Crower 68404 springs will install with stock retainers and allow lifts up to around .540" (double check me on that). Of course, if you swap everything from the 62s then no worries.
I would run a modern cam profile with a tighter lobe separation than the 068. The 068 is pretty mild and is really designed for high compression engines. It works well in 455s with low compression but it will have a soggy bottom in a 400. I like Squidward's rec. for the Lunati. Also, the Summit 2801 would be a good budget choice.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
OK, a more modern cam sounds like the way to go. |
how many valve reliefs do your pistons have?
I no longer have that beautiful 66 in my Avatar. whaaa! When a cat is dropped it always lands on its feet. When buttered toast is dropped it always lands with the buttered side facing down. If a piece of buttered toast was attached to the back of a cat, when dropped, the cat/buttered toast combination should hover, spinning just above the ground, as it tries unsuccessfully to resolve the inevitable conflict of non-scientific certainties. |
4, they are TRW 2262's.
65 Tempest, 400, TH400 86 Fiero SE 2.8 |
thanks. i was going to lurk if they were the same as my detonation prone 8s.
Why not use a set of Rhoads lifters ? It will keep things mild until you stomp on it, then they bring the cam to its potential.
Denn die toten reiten schnell More doors = more love! |
I was thinking Rhodes might be an option but not sure about the noise level. I do have Crane's version- High Intensity that date to around 87, they are NOS but haven't read much about how well they perform. It would save me the hassle of ripping the front of the engine off. Never considered using them with the 62's as I am sure denotation would be worse.
