Im not understanding what you're asking. Similar to what?
Im getting the reading 12 inches from the A/R flange
My Half AN Injun..... |
Oh you meant the gage? Lol.
I use my fuel injection for air temp... I just found that for you to help you find one...
what location are you reading your intake air temperatures?
Whitmore 462, 670 heads 10.55@125 Same with 310 E D-ports 10.12@131 498 w/single 88 8.53@158 |
Right before the throttle body . But next time im locating it in the plenum..
My air temp sensor is in the carb hat, and I have a carb style throttle body.
George you plumbing welding is beautiful.
I want to try it down in the plenum because I've always wondered if being its more closer to the head and basically inside the motor ,if it heats up at that point away from where its at now and if it does I'd rather know an tune to what temp the motor really sees....
Thanks rohrt, wish I could take credit for it though. Nathan Shaw from One Guys Garage handled my hot side work. http://www.one-guys-garage.com/
Thanks guys, I'm going to see if I can get something set up before the next race and try to get some IAT data.
Here's a video I took some year back... about 20lbs, ethanol, sensor in the manifold, about 1/2 the fuel through the injector hat and half in the port - the port fuel being after the sensor. This was a cheapie sensor/gauge package that I'd guess wouldn't react quickly to changing conditions, but my take away was temps were dropping under load during the pass. Speaks to the cooling effect of the fuel. This was with a GoPro - don't get too much vibration with them in my experience.
https://m.youtube.com/watch?v=CqQQF-4Vwyc
The secret to happiness is not getting what you want but rather, wanting what you have. |
Wow, interesting video.
I also got a chance to check back pressure using an old fuel pressure gauge. Was at 13psi on 6 pounds boost and 17psi on 10 pounds of boost. Not sure what that tells me but there it is.
Talk to Mike and Eric. They can explain it to you. Good info though.
Worth doing the test, George. Tom V.
