-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies - Build Thread http://forums.maxperformanceinc.com/...615847&page=23 |
Now, if you look at a Dodge slant six, they had solid flat tappet cams in them, but they were so mild that they get away with very low spring pressures. Something like 60-70 lbs. on the seat and maybe 200 lbs. open. They would run forever with that.
http://forums.maxperformanceinc.com/...d.php?t=733233 Wouldn't happen to know if they have the disc type check valve or a check ball would you? And the metering valve disc, is it with the 4 holes? .
Could even go 60311, it will run power brakes, but it's a little more 'cranky', if you can handle that. This one will be more sensitive to static CR, with e-heads, I would say min is like 10.5, 10.75-11 would be better. Might be better with a custom grind, filling out the form as Singleton suggested isn't a bad idea, then call after you get a response to discuss, they may mod it some after talking to you. .
