Old 03-24-2013, 08:27 PM
tom s tom s is offline
Make sure the timing cover has the proper dimple!As I said the X over on the intake was on the intake when I got it.It was just welded in the wrong place for the donut to line up with the timing cover.Tom
Old 03-24-2013, 08:28 PM
I could have just used it as was by blocking off both holes.Tom
Old 03-25-2013, 10:35 AM
428RA4's Avatar
428RA4 428RA4 is offline
Yes, I do have the correct timing cover. So what did you wind up doing to address the incorrect position of the crossover?
Old 03-25-2013, 12:04 PM
Cut it off and reweld it the right place
Old 03-25-2013, 01:32 PM
marks73ta's Avatar
marks73ta marks73ta is offline
Tom is there enough flange material to cut it down for a 301conversion??? Just thinking. Mark L
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build.
Old 03-25-2013, 05:48 PM
Are you thinking of putting a set of V heads on a 301 block?If so maybe but WAY better to just do a sheetmetal IMO.Jim Robertson made me one for my 303 short deck motor.Tom
Old 03-31-2013, 11:28 AM
428RA4's Avatar
Hey Tom -
Can you please send me higher resolution pictures of your dual quad intake? Any and all information I collect will assist the artists in building my piece.
thanks
mike
Old 03-31-2013, 11:51 AM
Send me a email to t.schlauch@yahoo.com and will send them.Maybe will be better.Tom
Old 03-31-2013, 03:33 PM
Dragncar Dragncar is offline
Whats that intake worth as a Ford Tunnel Port intake ?
It might be worth enough to pay for a chunk of a sheet metal one.
How rare is it ?
Old 04-01-2013, 06:48 PM
428RA4's Avatar
How rare is it ?
The Ford Dual Quad intakes go for anywhere between 1000 and 2500. A sheet metal intake will not work for this project. It has to be vintage looking.
Since the Pontiac intakes are made of Unobtainium, and is one of the rarest metals on the planet, you might as well make your own.
Old 04-01-2013, 07:43 PM
cgeise's Avatar
cgeise cgeise is offline
Sell it for 2 k and have JM make a new one out of cast sections
Old 04-02-2013, 10:57 AM
428RA4's Avatar
Thanks, but I have made the commitment to the project already.
I purchased the tri-power intake to acquire the water crossover. Piece by piece, the project is gaining momentum. Next week will be the nick knack box of parts to be shipped.
http://www.ebay.com/itm/330778509657...84.m1436.l2648
Old 04-02-2013, 12:02 PM
dci dci is offline
Mike are you going to attach the water crossover or leave it separate?
Don Johnston
DCI MOTORSPORTS INC.
330-850-5050 Shop
330-628-3354 cell
Designer of the DCI Tiger Heads and the NEW DCI Ram Air V heads !!!!!!
Old 04-02-2013, 12:05 PM
428RA4's Avatar
Hey Don -
It will be attached and be one piece. Why do you ask?
Old 04-02-2013, 12:18 PM
dci dci is offline
Well I believe you stated earlier that you may be or are going to look into re popping them. If you indeed do that (which I would like to see you do). I think that if you make it separate that it will be able to work with my heads. That being said, the water cross over passage on my heads is still in the stock location. I would love to see you make the dual quad intake and then I could concentrate on a single 4 intake. That way all bases are covered except maybe a blower intake.
Don Johnston
330-850-5050 Shop
330-628-3354 cell
Old 04-02-2013, 12:28 PM
428RA4's Avatar
OH -
I understand.
Well, I'm not sure how you are going to address the differences between a stock head height and the taller configuration of your heads. Intake spacers? So, I'm not sure if there were be an advantage, disadvantage or moot if I leave the crossover on or off.
thoughts?
Old 04-02-2013, 12:40 PM
You realize the bolt pattern is diff from that intake and a V head on the X over?Tom
  #38
Old 04-02-2013, 12:41 PM
428RA4's Avatar
Yes Sir.
I may have to send the intake builder my NOS single 4 barrel intake for better reference. Not sure yet.
  #39
Old 04-02-2013, 01:58 PM
dci dci is offline
Spacers will definitely be needed and pose no problem what so ever. As a matter of fact may even help by making the intake runner longer which will make more torque. I really don't see any real issue making it one piece or with a separate cross over now that I think about it. I suppose it is easy enough to cut off if they do decide to purchase it for my heads.
Don Johnston
330-850-5050 Shop
330-628-3354 cell
  #40
Old 04-02-2013, 02:20 PM
61-63 61-63 is offline
This is a neat thread. Given the price of 859 intakes, when/if one can be found, a person could fabricate that intake for less money I think.
The medium and high riser Fords are being reproduced for less than $1000.
http://www.dscmotorsport.com/asp/pro...=152&GroupID=4
