And a couple shots of the steering wheel, rough but repairable, And after looking at the underside of the car, I don't think even Keith would have drove it as long as it was, I have some shots of the lack of frame and floor boards on my phone I will post later today, it is really, REALLY!!!!! RUSTED!!!! I did not actually look under the car on the 1st trip to the yard.
Unfortunatly I had to leave the engine as I did not have time to pull it, and with my Job I never know until the day before Norwalk if I can make it there, so I really can't afford to have it not paid in advance, taking up space. Sorry.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
Looks like you have everything except the band/bracket that secures the hoses to the frame rail inside the engine bay. You did not take any pics of the PS hoses from the pump, that part could be still on the hoses.
I have the same one on my 4 motors.
Take out the 4 bolts on the inside of the balancer. Thats holding everything to the hub. Everything should seperate from the hub. Check the hub in the area of the crank key way to make sure its not cracked.
Keith Collier 61-63 Pontiac Tempest Tech advisor POCI.org Last edited by mechanickeith; 05-30-2012 at 12:53 PM. |
Thanks Keith, I am going to let the new owner inspect it when he gets it. And I did grab the Hose bracket that bolts to the frame rail top, but it is not pictured. And Keith just to prove that even you would have retired this car for parts, here are the pic's of the underside of the car.
Nothing wrong with that!!! Good for at least another 50-60K!!!!
Keith Collier 61-63 Pontiac Tempest Tech advisor POCI.org |
Yeah, Keith could use the extra leg room that Tempest offered
