Old 05-27-2007, 09:37 PM
stucky2947's Avatar
stucky2947 stucky2947 is offline
OK, engine and tranny are in. What kind, style, manufacturer, of headers will work on this? Also, which speedo cable will work? And how about linkage?
Old 05-30-2007, 08:41 PM
stucky2947's Avatar
Here's what I got as of today.
Name:	2007-28 May2a.jpg
Old 05-30-2007, 09:16 PM
pontiac6269's Avatar
pontiac6269 pontiac6269 is offline
Looking good. Maddog Headers are the only ones made for these cars.
Eric
Eric
1969 GTO - 461, turbo 400, Continental 13", 3.08 gears. - 12.59 e.t. @ 108.43 mph, 1.898 60'
1978 Oldsmobile Cutlass Supreme- 461, turbo 350, PTC 3500 converter, 9" 3:50 gears. = 11.39 e.t. @ 117.55 mph, 1.599 60' on E85
Old 05-30-2007, 09:39 PM
TheMonkey's Avatar
TheMonkey TheMonkey is offline
va va voom....
looks great. thanks for sharing.
_____________________________________
www.malunacoolers.com
Old 05-31-2007, 07:36 PM
kaptinkafeen kaptinkafeen is offline
I'm always interested in these threads, as am I looking for a big pre-'64 GP to restore.
Keep up the great work , and thanks for sharing.
-Andrew
-probability is fundamental, uncertainty is inevitable
[B]Looking for a '71 casting rochester 7042270 - have a '72 dated 7042270 that can trade?
Old 05-31-2007, 08:13 PM
stucky2947's Avatar
I hope I can get some more help here. I have #62 heads and replaced the stock screw-in rocker studs with ARP studs. The problem I have is now the stock pushrods are about .125" too short. I can screw the rockers down all the way and still have slop in the pushrod. I am using Comp Cams magnum roller rockers. I did notice that the ARP studs have a hex piece that bottoms out on the head when it is installed and the stock ones don't. The hex piece is about .125" thick. Does this mean that all I have to do is get pushrods that are .125" longer than stock? I hope it's that easy.
Old 05-31-2007, 09:16 PM
TheMonkey's Avatar
sorry, don't have the answer to the stud question, but... i was just looking at your picture of your motor nestled into your car without the fenders. it looks like your UCA bushings are the screw-in metal to metal type? for some reason i was thinking that '61 was the last year for that. are your bushings screw-in? is that stock like that on '62?
Old 05-31-2007, 09:21 PM
Stuart's Avatar
Stuart Stuart is offline
Scott -
61-62 suspensions are the same, then 63-64, then 65-70.
Old 05-31-2007, 09:37 PM
stucky2947's Avatar
Thanks for the answer in detail Stuart. I do have another question though. What distributor should I run? Not too concerned about originality.
Old 05-31-2007, 10:51 PM
Stuart's Avatar
I think most any Pontiac distributor will drop in, but the advance curve may have to be adjusted to suit your engine combo. An HEI distributor would probably be a good choice for street use, if you have space (they won't fit on tripower engines.) I'd post the question in the street section for more responses, along with the thing about the pushrods as I don't have any experience with the aftermarket rocker studs/arms.
Old 05-31-2007, 11:09 PM
PITTSBURGH 64 PITTSBURGH 64 is offline
Stucky, I use the stock points but a lot of guys like the HEI. I would go either way.
I don't know if the HEI will fit your car. The stock distributor and coil is an excellent ignition system.
This is some interesting Pontiac info
http://www.classicfirebird.com/hand/hand.html
Old 06-02-2007, 05:38 PM
HEI will fit, have one in my 62 GP.
Eric
Old 06-02-2007, 05:51 PM
i'd run a points type for the better advance curve. if you want the electronics then convert it with a m-h kit.
mike
former." --Albert Einstein
- Winston Churchill
Old 06-02-2007, 07:51 PM
stucky2947's Avatar
I don't have a distributor yet. Which do you recommend? What is a m-h kit?I don't think an HEI will fit with tripower.
Old 06-02-2007, 11:36 PM
Ames was selling NOS aluminum 1971 units.
Old 06-03-2007, 12:04 AM
m-h is a company that sells electrical components for vintage cars. they have a kit out to convert the points type distributor to an electronic pickup style. i think p/y sells them.
mike
- Winston Churchill
Old 06-18-2007, 03:16 PM
TheMonkey's Avatar
Eric
Indian Adventures has some too, although I don't know much about either. I need to figure out exhaust on mine soon.
  #38
Old 06-18-2007, 07:49 PM
stucky2947's Avatar
Thumbs up
After talking to my buddy,(who restores Pontiacs) He would not go with headers. The reason: He put a set of headers on a '62 Cat and went through three starters in less than a year. He said the headers sit right on the starter. So he ended up modifying the headers to give the starter some extra room. Said he would never do it again. Ram Air Restorations has the long branch exhaust manifolds for $419, and, according to him, they flow as good if not better than headers. I don't want to pay for custom headers, and the long branch manifolds fit like a glove. The only thing you have to do is get an oil filter extension (about 3"). You can get a complete system, from the manifolds to the tailpipes for about a grand. It comes with all the gaskets, hardware, mufflers, and I think the manifolds are ceramic coated inside and out. Not a bad deal.
  #39
Old 06-18-2007, 08:06 PM
I used the Long Branch manifolds with the Pipes 2-1/2" GTO system. Once I modified the cross-member and my hydros dip stick tube it fit just fine.
I used the long Walker Hemi Turbo mufflers and they sound fantastic. Not too loud but a heavy mello tone.
  #40
Old 06-18-2007, 08:34 PM
stucky2947's Avatar
What size plate did you weld on your crossmember? Any issues with it? Thanks.
