Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
If you lawn has any steep slopes the zero turn will require a lot of getting used to. They are great for mowing around trees ect.
Since no one mentioned Craftsman, I will. Have the 50 inch hydrastat with the Kohler V-twin engine. The engine is great and is the only positive thing I can say about that GT mower. The lift arms and deck is flimsey, the blade housings have no way to lube the bearings. The bearings aren't serviceable since the pulley is welded to one end of the shaft and the blade flange to the other.\ The old Craftsman garden tractor with a 48" mower deck is twice the machine even though the opposed twin B&S engine sounds like an eggbeater in a bucket of bolts.
Monty Frerichs B&M Machine Box Elder SD |
you cant go wrong with a real john deere garden tractor from a dealer. built much better than the box store ones. i have a 325 that i bought in 1999. just one bely last year & 1 battery in 2010. you have to do your maintenance .
DBANDGB |
Buy a used Dixie chopper 60" or bigger. In a residential setting (once a week) it will last forever.
Don't buy a box store version of any zero turn mower, they are spec built to a lower quality. |
My Sears Craftsman had a superb Kohler engine ( only good thing about it): That enigne fit nicely in the Simplicity sit-down mower.
The big work gets done by a John Deere "COMM-MOW" 52" ..loud but effective. |
When I cut my 3 acre property I used a Kubota L3130 with a 6' finish mower. Fairlty slow but gets the job done.
Go Fast... Return... Go Fast Again... Who cares about left turns??? |
I bought a JD X595 24 hp diesel w/ 62" deck 4wd tractor in 2003 and I've never once regretted it. I also bought the 2 stage snow blower, the front end loader and a JRCO cart for the power-flow collection system. Not the least expensive route...but it makes doing just about EVERY unenjoyable lawn chore...pleasant. I used to spend an hour w/ a walk behind snow blower every time it snowed more than an inch. Now it only takes me 8 minutes to clean the driveway. The diesel is VERY forgiving on fuel consumption and thie X595 is built like a tank. Plastic body parts....but everything else is built to last a lifetime. I worked locally for a John Deere dealership as a mechanic for 7 years and of all the tractors I worked on in that time frame, the early 400 series and 500 series (now the 700 series) were by FAR the least problematic. In fact...I have never had to open the hydristat unit on either a 400 or a 500 series tractor. An early 322 tractor is a great little tractor, built to last a lifetime as well.
Gregg |
Exmark
I have a Crafttsman GT5000 with a 23HP Kohler, engine is fantastic. However every time I use something else breaks. I had to put new spindles on every other year. Last time I got a used Exmark TurfTracer HP with a sulky. This thing mows. Real spindles with bearings that can be lubed, a 19 hp Kawasaki, and a deck that is 1/4 steel.
Gregg |
IF you go with a commercial ZTR look at how fast you really can mow.
I had a JD Z trak 777 60"and it was just too damn fast to appreciate so I sold it and went back to my JD Z trak 757. If you do want big and fast I have a JD 797 with 72" deck that Im replacing motor on and will be for sale. The larger units have gone to watercooled 2 cyl,which helps for longevity wondering if they make a snow blower attachment for ZTRs The only thing Ive found on the JD ZTRs thats foreign made is the Japanese hydro pump
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
When I was faced with the need for a lawn and garden tractor a few years ago, a relative who is a very serious lawn and garden tractor aficionado told me that the John Deere 318 (80s - mid 90s vintage) is the best lawn and garden tractor ever made. Around here they are also pretty easy to find.
I run a 50'' mower deck with it and a 48'' two-stage snowblower (I see you are in MI - might be a consideration) and it is great. Eats through 2' of snow. I have also done quite a bit of tilling with it. Never lets me down. |
I have a John Deere X300 with 42" deck for my 1.25 acre lot. I get the lawn done in 1 hour 10 minutes.
If you buy a John Deere, it'll cost more initially, but maintenance is practically zero (other than oil changes and blade sharpening). When it comes time to replace your mower, John Deere mowers are very easy to sell at premium prices compared to other brands that you will practically give away after 5 years usage. I bought a '89 John Deere in '97 for $800, used it for five years and sold it for $850. Can't beat John Deere's resale value.
You can get a snow blade for the front as well, and use it in the wintertime. It will definitely do it all. I had an "A" (I really wanted a Cub but the A was a little cheaper). One of the best purchases I've ever made in my life. Currently mowing with a Cub Lo boy - also one of the best purchases I've ever made. You can't tear up a vintage tractor. Plus, there's the "cool" factor. I've had people stop in the road just to watch me mow. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 Last edited by Keith Seymore; 08-04-2013 at 02:45 PM. |
I have a 1992 G2000 4Wheel Steer Kubota with a 60" deck. Close to a ZTR... but not quite.
I drove Ol Goat 67's 54" ZTR Big Dog and I really like it. It's a really rugged machine. If I ever go with a ZTR mower it's the machine I'd buy. Remember..... if you go with a ZTR, you'll take a while to get used to it. I know.... it looked like a snake mowed Charles' [OG 67] lawn when I got off it. LOL You should see him and his wife go at it. Looks like the "Lawn Mower's Derby" they go so fast. LOL I'd say he has just a tad over 2 acres to mow ( that's counting what he mows across the street from his house), and they do it all in about 90 minutes. Big Dog gets my vote.
Niiiiiiiiiiiiice.
Two 1975 455 Grandvilles & '79 455 Trans Am ‘69 Camaro SS 396/375 (owned since ‘88) ‘22 Toyota Sequoia V8 ‘23 Lexus LS500 awd ‘95 Ford F-super duty 4wd 7.3 p-stroke & countless Jeeps & off road vehicles. |
Craftsman and Kioti
I use a 9000 series lawn tractor around the house. It is 42" with 24 hp. I love the joy stick. It goes faster as you push the stick forward. Lots more fun than toe/heel peddle.
Then I use a CK27 Kioti with a 5' bush hog for the 8-10 acres which surrounds the horse lot, that used to be a hayfield. It's a diesel that hardly uses any fuel at all, it seems. |
Gregg |
#38
Note from TJ
Pontiacs and Appaloosas forever! |
#39
Gregg |
#40
