hp just from going from one brand of header to another both with the same tube and collector size, but this was on a big CID engine making over 650hp. So for sure how well the headers are made and basic design/construction play a big role with these things.
There are also BIG gains to be had with head pipes and using "X" and "H" pipes before the mufflers. The big CID Pontiac engines for sure respond very well to larger head pipes after the manifolds or headers. The drag strip has shown us a much as .2 and 2mph going from non-mandrel bent 2.5" head pipes with an "H" to mandrel bent 3" pipes with an "H". This doesn't look like much on paper but a pretty significant improvement in terms of power produced in the loaded rpm range.......Cliff
Hey Lee, I have some 4 tube headers pulled off a 76 T\A, it would be cool to test a set of 4 tubes to see what if any difference there would be. Also have a set of ram air manifolds that I would lend to the cause. Not sure if you are that curious to do all that work just offering as it would be cool for the Pontiac world
With a stock torque converter, street traction is minimal as is! Grin, I appreciate the offer! Skip and Larry N. have made similar offers. Maybe with the next motor, down the road. I've got an appointment to have the pipes and mufflers all changed out next week. All 3", Borla ProXS mufflers, and mandrel-bent 3" tailpipes (from Steve C's old system, thanks Steve!).
Is the current 2 1/2 inch exhaust dual mufflers? H pipe? X pipe? Transverse muffler?
You might see another nice boost in power with that upgrade. Look forward to your results. |
I may add a Dr. Gas X at a later time.
Swapping headers for testing is not easy. If it were it would be of interest to see testing with my old 1-7/8" headers that Lee now has on hand. If memory serves me right Lee is saving them for a future higher HP combo but to see the impact on 'bigger' headers here would be of interest.
#38
wow interesting thread;
I found B-man's post (#10) to be the most interesting so far!
#39
I looked at a set of 67 manifolds I have, and I notice what you're talking about. For my next build with factory manifolds, I will certainly install the older, "better breathing" ones.
Eric "Todd" Mitten '74 Bonneville 4dr Sedan (455/TH400/2.93 open) '72 LeMans GT (455/M-13/3.23 [8.5"] posi) '71 GTO Hardtop (400/TH400/3.07 12 bolt posi) ‘71 GTO Convertible (455HO/TH400/3.23 posi) '67 GTO Coupe (455/ST-10/2.93 posi) '67 Tempest Wagon (428/TH400/2.56 posi) Deuteronomy 8:3 |
#40
I appreciate the endorsement Lee and Steve.
Guys, I will gladly entertain other models....IF and only IF I can efficiently and effectively make a buck for my efforts with the 2nd gen crowd. This is my target and largest market for the product as most everyone has modified suspensions where ground clearance is at a premium when considering exhaust systems. I can not speculate on a retail price, hopefully I can have a cost figure based on utilizing premium materials and offering top quality craftsmanship.
Home of WFO Hyperformance Shaker induction. |
