Old 04-25-2017, 04:28 PM
74 SD455 Formula 74 SD455 Formula is offline
Originally Posted by SD Formula View Post
Here's a piece that was hard to find.
I had a couple of those. I only have the one NOS one for my car left. I'm in need of a coil and bracket for my Distributor if you have an extra you'd like to sell.
Old 04-25-2017, 07:01 PM
SD Formula's Avatar
SD Formula SD Formula is offline
Like this?
When removing an unreplaceable washer, the part will be heard hitting the floor and then vanish from the face of the earth!
Old 04-26-2017, 04:52 PM
Like this?
Yep, Thats what I need as well as a coil. Not going to install them,just want them for when i sell the car some day the new owner can put them on if he wants. If your wondering I have an old Mallory set up in my car now with the coil hidden under the dash inside the car.Keeps the originallity or appearance looking as it should.Mine is still a survivor with 50K miles.
Old 04-26-2017, 09:01 PM
SD Formula's Avatar
I'll look through my stuff, I used to have a coil bracket off of a 74 Formula 400 two barrel. Pretty sure it would be the same. Have a bunch of coils, mostly Chevrolet 087, 202, 174, etc. Not sure what # they were for 1974. Enlighten me?
Old 04-27-2017, 10:42 AM
Interceptor's Avatar
Interceptor Interceptor is offline
Well this is pretty cool. What are production numbers on the SD Formula? I thought it was 0 ...
70 GTO Restomod -- 400/200-4r, nothing to see here
70 Firebird -- 455/400
69 Mach 1 -- 390-C6
07 Escalade EXT
Old 04-27-2017, 11:11 AM
njsteve's Avatar
njsteve njsteve is offline
SD455 Formulas: 43 in 1973 and 58 in 1974.
Old 04-27-2017, 09:42 PM
Held for Ransom's Avatar
http://www.forums.maxperformanceinc....d.php?t=687163
'432'.
Old 04-28-2017, 06:06 AM
SD Formula's Avatar
Don't have a 432.
Old 04-29-2017, 06:20 AM
SD Formula's Avatar
I've been following OVERLUD work on his 74 Formula and like his process & the way he is presenting information to the forum. With that in mind I'll use his abbreviation, and will refer to my resto guy as MFG My Friend Gil.
MFG will start work on my SD Formula on or about June 1st when he finishes his current project a 67 sb Corvette convertible. As I may have mentioned earlier this is an amature restoration project, started by me approximatelt 15 years ago, that has been setting for far to long.
The engine has been rebuilt with some modifications, the body is on a rotisserie, stripped with most body work completed. Many of the sub-assembly are completed. Most of the digital pictures have been lost. With that in mind. I'm trying to bring MFG up to date so he can get started.
So yerterday I started taking parts an assemblies to MFG's shop.
A re-skinned door.
Old 04-29-2017, 07:21 AM
SD Formula's Avatar
A mostly completed semi gloss black powder coated rear bumper assembly.
ID:	453341   Click image for larger version
Old 04-29-2017, 07:51 AM
SD Formula's Avatar
So yesterday started taking parts an assemblies to MFG's shop.
A re-skinned door.
Here's the paint I used & plan on using on the underbody & interior.
Old 04-30-2017, 10:01 PM
OVERULD's Avatar
OVERULD OVERULD is offline
If we're not careful, MPD, MPR and MFG are going to start comparing notes and the price per day will go up to two beers...and a dang bag of peanuts !
BJ
Old 05-01-2017, 06:10 AM
Judge273's Avatar
Judge273 Judge273 is online now
Well, I can tell you My Aching Back (MAB) is happy to have a job....I'm not doing a concourse restoration. Doing my 71 TA for my wife and to see what it takes.
But, this one sounds like a good candidate..Hats off to those concourse restorations!
Mike/Illinois
Old 05-02-2017, 10:47 PM
OVERULD's Avatar
I hear you Mike! You're taking yours to a different level than I'm taking mine, but still, there is a lot of detail work that never seems to end. Looking forward to the day I can just get in, crank it and feel the smile creeping across my face as I hear it, feel it and reailize that my hands had a part in bringing it to the point where everything works as it should and it will be a fun ride to whatever event I'm headed to. Raising a glass of Bourbon to all who dedicate their time and effort to keeping the Pontiac Brand alive and well! Cheers!
BJ
Old 05-04-2017, 09:39 PM
SD Formula's Avatar
Thanks for the comments guys! More boring pictures until MFG starts the project.
ID:	453821   Click image for larger version
ID:	453822   Click image for larger version
Old 05-04-2017, 09:49 PM
SD Formula's Avatar
More
Name:	2017-05-04 21.27.38.jpg
ID:	453827   Click image for larger version
Old 05-04-2017, 10:07 PM
SD Formula's Avatar
[QUOTE=SD Formula;5734942]More[/QUOTEthese markings look correct?
Name:	Glens Data 133 (0).jpg
  #38
Old 05-05-2017, 02:01 PM
Norwood's Avatar
Norwood Norwood is offline
This is what the hood latch should look like
  #39
Old 05-05-2017, 04:27 PM
SD Formula, what is your 6 digit number on the bottom of the trim tag (70xxxx???)?
  #40
Old 05-05-2017, 04:55 PM
SD Formula's Avatar
Looks like 700089, Why?
