Old 10-19-2014, 11:24 PM
bad69bird's Avatar
bad69bird bad69bird is offline
Congrats Kelvin! Good luck with it!
Here's his pic...
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs)
Old 10-19-2014, 11:36 PM
Kelvin Poe's Avatar
Kelvin Poe Kelvin Poe is offline
[QUOTE=bad69bird;5290200]Congrats Kelvin! Good luck with it!
Thanks, and thanks for enlarging the pic.
'70 Trans Am, full tube chassis, 2360 lbs., IAII Aluminum 529ci, CV-1 Heads - N/A - Best 1/8 mile 5.10 @ 133 mph, Best 1/4 mile 8.08 @ 165, Best 60ft. 1.120 - (SOLD)
2009 Norwalk KRE Quick 16 Winner!!!
'61 Tempest wagon 2Dr, '05 GTO LS2 powered, 12.39 @ 109 mph at Drag week 2015 - https://www.youtube.com/watch?v=jsVRzMXERtA
'64 Grand Prix, Pump gas, 529ci., CV-1 Heads, Holley Dominator EFI. - Single turbo in progress..
'70 Trans Am, Ram Air III 400 - 4 speed.
Old 10-19-2014, 11:43 PM
bad69bird's Avatar
No problem
Old 10-20-2014, 03:34 AM
slowbird's Avatar
slowbird slowbird is offline
Congrats! Looks fast just setting there.
Old 10-20-2014, 08:25 AM
badgto's Avatar
badgto badgto is offline
Awesome numbers Kelvin. I'm just glad I run a different class than you, with you being back out again.
Old 10-20-2014, 08:36 AM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Congrats, you must be very happy, those are terrific results.
Thanks for posting and sharing....knowledge is power and helps us all.
Old 10-20-2014, 08:44 AM
Tom Vaught's Avatar
Boost Engineer
Even though the numbers are pretty close between Goatracer's Dual Dominator engine with NOS compression ratio and Calvin Poe's Single 4 BBL engine with higher compression you now have two good Dyno points for comparison with other engines.
Don't think "Happy Holbrook's Dyno" was as far off as some thought it was.
Again, Great Job, Calvin Poe.
Tom V.
Old 10-20-2014, 12:30 PM
bruce driggers bruce driggers is offline
Great job Kelvin !!
Old 10-20-2014, 12:40 PM
quick67bird's Avatar
quick67bird quick67bird is offline
Sounds like it will be a beast and will be a good performer.
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4.
Old 10-20-2014, 12:44 PM
grnmnstr's Avatar
grnmnstr grnmnstr is offline
Originally Posted by Kelvin Poe View Post
The tunnel ram has a single carb tent top on it. I didn't really want to go with dual 4's.
The headers are 2 1/8". They started as a BBC Headman weld up kit that I built.
The Lifters are standard size .842 Pontiac solid roller lifters that Calvin Hill sells.
The rocker ratio is 1.85.
Thanks for the questions.
Thanks Kelvin, just looking to compare with mine.
I see the single carb and now I see the dry sump.
Some similarities with mine.
1978 Pontiac Grand LeMans.......out next year
Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG
Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs.
Old 10-20-2014, 12:53 PM
GTOGEORGE's Avatar
Kelvin is going to have a nice 7 sec. ride!
GTO George
Old 10-20-2014, 01:12 PM
ho428's Avatar
ho428 ho428 is offline
It can't be.
Happy dyno, East Coast air, Solar flares, Polar Vortex, must be some logical explanation other than a good choice of parts, hard work and proper tuning.
Nicely done!
That is one FAT (!) tq curve.
Old 10-20-2014, 01:16 PM
Kelvin with the new HP you should be into the 7.80's pretty easily.
You ran the engine with alcohol on the dyno right?
The AFR shows 11/12 AFR which must be a conversion from the stoichiometric scale?
(never saw an alcohol dyno sheet)
Probably from the alcohol.
Old 10-20-2014, 01:21 PM
firechickenman's Avatar
firechickenman firechickenman is offline
Congrats on the new power! If you can get it to Tulsa this fall, that should make for some good numbers at the track!
'68 Firebird
463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69
2022 - 10.13 @ 133.07
9.93 run - https://youtu.be/hII0_UlYM4U
Old 10-20-2014, 01:37 PM
Kelvin Poe's Avatar
Originally Posted by Transporter View Post
Great job Kelvin, and from one Kansan to another, I'm glad you posted the info, at some point I really need to get my ass over to your shop and introduce myself.
Stan
Stop by anytime, Stan
Old 10-20-2014, 01:54 PM
Kelvin Poe's Avatar
Thanks John, I'll just be happy to be in the 7.90's.
Yes, that dyno sheet was on alcohol. I did make the first few pulls on gas, though, to get some heat in it and seat the rings.
Old 10-20-2014, 02:15 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Congrats!
You should run very well.
First Pontiac powered street car in the 7's
7.940@170.84. 3460#s
  #38
Old 10-20-2014, 02:36 PM
Wareagle's Avatar
Wareagle Wareagle is offline
Cool
Congrats Kelvin - one Sweet Trans Am
  #39
Old 10-20-2014, 02:37 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
congrats and kick some a$$ with it..
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046 jet
First ultra street/ultimate street NOS car to get into the 4's!
1.079 4.559 153.23.
3100 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
T2TTFMF!
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #40
Old 10-20-2014, 02:47 PM
wreckmastr's Avatar
Good job man! Congrats and thanks for posting. It doesn't matter who's heads they are. Great combo. Have fun with it.
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
