73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 07-22-2015, 12:15 PM
sdx455's Avatar
sdx455 sdx455 is offline
I don't have these on the water pump neck or the intake where the bracket attach. when I disconnected the brackets from alt . the back bracket pulled away about 1" from the alt.
73 GTO 455 TKO 600 3.90
Old 08-01-2015, 01:14 PM
Alvin's Avatar
Alvin Alvin is offline
Did install of those "stud bolts" correct your alignment problem?
Old 08-01-2015, 02:49 PM
Alvin's Avatar
From John @ Wallace Racing website below
John, do you have the same for 1973 Alternator mount?
johnta1 wrote See if these work:
73 Alternator mount
1973 80 amp alternator mount
These are for use with power steering, but the pump isn't shown.
Original reply to thread post #8 here http://forums.maxperformanceinc.com/...=1#post5441692
Thx again John for the assist
Edit: Wallace Racing Pontiac website link http://wallaceracing.com
Old 08-02-2015, 12:02 AM
Looking at your pic of the alt. it looks like the belt is sitting at a slight angle as it comes up on the right side of the pulley. It looks as though the belt is running crooked from right. Make sure the belt is running straight or it will keep blowing off. Make sure all the pulleys are sitting on there parts correct to. If the pulley isn't sitting on the water pump straight it will pull the belt off to. Yes you can have the pulley crooked on the water pump if you didn't tighten it down the same on all the bolts. But still the belt looks to be running crooked on the water pump pulley to me.
Old 08-06-2015, 05:07 PM
sdx455's Avatar
Any one know the length of part#4 spacer, mine was not original piece it was the from help section
Old 08-06-2015, 08:59 PM
3 7/16" I think?
(from a MPC book, from a quick look)
