Thanks guys for the suggestions I'll keep ya all posted,,,,,lol.....
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
I had a 70 Bonni 455 convert some years ago and it started knocking and everyone that i had listen to it said it sounded like a bearing knock so i pulled the engine and found it to be a flex plate bolt backed out. Hopefully it'll be that simple for you.
Pulled today
wow, sorry to see the carnage. did you build this engine the second time around?
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
more pics
My real Concern here is the oil pan ...looks like fuel maybe mixing with the oil ...and caused the Bearing issue.... I'm not gonna pull it apart I want to take it to the builder and have him look at it...get his take too..... I don't like the how BLACK the tops of the pistons and the Combustion chambers are for as little mileage it has on it.....MIGHT be 1000 miles Well what ya think ......Cant go through this F*****G again.....$$$$$
Nope shop recommend to me by a friend that is very reputable ...I'm gonna take it back to him I;ve called him about a month ago.,,,,what ya think about the pan...
I still have the filter might take it in and have it tested for Fuel or Antifreeze ,,,but never noted any issues ....
black carbon on top of pistons is normal and mostly from cold starts and low speed operation
1989 Automotive Hall of Fame Inductee |
It just seems excessive with that low mileage...almost seems oily----ish.....
oily is not good, got to watch excessive idling during break in, make sure everything is right and go drive it
Bad news SUCKS...
Les Iden ---------------------------- '65 Buick Sport Wagon Custom, 340, T350, 3:23 '66 GTO Post/468, 700R4, 3.31 (Mike's as of 9-16) '68 Grand Prix/455, dual AFBs, T400, 2:93 posi (sold) '72 TA tribute/461, T400, 3.08, (Russ's as of 9-16) '97 Mitsubishi Eclipse Spyder Turbo, Konis, 5 speed '09 Torrent GXP, nav, Sun & Sound pkg., Bilsteins |
Well I have new pump on there that was actually on the 350.... I have another pump to put on it its Darbys pump he was usin on his old ride.... The Carb has been rebuilt with one of Cliffs kits but how do I know if the carb is REALLY leaking .. I was thinkin of sending it out to have it checked.... I still have the oil filter full of oil, might take it and have it tested for fuel content perhaps...
ok fill me in .....
does the oil smell like gasoline?
The oil when I drained it,,,didn't check never thought about it....and need to say the car has sat for 2 months soooooo....... The pan doesn't seem to smell.....I'm pissed and hope I don't have other issues that caused this problem,,,,
Sorry but what is obvious in the gasket pic???
What head gasket do u suggest...??
you really need to get a look at all the bearings....tough to see much in your pan pics with the flash glare....
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
#38
pan pic no flash
I agree on taking the caps off but I want to leave it for the builder So do u think its fuel that's marking the pan like that in the pic............ looks like snow flakes.....
#39
give Butler a call and get a set of his oem type head gaskets. Get his opinion on the fel-pro gaskets. It is obvious the gasket let go between the cyls.
#40
[QUOTE=cnc;5111164]Sorry but what is obvious in the gasket pic???QUOTE]
if you look at the gasket between the cylinders the color matches the tops of your pistons. the gasket shouldn't have that discoloration hope your builder takes care of it |
