lee- sorry to hear about your trouble and that you seem to be giving up on the V's. i hope the new setup works well and you see the results you've been chasing for so long. keep the faith, your hard work will eventually pay off.
I told Lee that Marty made 1600 hp and 1400+ lb/ft of torque with "D-port" heads. He went 7.40s skipping 2nd gear at Norwalk.
Lee wants to run Mid 8s. What am I missing here? That is ONE SECOND difference in the performance requirement. With a decent head it should be a minimal effort and cost deal. Tom Vaught ps ALL of the stuff lee had for the Ram Air V engine was "first cabin" stuff. The Ford Tunnel Ports heads had the same issues with some of them cracking and leaking water years ago.
![]() Quote:
He had a custom set made.
Brian
I dont want to list peak numbers as I am involved in heads up class racing Appart from over 280 at 0.500" already mentioned to get you in the ball park They were flowing more at .600 than .500 They were flowing more at .700 than at .600 After 0.700 they did level off but were still flowing more at .775" Thats along way from the .550 you mentioned for "any D-port, ported or otherwise" Sorry I cant offer more, just wanted to point out that not all ported D-ports stop at .550" Think about lift vs duration and the time a valve spends at a certain flow rate over the whole intake cycle. Also remember (obviuosly) that the induction cycle isnt a steady state flow on a valve held open at a pre determined lift in a static manor (ie flow bench) On an intake cycle we cannot "crank up" the cubes to create a certain depression accross the port at any lift as you can with a bench
Working on going faster (and now staying dry at the same time !!) |
![]() Quote:
![]() Quote:
Looks like .550" to me ??????????????
Very well, but can you address my questions?
If your heads flow the best at .650 and you put a 650 lift cam in it, then you are really kind of screwing yourself because the valve only spent a millisecond at the lift point that it flows the best. If your heads flow best at .550 then you need a lift makes the valve spend the most time at or above that point.
The way I see it, you need to run the duration and overlap to operate the engine in the desired rpm range and type of use that you need, then you need to run as much lift as possible, taking into consideration valvetrain reliability. If you are drag racing and you dont mind to replace parts regularly, then you should run the lobes with the most lift you can find. If it is a street car and you dont want to fool with the valvetrain then I would stay less around .600-.650 for reliability. |
Brian from my discussions with head guys and cam guys even on heads that don't flow more with the higher lift a "square" cam lobe like the stockers use because they are lift limited is much harder on valvetrain than a "normal" lobe that goes higher in the lift. You then get more total duration at those higher lifts with better valvetrain dynamics than a square lobe, asl long as the port does not go into turbulence at those lifts, and loose flow.
Before porting was allowed in SS they used rollers with high lift and bigger durations on ports that did not flow more and made more HP.
![]() Quote:
I have a SS roller cam for the 400 with that lift. You have to think about 'Area Under the Curve'. The amount of time the head sees .550" lift (or whatever), you need to have more lift for the valve to see this. The flow doesn't 'stop' at .550". It will keep flowing above that lift, just not at the max flow. ![]()
John, I realize that. Simplified, my question is, at what point do you take diminishing returns into consideration regarding lift?
Engage intellect: Perhaps the Ideal INTAKE Valve event would open "Instantly to about 0.3" at XXBTDC then "instantly jump to .8" after piston move away, then about 90Degree down dropped back to .5", at BDC slammed to .05", then slammed shut at xxdeg ABDC vs RPM.
Such the profile would match the Vacuum-pull from the Exhaust overlap, the Piston Velocity, and the Containment needs. Make it so. HIS |
Point is: Our Peak lift occurs too late compared to Maximal Exhaust Pull event thru to Maximal Piston Velocity.
Opportunity Wreaks for the Biz team: We would need a Rhoads Intake Rocker arm: 2.5:1 Ratio at start followed by a 1.1:ratio or less after bleed time. Make it so. HIS |
![]() Quote:
Not sure: I'm not sure about the Rotor rate on the induction-side. The effective rotary chamber growth vs rotor angle is unknown to me. If the equivalent "piston velocity vs crank angle on the induction cycle was found/known, then the optimum Intake valve requirement defines itself.
![]() Quote:
Yes - Winning SS Championships with D-ports .
The Bandit Rules - Make mine with a SD-455 Engine . |
#38
That's nice.
![]() I can't beleive there is nobody that can address my questions that knows what the hell they are talking about. ![]()
#39
Brian, here's my take on it. Iron Pontiac heads, unported or poorly ported, will go turbulant around .500. The stocker guys know this of course but they do not care. Why, because they have to use .440 max lift. They use the so-called cheater cams with an almost square lobe to create long duration and fool the poor flowing head. I have asked the question of stocker guys and they said: "if I went with more lift and same duration charateristics I would kill performance". I would say from this, that if your heads go in reverse (ie turbulance) at .500 or so, do not exceed .500 lift. If your heads level out at .500 to .600, it would be wise to lift 'em to .600. My .02
fasteddy |
#40
Brian, why don't you just tell us what the answer needs to be.
