All ready ordered new guide plates form Ken K and will remove intake tomorrow to see if there is further damage. Hopefully not.
FWIW the 3/8" Comp guideplates aren't too bad,been on my RAIV motor for a long time but did get tweaked for aligment. But definitiely something to look at the alignment no matter whose you use. Isky has some adjustable 2 piece guideplates but the slots aren't deep enough for a Pontiac.
I'd sayn that bolt from being fatigued-stretched back and forth. I would check the slot in the rocker and what the other guys said. Got some rockers from crane and had a slot problem. You just can't check everything enough times. Had a 1/2" stud break down inside the head once causing the valve lash to get off. Thats still a mystery
Well I opened it up today and this is what I found. A destroyed lifter. The funny thing is the broken lifter is the one adjacent to the stud that broke. The lifter from the broken stud was in tact and just out of its bore. I did scope the cylinder and could see no damage to the piston. I could not recover all the broken lifter parts so I guess the engine will have to come out and be torn down. Man this sucks!!
Hard to tell from pic's, but looks like lot of wear on 2nd one over.
Make sure the oil bands dont go past bore. Agreed with WDC, get a set of poly locks.
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 Last edited by Region Warrior; 02-09-2012 at 12:30 PM. |
Lobe is toast, you can see the angle of the witness mark on the ramp that would indicate the lifter tracked across the entire face, and before/after the peak.
When the cup popped, it probably got hung and damaged the lifter bore too. Not fun. I feel for you. .
lifter bore not looking to good.
The lifter plunger or body got hung between the lobe and the block, that's what caused that, as well as the lifter being chewed up. (And that lobe is wiped)
That's not particularly a problem, since it's on the outside, I was originally talking about the bore itself. That's what you need to look at. Kind of moot at this point, you need to do a tear down and inspection regardless. What kind of lifters? Do they have a wire-type retainer, or a snap ring? Should always go for snap ring type lifters. .
The lifters are suppose to be Johnsons. Here are a few pic's of the one that was in the pbore with the broken rocker stud.
Those are Hilift Johnson lifters.
did the builder install the oil gally plug.......the one in the upper rear of motor, by the dist.
1970 firebird, 468, e heads, |
