Old 03-21-2013, 10:02 AM
goatman-68's Avatar
goatman-68 goatman-68 is offline
Back in the '70s, it wasn't uncommon to see those yellow headlights substituted into the high beam space...Especially, Mopars for some reason....I wonder if they still sell those? In fact, I've noticed that some of the new generation Dodge Challengers come with them, I assume for that old school look.
I also like the (old school) look, except I went with 250 watt aircraft landing lights instead of the yellow.........
Name:	DSC01118 [1024x768].jpg
Frame off (resto mod) 68 GTO - 406, 0-deck, E-Head home port 87cc, TRW L2279F30, Comp. flat solid .577/.577 - 248/248@.050 110LS. 700R4, Precision Industries 3 disc 10" lockup 3500rpm, Moser 9" 4.11, Detroit Locker.
Old 03-21-2013, 11:40 AM
Now, that's pretty cool.
Old 03-21-2013, 12:17 PM
2002Z4CSS's Avatar
I used to have these for high beams on my 1973 Thunderbird. If I used them for anything longer than 3 minutes the circuit breaker in the headlight switch would trip and I would then loose all headlights until the circuit breaker cooled and reset. Darn bright lights though!
1971 Pontiac GT-37
Old 03-21-2013, 12:55 PM
goatman-68's Avatar
The popular aircraft lights are 100 watt pencil beams. The lamps I used are 250 watt floods. I ran a 6ga wire from the battery in trunk to a continuous duty Ford type starter solenoid mounted up front. Then I ran either 8ga or 10ga wire right to the lamps. I use the dimmer switch just to actuate the solenoid. These 250 watt lamps draw 20 amps each so you need a high output alternator to keep up. I live in the country with lots of deer so the few times I have driven the car at night, these lights have saved the car!!!!!!!!!!
Old 03-21-2013, 05:38 PM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
That's pretty cool.
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
