Old 01-14-2015, 12:00 PM
69goatboy's Avatar
69goatboy 69goatboy is offline
Originally Posted by 68azbird View Post
When I get the chance to jump back into it I'm pretty sure there's a format conversion to convert from ACAD to solidworks or pro e.
After I get all the views done in AUTOCAD I can print it out with the dimensions and do a QC check to make sure it's 100% accurate.
If it was done in 3D, simply save as a .stp file.
SW, SE, Inventor, Pro-E, etc.. all can read a step file.
If it's a 2D file, send it to me and I'll see if I can make it a 3D one.
I work in 3D (Inventor) all day long.
The joker in the deck keeps sending me his card.
Smiling friendly, he takes me in.
Then breaks my back in a game I can't win.
Old 01-14-2015, 12:04 PM
You can export just about any 3D CAD model as a igs file, which can be opened in anything. The only problem is they lose their history.
Old 01-14-2015, 01:40 PM
Captainofiron's Avatar
Captainofiron Captainofiron is offline
ProE will open autocad drawings, then you just need to save it as a ProE drawing (.dwg) and then open a 3d part file and import the sketch to extrude it.
It sounds more complicated than it is
www.fquick.com/Captainofiron
68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4
97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil
14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires
Old 01-14-2015, 03:13 PM
dm_fan's Avatar
dm_fan dm_fan is offline
Administrator
I wonder what is would cost to send the file to a company with a 3D printer to have a model made.
You could have a life size (or I'd imagine smaller sizes could be printed) model of a Pontiac V8 block in a few hours.
"No you fool, we're following orders. We were told to comb the desert so we're combing it."
Old 01-14-2015, 03:42 PM
a guy I am doing some contract CAD work for has a really nice ABS printer, not sure how much the material costs would be, but the last piece I designed for him took 6 hours, and it was an AR15 grip
I think he said his printer will print 24" by 24" by 24" models
that would be pretty big, I bet you could even do sections of the full size model and glue them together
Old 01-14-2015, 05:58 PM
Alvin's Avatar
Alvin Alvin is offline
Lightbulb
My vote is for PY to be "THE" distributor for the 1:1 and 1:4 scale version of various Pontiac engine models. What would it take to make that happen?
Had this Classic Visible V-8 motorized version as a kid and have this current version unbuilt in our SWAG now. Including this for some of the younger crowd who may not know about these.
Regarding the static Pontiac engines - how about a few versions such as Tri-Power 389/421SD, RAIV, 455 HO/SD, W72 T/A 6.6, etc. with the Shakers/Trips etc. available
Old 01-14-2015, 06:35 PM
+1
that model kinda looks like a SBC Pontiac hybrid with the water pump and heads
Dick Boneske's Avatar
Post #2--Excellent picture of a '64 GTO 348 HP 389!! I've never seen this before. Is there somewhere we could get a high resolution source for this?
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 01-14-2015, 06:45 PM
Alvin's Avatar
Yes here you go http://www.hotrod.com/features/histo...nt-pontiac-v8/ from High Performance Pontiac
Old 01-15-2015, 10:57 AM
68azbird 68azbird is offline
I can make a mold of a 1:1 scale engine in far less time and cost than the whole 3D printing process.
Old 01-15-2015, 10:59 AM
GRX's Avatar
GRX GRX is offline
Check this out
HERE
Good one. That reminds me of the cutaway engine they had made when I worked for CAT to display the internals of the 3408 twin turbo v-8. It was very satisfying to watch an engine which you had just machined & built put out 2k horses at 2k rpm in the run in room for 2 days straight.
1969 GTO hard top ~ Std bore 400, '70-RA3 block, 670 heads, Bal. & Blue... M22, 12-bolt w/3:55s
Old 01-15-2015, 12:42 PM
yea right now 3D printing is good for really intricate designs, but mostly used for prototyping and then sending the prototype to get cast like 68azbird is saying
I could see it being good later on when metallic 3D printing become more mature, as you could make engine blocks and heads easily as you could just print in the cooling/oil passages with no need to get rid of the internal mold (sand or wax)
Old 01-15-2015, 10:06 PM
fiedlerh's Avatar
fiedlerh fiedlerh is offline
Large format 3D printing is very expensive. I had a hollow part printed about the size of my fist and the material cost alone was $72. This was high resolution photopolymer powder. The printers using "string trimmer line" (not really but it looks like it) are cheaper, but the model is very coarse and porous.
http://www.pontiacpower.org/
Old 01-16-2015, 03:53 PM
a 3d printed accurate Pontiac v8? What size will it be? I'd buy one in a minute
Old 01-16-2015, 04:03 PM
Alvin's Avatar
Default Pontiac version needed
Plastic replica engines http://pitstopusa.com/b-4707-p-ayr-products.html
SBC for fitting http://pitstopusa.com/c-133030-engin...a-engines.html
Old 01-22-2015, 06:35 PM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
I uploaded a couple of models to grabcad this week.. just look up recent "pontiac" models.
Kris.
*** THE BIG BRACE is here ***
Old 01-22-2015, 11:00 PM
Alvin's Avatar
Kris.
Which ones are yours Kris? http://grabcad.com/library/recently-...query=Pontiac+
  #38
Old 01-23-2015, 02:40 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
captainofiron- I've got Pontiac V8 cylinder deck dimensioned drawings sourced from Cometic. As near as I can tell, they are accurate (bore centers, head studs, and dowel pin locations). If you PM me a mailing address, I'll send you a copy (two pages).
  #39
Old 01-23-2015, 10:37 AM
Here's one:
Exhaust flange
Hover over the pics and they show the author name.
Or in the link I sent, it lists his other stuff.
  #40
Old 01-23-2015, 11:42 AM
2manyponchos's Avatar
2manyponchos 2manyponchos is offline
Anyone here have familiarization with programs like Geomagic or those that can convert a 3D scan into a useable solid model? I have a 3D scan of an original RAV head that I tried to have our master CAD modelers convert, but they keep having difficulties in the version of Geomagic that we have. Willing to pass along the scan if anyone has the capability.
P.O.S.I - It's not just a club...it's an addiction!
