Old 08-07-2016, 07:21 PM
Tom Vaught's Avatar
Boost Engineer
Sounded great with the new block installed in the car and ran very well.
Amazing how well those guys can recover from a bad engine deal quickly.
Tom V.
Old 08-07-2016, 07:44 PM
Elarson's Avatar
Elarson Elarson is offline
Time slip
Eric
Old 08-07-2016, 08:09 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Dang!! Almost a sub-one second 60-foot! How many G's were you pulling?
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 08-07-2016, 08:21 PM
Scott Roberts Scott Roberts is offline
Not sure if its different for fuel cars but we were getting .96- .97 60ft. If Eric can get the 60ft down he is The re. It's pulling very hard on the high end for sure... I assume its in the clutch set up..
Old 08-07-2016, 08:22 PM
Elarson's Avatar
Don't know.....no G-meter in car.
Eric
Old 08-07-2016, 08:23 PM
Elarson's Avatar
Definitely more left in the package.
Eric
Old 08-07-2016, 08:30 PM
Half-Inch Stud's Avatar
Wow! crispy soundtrack too
Old 08-07-2016, 08:40 PM
360Rocket's Avatar
360Rocket 360Rocket is offline
man that is just too cool for school....to hell with being a fighter pilot, Git you summa that!!!
Old 08-07-2016, 08:58 PM
67GTO4SPEED's Avatar
67GTO4SPEED 67GTO4SPEED is offline
Eric
'67 GTO 400 HO - Ram Air - 4 speed - 3.55 Safe T Track, A/C, PS, red fender liners
'78 Lemans - Drag car project
Old 08-07-2016, 09:36 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Congrats on the pass. Hard work and dedication right there!!
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046 jet
First ultra street/ultimate street NOS car to get into the 4's!
1.079 4.559 153.23.
3100 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
T2TTFMF!
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 08-07-2016, 09:37 PM
mgarblik mgarblik is offline
Back home from the Norwalk event. Obviously, we are happy with the performance of the Boss Bird. Friday started out with a fairly heavy load of chaos as some who were there observed. First warm-up on nitro the engine sounded lousy, would not idle and had crazy variations in exhaust temperatures and a dead #7 cylinder. We worked late into the evening and corrected all the issues. Dead #7 was a damaged exhaust push rod and broken exhaust rocker arm adjuster as well as stretched attaching bolts to the Jesel bar. We had just enough parts to fix all this stuff. The new valve springs, although we think they are working great are really stressing the Jesel bar and fasteners. They are working loose every time we run the engine. 450 lb. seat pressure and 1120 lb. open are really punishing these parts. The rest of the issues were all related to our previous blower explosion. The manifold top had twisted and bowed creating vacuum leaks we couldn't detect on alcohol but showed up right away on nitro. Lots of new gaskets and RTV solved the issues at least for this week. The rest of the event, the engine, driver, crew and everything on the car was flawless.
It was nice to see and talk to many of you on the forum. If I seemed distracted or not able stay with every conversation, I apologize. It's hard to stay focused on my #1 job which is to keep Eric safe. I have various lists I work off of and my crew only work together 3-4 times a year so we have to constantly cross-check each other to make sure everything gets done. It was great to have a chance to actually watch some racing Saturday night for the first time in years. Seeing and touching Jack's DOHC Mickey Thompson block land speed record engine was really special. It's incredible and I will post some pic's soon. Arnie Beswick was at the line for both runs of our car and was pleased with the performance. He can be a harsh critic. He said it sounded great and was all smiles. I will be removing the engine for complete teardown and inspection in the next few weeks.
I have to mention that All Pontiac went to extraordinary lengths to provide a reinforced solid aluminum engine block for us. This is no small project. In less than 1 year this block went from a conversation to a running engine in a nitro funny car. Think about that. Work done in Virginia, Arizona, Michigan and California. Blueprints, pattern changes, special fasteners, special aluminum alloy, special post casting processing, HIP process, special machining operations. All done to provide a really strong aluminum block we and others can afford. When that block showed-up I was determined to have it ready for Norwalk, no matter what. Look forward to developing it further.
Old 08-07-2016, 09:41 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
Felt awesome!
Eric
Outstanding run, congrats! This was the last run my brother and I watched before heading home!
Old 08-07-2016, 09:50 PM
mike leech's Avatar
mike leech mike leech is offline
Great job guys!
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
Old 08-07-2016, 10:30 PM
catc's Avatar
catc catc is offline
WOW!!! Congratulations...sounds wicked......that was a great run....
Old 08-07-2016, 10:35 PM
Rock C Rock C is offline
wow great run congrats
Old 08-07-2016, 10:42 PM
Elarson's Avatar
Originally Posted by Steve Barcak View Post
Congrats to Mike and Eric. Well done
Wish you could have been there. Your work with nitro in the Pontiac engine gave us a shot of courage to jump in ourselves.
Eric
Old 08-07-2016, 11:13 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Wayta' hang in there guys and get a little gravy for all the hard work/$/time involved.
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
  #38
Old 08-08-2016, 12:08 AM
slowbird's Avatar
slowbird slowbird is offline
Man i missed the run (i was next pair out) but it sounded awesome!
  #39
Old 08-08-2016, 12:53 AM
Mikes455Wagon's Avatar
Mikes455Wagon Mikes455Wagon is offline
Congrats guys! It always feels good when lots of hard work pays off me things go right! 231 out the back is moving!
  #40
Old 08-08-2016, 02:02 AM
Old Man Taylor's Avatar
Fantastic!!!!
