Here was my solution to avoid stock/solid/plate mounts.
Polyurethane to dampen vibration and a captured bolt to keep the engine from going anywhere if the poly failed. That said, build at your own risk. My car is in the body shop & these are untested so they may be total crap, but I think the theory is solid. Speargun's homemade engine mounts
No! Do not try! Do! Or do not. There is no try. - Yoda 1967 Firebird Restoration 2005 - 1/25/2017 |
Your cam, on the other hand.........
Yea cam is 277/288@50 with 485/471 lobes with 1.65 harland sharp rockers which everyone says they actually measure out more so ya can do the math lol
I cracked my 455 block while using solid mounts went to motor plates and no problems with block cracking anyway!
Gene Kinch 1969 firebird CVMS 468,t-400,9inch 3.50 rear 11.58@116 1979 TA 462,t-400 3.23 10 bolt 12.76 @ 108 1971 GTO 400,t400 3.23 10 bolt all original 14.41@96 1968 GTO Gallop-n-Goat race car CVMS 462,pg 4.56 12 bolt eheads 5.98 @115 on e85 1995 Jerry bickel ex-pro stock Firebird,sonny leonard 632,Glide,9 inch 4.10 rear 7.08 @198 ( crashed and under reconstuction) 1979 TA, 400/ 4 speed all original needs restoration. 1999 Trans Am LS1 |
Under 1.4 60's would be awesome.
If I can get motivated to put my car(65GTO) back together, I would like to replace the solid mounts with a Mid plate and some "ears" on the front.I would like to use aluminum for the plates/ears and have the attachment brackets on the frame welded on. Any suggestions? Other mods are 5,000rpm 8"COAN, little bigger cam and 200lb diet.
PHILLYGOAT 1965 GTO/ OEM Block, Crank & D-ports(all slightly modified of course)/ 3550lbs/ Full Exhaust/ Foot Braking 1.41 60ft 6.45@104.97mph 10.25@127.12mph(Pontiac Heaven) More Details on GOAT http://www.pontiaczone.com/forum/vbpicgallery.php?do=view&g=379 GTO Burnout http://www.youtube.com/watch?v=nZqdcH0Ltc4 |
Nice to see you here Phil!!
Jack Ferris RestoRacing LLC www.restoracing.com Sandy, UT --------------------------------------------------- |
The more power you make the more stress you exert on the block at motor mount pad. Just saying. At least run a front plate.
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
What we did on the '78 with front and mid plate.
Why couldn't you run a front plate and mid plate and use a solid motor mount as a limiter?
Either a solid mount on one side or both sides.
"Artificial intelligence is no match for natural stupidity". 1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph 1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.56 139mph |
Does anyone else use a limiter on both sides? I just have one on the passenger side and thought that was sufficient.
Hi Jack! Thought if I got involved in posting it would probably get the juices flowing.
Now, back to the thread!
