OHC-6 TECH Over Head Cam projects, questions and advice.
Old 01-15-2013, 08:11 PM
hpp's Avatar
hpp hpp is offline
problem lies in design,throwing oil up thru the screen at high RPMs
I've read just leaving the screen out makes this even worse. Did they make any changes 66-69?
Old 01-15-2013, 08:39 PM
Cammer-6 Cammer-6 is offline
stuff a copper scrubby in
wrap a wire around it so it wont fall down in
no changes except the cap/breather
it went from 49 states open in 66,67
to CCV in 68
66,67 Calif only was CCV
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 01-16-2013, 11:49 AM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
Noted. Thanks for the information.
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
Old 01-16-2013, 06:00 PM
hpp's Avatar
hpp hpp is offline
Originally Posted by barrierblue66 View Post
Great progress! It's gonna be a beeautiful color
Thanks Barrier blue is my favorite color on these years.
Im going to do the same.
Old 01-27-2013, 09:49 AM
hpp's Avatar
hpp hpp is offline
Few pics of the intake and ex man so far. Still looking for the throttle cable bracket it's the last piece I need.
ID:	311215   Click image for larger version
ID:	311216   Click image for larger version
Old 01-27-2013, 10:58 AM
PMD1969's Avatar
PMD1969 PMD1969 is offline
Looks awesome! What did you do to finish the exhaust manifold?
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213)
99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale
http://sohcsix.yuku.com/forums/1/OHC-lounge
Wanted: 1969 OHC "H" Camshaft
Old 01-27-2013, 11:19 AM
hpp's Avatar
hpp hpp is offline
Bead blasted then I used POR-15 Manifold grey applied with a sponge brush dries great with no brush marks.
Old 01-27-2013, 12:18 PM
Years ago I went to a friends shop and saw a 60s T bird he was just finishing for a customer.
I asked what was on the manifolds and he said"nothing".
I asked how they remained so new looking,yet obviously the motor had been run for breakin and after all this is Fla we live in so humidity is always present.
His explanation was this:
Blast until clean,do not touch with bare hands
coat or dip in fresh clean motor oil and continue to coat until cast iron doesnt soak up any more(this may take a week or so)
fire motor up,or use BBQ grille or shop oven
at the first sign of smoke shut it down and let cool,repeat and continue to remove from heat until all the oil is burned in.
This is basically the same process as seasoning a cast iron skillet. Touch up later if needed
until the oil is soaked in to the cast iron.
Old 01-31-2013, 10:08 PM
hpp's Avatar
hpp hpp is offline
Not a whole lot going on right now. Working on the upper/lower control arms removing the ball joints and bushings then off to the blaster.
Old 02-15-2013, 07:31 PM
hpp's Avatar
hpp hpp is offline
Painted the top of the firewall with PPG base/clear with the correct amount of overspray into the black. Blended the base into the factory blue on the sides of the firewall and then cleared. Color is very close to Barrier blue.
Still waiting for the parts from the blaster and my front end rebuild kit.
Going to install the heater box,stainless front brake lines,brake booster tommorow.
Name:	Firewall painted 001.jpg
ID:	313308   Click image for larger version
Name:	Firewall painted 007.jpg
ID:	313309   Click image for larger version
Name:	Firewall painted 008.jpg
ID:	313310   Click image for larger version
Name:	Firewall painted 005.jpg
Old 02-15-2013, 09:44 PM
barrierblue66's Avatar
barrierblue66 barrierblue66 is offline
Sure does look the same. Nice work, looks great!
'63 Catalina Safari, Silverleaf Green / Cameo Ivory, nice options, 4 speed
'66 Grand Prix, Marina Turquoise, 421 HO, many options, 4 speed
My Garage
Tarheel Tigers Pontiac Club of Raleigh, NC
Old 02-16-2013, 03:06 PM
hpp's Avatar
hpp hpp is offline
Installed the firewall insulation,heater box,core and brake booster. Was going to install the new brake lines but they aren't even close to being right. Have to find out what the deal is.
Name:	heater box install and lines 001.jpg
ID:	313418   Click image for larger version
Name:	heater box install and lines 002.jpg
ID:	313419   Click image for larger version
Name:	heater box install and lines 003.jpg
Old 02-19-2013, 07:44 PM
hpp's Avatar
hpp hpp is offline
I ordered a 3 piece brake line kit from Ames they get the lines from Right stuff. The lines were not correct they are listed for my application power drum brakes but as seen in the pics they are different. I called right stuff and am returning the lines with my orig ones and they are duplicating mine. Only orig line I dont have is the one from the master cyl to the prop valve.
Third pic shows the line for the master cyl it's not corect either. So im not sure what they sent me.
Name:	heater box install and lines 005.jpg
ID:	313691   Click image for larger version
Name:	heater box install and lines 006.jpg
ID:	313692   Click image for larger version
Name:	heater box install and lines 007.jpg
Old 02-19-2013, 11:06 PM
GT182's Avatar
GT182 GT182 is offline
Cammer, that oil trick does work great. When the sick 389 was in my GTO and blowing oil out the breather cap on the valve cover, the exhaust manifold looked like it was brand new. No rust or crud on it at all. I've got to do the oil trick with the manifolds on this 400 cause they look like crap.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 03-01-2013, 02:44 PM
hpp's Avatar
hpp hpp is offline
I pressed the new bushings in and installed the lower ball joints then painted the control arms. Starting to assy the front suspension I have to grab the spring compressor from work tommorow.
Name:	1966 suspension 002.jpg
ID:	314835   Click image for larger version
Name:	1966 suspension 003.jpg
ID:	314836   Click image for larger version
Name:	1966 suspension 007.jpg
ID:	314837   Click image for larger version
Old 03-01-2013, 10:30 PM
ha real men dont need a stinkin spring compressor.
I know someone that thought that and a spring got away from him, landed on roof of neighbors house!
Old 03-01-2013, 10:53 PM
hpp's Avatar
hpp hpp is offline
That's funny
  #38
Old 03-09-2013, 09:05 AM
hpp's Avatar
hpp hpp is offline
Installed the front springs and got the car back on the ground finally able to push it out of the garage and blow everything out and get things cleaned up. Last pic shows the spring compressed to be installed I have to say I was a little nervous.
Name:	Suspension installed 003.jpg
ID:	315658   Click image for larger version
Name:	Suspension installed 004.jpg
ID:	315659   Click image for larger version
Name:	Suspension installed 005.jpg
ID:	315660   Click image for larger version
Name:	Suspension installed 001.jpg
ID:	315661   Click image for larger version
  #39
Old 03-12-2013, 11:07 AM
Springs always make me nervous.
  #40
Old 03-12-2013, 11:18 AM
Looks like my front end - about 20 years ago when I did it The compressor I used had hooks, and I remember handling very carefully.
My Garage
