Thanks Ken.. Hoping to get to your neck soon with one of my clunkers so keep me posted about any events..
Sometimes towed but never trailered! |
B1 eng
You should have checked the factory chassis manual.
B1 shows to be a 61-10 H/M (slim jim), 4bbl, 10.25:1 comp engine, with a 425E and 61-10 H.M. camshaft (0), w/spl equip, for a 23-25 series car. Piston fit ..0007-.0013, dist model 1110964 or 1110970, AC 45 spark plugs and heavy duty starter. |
http://forums.maxperformanceinc.com/...d.php?t=725766
'63 Catalina Safari, Silverleaf Green / Cameo Ivory, nice options, 4 speed '66 Grand Prix, Marina Turquoise, 421 HO, many options, 4 speed My Garage Tarheel Tigers Pontiac Club of Raleigh, NC |
Your cam should be a 519640. The 303 HP eng uses cam 529472. good luck with it..Has always been my favorite. I had one from 64-66, but my wife had to sell it because something expensive broke while I was in Nam.. We finally found a 61 Cat Conv 3 years ago.. Last edited by lilabner; 04-29-2013 at 03:43 PM. |
This is from H/O Racing catalog
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
I appreciate all the research.. I have Pete McCarthy's book but the B1 isn't in there.
Looks like there's still conflicting info about this B1 engine.. From that chart it appears the B1 is rated the same HP as the 2 barrel engine which it 283? There's no 287 HP until '62 and it's a different code. There's no tag on my carb but it looks like the same one that's on my '63 BV.. So it must be the cam/slimjim application that makes it 283 HP, coincidentally the same as the 2 barrel?
Sometimes towed but never trailered! Last edited by MOJO Catalina; 04-29-2013 at 07:08 PM. |
I think your 61 Ventura was originally a 2-barrel engine & someone put a 4-barrel intake & carb on it. Thats what I did to my 59 cat A code, 280 HP 2-barrel.
I'd trade my 61-tempest wagon for that. hint hint.
GT. |
Go to page 6-0, Fig. 6-1 in the 1961 Factory Chassis Manual, Then go to page 6-55 to find the HP, your engine being a 61-10 HM 3 speed with a 4 bbl carb. the manual can be found and copied online here.
http://wildaboutcarsonline.com/cgi-b...69990444536748 The big catch is you have to register and join,,,for free.. |
The 1962 287 HP might be a misprint? It appears most engines were raised 3 HP from 1960 - 1962
OK so in the 1961 shop manual the B1 has a 4 barrel.. does it say what HP, cam and Carb number?
Just bought a '61 shop manual.. Figure if I'm gonna own and work on it I better have one.. Hydramatic manual is the same for '63 right? I already have one of those..
Hydramatic manual should have info on both HM transmissions. There may be minor changes between 61 and 63 but may no cause you any trouble unless you are into a full tear down and rebuild
OK that's good to know..
Still have not gotten the engine to wink.. been soaking each cylinder with PB blaster and tapped all the valves lightly w/a hammer.. 2 were stuck but are bouncing now.. I'm thinking those are the two cylinders that are probably stuck.. Anybody out there an expert on unsticking a 389? I'm open to suggestions.. Just bent my breaker bar and 3 pipes.. Not budging yet..
#38
Something my brother-in-law told me a long time ago
that works pretty good is coleman lanter fuel and trans mission fluid mix in the cylinders. It worked for me a long time ago on a 400 that was set up. I filled the cylinders pretty deep and let it soak. The lanter fuel will seep in and the tranny fluid will lubricate at the same time. Hope it helps. GT. |
#39
Thanks, I think I have both of those items already.. I loaded it up with a whole can of PB Blaster equally dispersed between all 8 cylinder.. If it doesn't spin for me later today I'll try that mix..
#40
