Old 04-10-2008, 09:51 PM
77TA 77TA is offline
Originally Posted by gtofreek
Just an interesting side note. The RA manifolds on this engine were Jet-Hot coated inside and out. When the engine was running I took a temp reading on the manifold with an infrared gun and the end runners were only 145° and the center was 240°. I guess that's proof that that coating really does help. The cast iron ex. pipe retaining ring that bolts to the manifold was over 450°.
A large part of the difference was the emissivity of the target.... those shiny coated manifolds will read cooler... paint a black spot on them or use a contact probe if you want to know the real temp... The coating helps just not that much.
Old 04-10-2008, 11:00 PM
440GP69's Avatar
440GP69 440GP69 is offline
i'm really curious to see what a performer rpm would have done and a cliff's Q-jet, the coatings help keep up the velocity of the exhaust too.
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
Old 04-10-2008, 11:41 PM
gtofreek's Avatar
gtofreek gtofreek is offline
I'm sure a performer RPM would have done much better but it wouldn't fit with the original RA pan. So the customer and I decided on the Tomohawk. As far as the Cliff Q-jet is concerned, I'm sure it would work really good, but the owner of our shop, Jeff Koerner is a Holley GURU. He builds some of the best Holleys around. This 750 HP with standard size venturis, flowed 997 CFM by itself and 1040 with a 1" taped spacer. The a/f ratio is a little messed up because we ran out of the right jets and have to order some in.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 04-11-2008, 12:51 AM
gtofreek's Avatar
Originally Posted by Don 79 TA
what cc heads are you using?the 65's?
They were they 65 cc. head that was CNC'ed by them and if I remember right, they ended up being around 72-73 cc's. I have to look it up in my records 'cause it's been a while. It was actually closer to 10.7:1 IIRC.
how are the headers sealing/matting up the head? look good?
Yes, the manifolds bolted up real nice. Sealed good too. I didn't even use a gasket, just Hi-temp silicon for testing because they will need to come back off. They were also Port matched to the gasket real nice before they coated them. The Fel-Pro steel core header gasket is what they matched it to. I made the port opening in the head a little smaller than the gasket and manifold. These gaskets will be used on final assembly. They came from RA Restorations in Texas. Nice piece for the money.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 04-11-2008, 03:01 AM
440GP69's Avatar
man this is the best street 400 combo ive seen in a long time! talk about a fun motor to play with imagine a 4-speed and 3.90 posi behind this thing in a 3100LB 69 Trans am! it's going to be a screamer! that torque curve is amazing for the large cam and single plane intake! are those 2.50" outlet manifolds?
Old 04-11-2008, 07:31 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Sounds like a NICE combo. We dyno'd a 428 last year with a set of unported KRE heads, and were remarkably surprised by the power numbers. Nice to see we can use the latest technology to make great power with the smaller engines!
"I didn't even use a gasket, just Hi-temp silicon for testing because they will need to come back off."
A neat trick we use here is to glue the gaskets to the heads with a small amount of RTV, then apply a generous coated of car paste wax to the bottom of the the intake.
This will act as a release agent, and you can install intake manifolds at the track or on the dyno without tearing any gaskets. We also prefer to remove the water crossover, and leave it in place. I've swapped intakes at the track in as little as 12 minutes!......Cliff
Old 04-11-2008, 09:22 AM
gtofreek's Avatar
Yes they are 2.5" outlets. It should be a beast.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 04-11-2008, 09:28 AM
gtofreek's Avatar
It was actually the ex. manifold that I just siliconed on. I agree on the intake trick though. We also glue the gasket to the head and we use Crisco as a release agent. Works real good without making a mess. Plus, you can just lick it off your fingers when your done smearing it on the gaskets! No mess, no fuss!
I like the power curve these KRE heads make. I bet it would still make over 400 HP at 7500 RPM with the way it was going.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 04-11-2008, 09:45 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
But I thought those "small port" KRE heads were low rpm
Nice work!
Skip Fix
Old 04-11-2008, 09:47 AM
gtofreek's Avatar
They are, and high rpm also!
Thanks!
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 04-11-2008, 11:44 AM
440GP69's Avatar
the csa of the kre d's even when ported looks to perfect for street motors
Old 04-12-2008, 01:31 PM
gtofreek's Avatar
I think they make an excellent street head. Personally though, if i had a set that needed top flow more than 265 CFM in the future, I will just have them CNC'ed from someone like Kaufmann or SD Performance. Getting 265/220 out of them doesn't take a lot of work. But to get more than 265, takes a lot of work. I have too many hours to count in the porting of these heads. If I knew then, what I know now, I wouldn't have done all that work. I would have just sent them out for CNC'ing. With just a good valve job, a bowl clean-up and a gasket match to the #1233 gasket got these heads to 265 CFM. From there it was a lot of porting with little gain until I opened up the port a fair amount all the way through.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 04-12-2008, 01:44 PM
Skip Fix's Avatar
Why I quit years ago, cut down on the "black or sliver boogers" too
I think on the KRE heads to start to get close to the the same cc as the E heads when you get towards to 300+ cfm also.
I use a dash of silicone grease on the intake for release myself.
It is kind of fun to have a "little" motor that runs with the 455s guys! Just need more gear and convertor though. My old RAIV 400 would back then.
Skip Fix
Old 04-12-2008, 02:04 PM
gtofreek's Avatar
Yeah it's always fun when you spank a big engine with a small one. Back when I had my 428 in my 65 GTO, I spanked a lot of 455's with it. And 454's and 440's etc.!
Amen on the black and silver booger thing! Never get used to that. Blow black boogers for two days afterwards!
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 04-12-2008, 02:15 PM
Silver Judge's Avatar
Thumbs up
With 4:11 gears, that car is going to be an animal off the line. Can you say tire melting ?
Please put headers and a 3 inch exhaust on the car, some nice coated 1 7/8 Maddogs ought to be good for another 50 ponies on this thing
501 HP, 554 ft lbs TQ
Old 04-12-2008, 02:30 PM
gtofreek's Avatar
Yes, I'm sure it would. I designed the engine to make 550-575 HP and 500 ft. lbs. of torque. But I knew the manifolds and intake would hold it back a little but that is what the customer wanted, so that's what we did.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 04-12-2008, 03:03 PM
Don 79 TA Don 79 TA is offline
at first i didn't notice the manifolds being used, i just assumed headers
nice to see these #'s on a 400
i've thought about getting the 65cc KRE's if i keep the 400
  #38
Old 04-12-2008, 04:28 PM
70KGOLD's Avatar
70KGOLD 70KGOLD is offline
That car should haul!
  #39
Old 04-14-2008, 08:07 PM
gtofreek's Avatar
Well, you talked me into it. We are going to install a good set of headers and a 2" tapered spacer and re-pull it to see how much the manifolds and no spacer really hurt this thing. Results coming soon!
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #40
Old 04-14-2008, 10:50 PM
440GP69's Avatar
how did you install the all thread in the deck? also if you can tell me how well does the oil line mod work?
