Old 06-09-2016, 05:10 AM
TransAmRIP's Avatar
TransAmRIP TransAmRIP is offline
Originally Posted by dpoltzer View Post
I believe they were left natural by Pontiac but I always re-spray these in cast iron gray which I think looks very nice. I never cared for them when some guys paint them black. Keep up the nice work!
Ok thanks, I think I'll do that.
And thanks for the kind words.
Bub
Old 06-11-2016, 07:12 PM
TransAmRIP's Avatar
Anyone else see the copper in the stabilizer drop down?
ID:	430532   Click image for larger version
Old 06-13-2016, 08:20 AM
superdutybob's Avatar
superdutybob superdutybob is offline
Typical look of an induction brazed part Bub!
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
Old 06-13-2016, 09:04 AM
TransAmRIP's Avatar
Old 09-25-2016, 01:32 AM
TransAmRIP's Avatar
Been awhile since I last posted updates on my 75 rest. I separated the front suspension, upper and lower control arms, spindles, and I also decided to do the drive shaft while I had it off. Sanded, wire wheeled, sand blasted you name I did it. My wife also got into the mix. She removed all the undercoating in the rear wheel wells with the air needle scaler from Harbor Freight. The last picture is the outcome of the needle scaler after removing the undercoating.
I tried to upload the video, it wouldn't load.
Bub
ID:	437294   Click image for larger version
ID:	437295   Click image for larger version
ID:	437296   Click image for larger version
ID:	437297   Click image for larger version
Old 09-25-2016, 01:43 AM
TransAmRIP's Avatar
more pictures...
ID:	437299   Click image for larger version
ID:	437300   Click image for larger version
ID:	437301   Click image for larger version
ID:	437302   Click image for larger version
Old 09-25-2016, 04:43 PM
Just some FYI, they make some bolts that have a stud type of head so it looks like the ball joints are original looking from the factory. I think you can get them from Inline Tube.
Old 09-25-2016, 05:03 PM
TransAmRIP's Avatar
Thanks for that info, I'll check into it.
Old 09-25-2016, 06:22 PM
TransAmRIP's Avatar
Yep, Inline tube sells them. I couldn' find them on the websight but found them on there ebay accout. $18.00 plus 2.75 shipping.
Thanks rexs73gto
ID:	437327   Click image for larger version
Old 09-26-2016, 06:56 PM
TransAmRIP's Avatar
My office is full of restored and painted parts. Keeping them in a safe place.
Old 09-26-2016, 07:08 PM
TransAmRIP's Avatar
Painted the yellow stripes on the drive shaft. I even posted pictures of the width of the stripes and the distance between them in case someone else needs the info.
Bub
ID:	437436   Click image for larger version
ID:	437437   Click image for larger version
ID:	437438   Click image for larger version
ID:	437439   Click image for larger version
Old 09-26-2016, 07:13 PM
TransAmRIP's Avatar
What color should i paint the yokes on the drive shaft? Steel color or Cast iron color?
Old 09-27-2016, 05:48 AM
ladytata's Avatar
ladytata ladytata is offline
Wow, your going all out. Awesome. My last 2 parts cars were 75, have some things left if you need something.
Old 09-28-2016, 11:54 AM
TransAmRIP's Avatar
I probably will need something. I'll let you know.....
Old 09-29-2016, 12:19 PM
TransAmRIP's Avatar
Competed rear stabilizer bar and drop down links. Also complete all of the control arms. Just a picture of the rear of the car how rust free this whole project has been.
ID:	437613   Click image for larger version
ID:	437614   Click image for larger version
Old 10-03-2016, 11:17 PM
TransAmRIP's Avatar
Received my rivet looking bolts for the upper control arm ball joints. You can see in the picture what the rivet/bolts look like vs the bolts supplied with the ball joints. Neat item.
Bub
Name:	2016-10-03 22.15.44.jpg
Old 10-04-2016, 12:04 AM
The new rivet top bolts look great . I'm glad I could help with that. Your going all out with it so theres no reason not to have the almost correct parts on the ball joints for you. They look great & your effort will not go unnoticed when you have it out to a good show. It not the big stuff the judges look at but the littles extra efforts you do to make it correct.
  #38
Old 10-17-2016, 10:06 PM
TransAmRIP's Avatar
Thanks for the info on the rivet look.
More progress to share. Completed the install on the drum brake assembly. More to come....
  #39
Old 10-28-2016, 06:26 PM
TransAmRIP's Avatar
Partial front suspension completed.
ID:	439588   Click image for larger version
ID:	439589   Click image for larger version
ID:	439590   Click image for larger version
  #40
Old 10-29-2016, 06:33 PM
TransAmRIP's Avatar
New bearings, rotors, brakes installed.
ID:	439667   Click image for larger version
ID:	439668   Click image for larger version
ID:	439669   Click image for larger version
