Headlight brackets and bezels are sold, thanks Darren.
Disc brake proportioning valve is sold, Thanks Janne. |
DWID,
I'm looking for the small clips that hold the non-A/C dash vent flaps in place. I've attached a picture of what I'm talking about. Does your car still have them and are they in good shape? Also looking for a nice glove box insert. If you're able to help, please let me know what you want for them. Thanks. v/r, Rob |
Hey Rob,
I do have some of those clips around, just let me have a look. Unfortunately the glove box insert was broken when removed. Rear seat is SOLD - thanks Tom trunk lid is SOLD - Thanks Richard |
If the glove box door has the original hinge intact I want it. Could you post a pic along with shipping $ to 18902. Thanks, Mark O.
You can also email the info since I might forget to look here after a while. mark.daleh2o@verizon.net
Ain't as good as I once was, but I'm as good once as I ever was. |
email sent on the glove box door.
Front bumper brackets are SOLD - thanks Darren |
Are the "Gauges (with bezel and printed circuit) - $200" the Rally Gauges?
Thanx |
The gauges are just the standard idiot light ones.
Sale pending on the corner mouldings
glove box door is SOLD thanks Mark
Frame and rear upper control arms are SOLD Thanks Mike
inner grills with trim (one side pitted) - $75
15/16" front sway bar (blasted and primed) - $40 Turn signals (housings, bezels, lenses, and brackets) - $100/pair Front upper control arms $35 each or $50 pair Saginaw power steering gear - $65 Pitman arm - $30 th400 speedo cable - $25 Heater controls (non ac car) with bezel - $50 Gauge pod cluster housing - $65 Gauges (with bezel and printed circuit) - $175 throttle cable and plastic firewall mounting plate - $35 Headliner bows and clips - $40 set Headliner tack strips with hardware - $50 set ash tray assembly (paint to match, rusted inside) - $25 Auto shifter assembly - $75 e brake assembly with pedal - $45 complete Under rear seat cable protector - $25 Trunk torsion rods - $35 set (2 available) gas pedal assembly (complete) - $35 rear bumper support bumpers - $20/pr Door hinges - $75/all 4 Door latches and lock mechanisms - $65/pair Front lower valence panel (middle section rusted out but excellent for repairs) - $25 Front lighting harness - $50 Intermediate lighting harness - $50 Dome lamp with harness - $25 Lower windshield stainless - $75 front windshield stainless - $50 fender stainless mouldings - $15 Rear view mirror with all mounting hardware (red cover) - $25 Stainless window tracks - $50 pair Sun visors and brackets (need to be recovered) - $30/pair brake pedal and pedal pivot bracket - $35 rear bumper brackets (set of 3, rusted and need to be straightened) - $30 original rad support center bracket - $20 front drip rails - $20/set Tail light housings (plastic) - $50/pair (have 2 to choose from) rear marker lights - $25/set (will need new bezels) wiper switch - $20 Trunk latch assembly - $20 Gas tank straps - $25 pair Front disc brake set up - $200 (spindles,rotors,calipers,brackets.shields etc) Front steering set up (tie rods, centerlink, idler arm) - $75 Center links - $30 each Transmission tunnel metal (nice shape) - $40 red door panels (need to be redone) - $150 (complete) Rad support top plate, centre brace and brackets for 70 lemans $20 Steering column and pedal pivot bracket $25 mid 70's Pontiac dog dish hubcaps - $60/set Listed below are larger items that I prefer not to ship: rear glass (2 to choose from non tinted) - $100 each front windshield - $125 Full firewall and tunnel metal - $100 rear package tray with trunk lid hinges etc. - $85 Trunk divider panel with rear crossmember (where trunk divider meets trunk pan) - $85 Inner rear quarter structures with sail panel - $75 a side Roof with sub frame - $100 Complete bucket seats (red) - $500 Inner fenders - $125/pair Rear quarter glass - $65 each Doors - $100/each (have a few to choose from) Rear bumper (needs straightening and re chrome)- $65 Front fenders (need heel patches) - $125 each Fiberglass rear quarters - $75 each |
Do you still have the 69 tail light housings? I'm interested.
PM sent on the housings
PM returned on Housings
PM & PP sent.
Tail light housings are SOLD Thanks Stu
Endura Bumper is SOLD Thanks Frank
Turn signals and brackets are SOLD Thanks Tony |
#38
Trunk springs are SOLD - thanks cuz
Front disc brake set up is SOLD - Thanks Jan |
#39
Dome lamp with harness SOLD as well
