Most modern cams are rated per current SAE guidelines,typically giving us the duration numbers @ .006" lift at the valve (which is usually around .004" at the cam,then multiply by the OE rocker ratio). So .004 x 1.5 = .006 Now the '65 to '76 OE cams were typically rated @ .002" on the opening side,and .008" to .009" on the closing side,at least that's what was stated in the HO racing HPED&BPA book (page 78 first paragraph). Which might explain some of these discrepancies. So understand that how and where one is measuring the cam can make the duration numbers come out ever so slightly different than those OE cam numbers were. Just where the cams duration is being rated needs to be known to accurately compare the numbers from one cam to another cam. Crane had a bulletin about that a while back,I'll include the text here: Quote:
Bret P. |
Bret,
Thanks for the info.That may have been the issue.
2001 Trans Am,WS6 Sunset Orange Metallic (sold) 1973 Trans Am 455,4speed 1970 GTO |
"I was thinking about asking Lanier Henry who is a part owner/partner (or damn good friends etc) with Schneider Racing Cams. They are grinding me a cam now FWIW..."
It's my understanding that CMC ground the original WG-5059 cams. They also have the original prints. In order to have a run made, a few samples would need to be obtained, and measured, then put in an engine and ran on the dyno, etc. Once satisfied with the product, an order would be placed for a minimum run or price per camshaft based on the amount they designate per order. I have no idea what their minimum order would be, as I never got a return phone call from anyone at that company, and I left numerous messages at several folks desks? Typically, the more you purchase, the less they cost per camshaft. I also gave up on the idea due to the high lobe failure rates we are seeing with flat camshafts these days. It was probably a good thing that CMC didn't make it easy for us, because no doubt 20-30 percent of the cams we would have sold would have had a lobe or two knocked off of them (for various reasons beyond our control). This gets us in to having to warranty them, etc. We went to roller cams here for all engines built here (when we choose the parts). We also went to forged cranks and forged 4340 connecting rods as well. End result, Cliff sleeps better at night!......Cliff
A couple of pictures of an original 744-profile camshaft. You can clearly see the "constant dwell" at peak lobe lift that's often referred to.
I have your dist gear sitting on my desk for a couple weeks now!Do you need to own it or use it.$100 if you want to own it.Tom
sorry yt hi jack!meant to PM.Tom
The guy who "Wrote the Book" on Camshaft design, Don Hubbard, was a "Boost Guy" and very good friend of mine during my early years at Ford. His book is here: http://cambook.net/ Don had a turbocharged Jaguar 6 cylinder. He worked on the Chevrolet Can Am Turbo cars during that race series. Don had worked for Harvey Crane and later was the Vice President for Camshaft Machine Company (OEM Cams) and Wolverine Blue Racer Cams (Aftermarket). I was a dealer for the Wolverine Blue Racer camshafts and still have some of the camshafts on the shelves. I would typically buy the camshafts 10 at a time and the camshaft kits (w lifters and lube) 5 at a time. I was not required to buy 50 cams at a time. I would order about 6 times a year. Unfortunately Wolverine Blue Racer went out of business. They (CMC/ WBR) made great camshafts. The Chief Engineer of the CMC / Wolverine company was a "Pontiac Guy" named Glenn Corwin. I watched a Pontiac hydraulic camshafts being ground on one of their high speed grinders in less than a minute. They also ground all of the early Roller camshafts for the Ford Motor Company. Yep, CMC ground the WG-5059 camshafts. They also had an extensive cam profile collection (using their measurement equipment). I had a couple of new camshafts from "the other guys" that CMC read for me. One of these camshafts was the famous Milt Schornack "744" cheater camshaft, that in no way, resembled a factory 744 camshaft, lol! It was a true CHEATER camshaft. Tom Vaught
After reading these posts it makes me wonder what would be closest to correct if a person wanted a 744 cam. Or one that would be the closest to the power that the original produced.
I have several of the High Lift 744 Boxed Wolverine cams but none of the stocker cams. Tom Vaught
I'll post tomorrow a side by side of a 744 and SPC-3/E-909-P lobe. Quite a difference considering the specs are the same.
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
Rocky.. Your busted. Thats a SD. cam look at the dist gear teeth (smaller Dia.) regular cam the teeth are almost as big as the bearing journal..
Same lobes tho... just bustin your chops a bit Thanks for the pic.
A man who falls for everything stands for nothing. |
You got me there!
TRW made a cam which was supposed to be a version of the 744. There were some subtle differences but it ran quite well. It made a LOT of torque. I can't recollect the number, right now. If I do, I'll post it.
It might be worth researching. If memory serves, it had the long dwell.
Rich The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance. Henry Ward Beecher "The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher |
744 on left SPC-3 /e-909 on right
Ken, did you check the Speed-Pro CS171R camshaft?
And what about the old H.O. Racing Specialities #744k 408/408 301/313 224/236 112/119? |
That camshaft used to be supplied by CMC to them. If Speed-Pro is still buying CMC 744 camshafts you should be able to get a "flat nose" camshaft that way. Good Post Kenth. Tom Vaught
Always wondered what CMC- CWC meant. Fat,Dumb & Happy! (I'm going to use that one) Is it just my imagination,or is there ALOT of that going around these days? Has every successful/established business in the country assumed that attitude? |
