Old 10-30-2017, 02:38 AM
NeighborsComplaint's Avatar
FYI stock initial timing on a YC 455 is 12 degrees.
Old 10-30-2017, 09:27 PM
Stuckinda60s Stuckinda60s is offline
Originally Posted by 360Rocket View Post
I think you did great Murf, you can never get too much input. Lemme go see if I can spot that code. It looks like a "YC" It has 455 on the bottom side of the block..
Stuck....I actually slipped in engine size in post #12...lol.
Yeah, I had seen that you posted the engine size, but I've also seen more than my share of 350's represented as 455's That includes one that a forum member recently posted about that he had bought as a 455 and driven for some time before he found out the truth.
But, that wasn't the issue. If we knew the engine code, we could, as you've seen from NeighborsComplaint, determine what initial timing is supposed to be.
Rich
The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance.
Henry Ward Beecher
"The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher
Old 02-10-2018, 12:06 AM
360Rocket's Avatar
360Rocket 360Rocket is offline
So maybe another tuning lesson learned? I'll ask you guys opinion first. So I've fought and I've fought, and I've fought with the carb/timing issue for far too long and I figure I'm fixated on one thing while the issue is quite something else so I decide to wave the white flag and get a fresh set of eyes on this tuning issue and I take the GTO to my local speed shop to have a pro give it a once over. So he pulls out a modern fancy star trek looking timing gun with LED readouts and dials and whistles on it and proceeds to show me that what I thought was 14 degrees of timing was actually set at 21 degrees of initial timing and 41 degrees of total timing. wow so in your opinion are my eyes that bad? or could there be a 6 degree difference between 2 different timing lights? The ride on the way home says thru the butt dyno that I picked up 50 HP with zero pinging and a much less strenuous sound coming from the starter on hot restarts. I still have some idle and off idle carb issues but that might have lead to a suspect PCV valve that I plan on replacing when I get back to work on Monday. Do I reserve trust in my trusty timing light? Or is a new set of contacts in order? 14 degrees is only 2 degrees off my timing tab so I don't think I could have been that far off, whats your thoughts?
