Tunas73TA, what's the build date on your car?
06D?
07A
So that means the first week of July... Correct? Forgive my ignorance but: Hows that jive with 622731 # stamped on the frame?
chuck... 1973 455 TA (07A) |
June (6) 22, 1973, 1st shift. My '74s don't have the letter stamp also. There may have been more than 1 frame builder in the early stages.
I've used to think maybe the (1) and (2) might signify the division code, 1 for Chevrolet (camaro) and 2 for Pontiac (firebird). But, I have seen birds with a 1 enough times to believe I am wrong. I then thought they might be the shift (as Ransom suggests). Maybe so, or maybe they are codes for different suppliers. I know the N is not for Norwood, I have seen a bunch of Van Nuys cars with N subframes.
The S was probably for the A.O. Smith Co. Maybe Kurt S. or another Camaro guy knows another subframe supplier.
I'll add my numbers to this.
My Norwood 09A car has a frame stamp of 82670S2. August 26, 70. Just what you might expect for the date.
My Van Nuys 12B car has a frame stamp of 11671N2. January 16, 71. Seems odd, but my build sheet for this car shows an initial date in the upper left corner of 12-14 that was crossed out and a handwritten date of 1-25 right above it. And my PHS shows a shipped date of 01-29-71. For what ever reason this car seems to have been held up after it got its trim tag but before it went to final assembly.
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant http://www.ford-trucks.com/forums/12...al-ranger.html 1966 Ford F250 4x4 Red/White 4-speed - San Jose plant 1966 Ford F250 4x4 White 4-speed - San Jose plant http://www.ford-trucks.com/forums/11...-f250-4x4.html 1971 Trans Am White/Blue 4-speed limited options - Norwood plant http://forums.maxperformanceinc.com/...d.php?t=757496 |
I'm with HFR on his description. I wonder if the S2 (or 1) is Shift 2 (or 1)
72 TA 4spd
03D build with 32072S1 |
Different vehicle but still GM. This could be the answer to the S1, S2, N, question.
MY 1964 Corvette with a Powerglide has the date stamped on the bottom of the oil pan. It is T1029N. Which I have learned through NCRS information sources to mean "T" Toledo 10 (Oct) 29th "N" Night shift. For this discussion S1, S2, & N Shift 1, Shift 2, & Night Shift. I have seen N used on other parts as a shift indicator.
When removing an unreplaceable washer, the part will be heard hitting the floor and then vanish from the face of the earth! |
So, they had S1, S2, N1 and N2 and that indicated 1st shift, 2nd shift, and nights and ????.
I think Mike is correct probably on the 'S' being the frame manufacturer, Smith in this case.
The number after the 'S' would be the shift.
oh - cool!
How did I never see this thread! I'll now have to crawl under my car to see what it shows... My car was monkeyed with, so hopefully it has the correct subframe!
I believe the S is for A.O. Smith frame works and 2 would be second shift.
Cannot remember who the N was for. I think Northern steel. Saw it in my GM parts interchange manual under frames and suspension section.
White/Blue 71 455 HO T/A Auto Blue/Blue 71 455 HO T/A 4 Sp White/Sandalwood 71 455 HO T/A 4 Sp White/Black 70 RAIII T/A M21/373 (stripper) Carousel Red/Black 69 GTO Judge 4 Sp 2002 Firehawk Red/Black 6Sp |
ok, I finally found my number;
Opinions on this one please! From another recent thread, it appears to be a 1970 subframe... If my interpretation of prior posts in this thread is correct, this looks to read as: May 28, 1970; Northern Steel; shift 2(?) May car's build date is 06A.
1970 Formula 400 Carousel Red paint on Black standard interior A no-engine, no-transmission, no-wheel option car. Quite likely one of few '70 Muncie three speed Formula 400's left. 1991 Grand Am: 14.4 @ 93.7mph (DA corrected) (retired DD, stock appearing) 2009 Cobalt SS: 13.9 @ 103mph (current DD; makes something north of 300hp & 350ft/lbs) Last edited by unruhjonny; 07-21-2018 at 07:59 PM. |
Yes, May 28, 1970. And that would work for an 06A car.
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
ok, my brother found this number on the passenger side rail on his '77 TA subframe;
He's interested in deciphering if it's original to the car, and worth keeping it vs swapping in one from a '78 donor Firebird: 20521N7 It appears as though little is known about these stamped frame date codes - which is probably why I had never heard of it... the closest I came to any sustancial information was a nastyz28 thread where the owner of an '80 posted a picture with a similar number sequencing... his ended in "0" which leads me to believe that the last digit of the year moved to the end when the date/source/shift information changed. help!
A pick of my 70 4 speed esprit frame
If your not at the table you're on the menu A man who falls for everything stands for nothing. Last edited by Formulas; 12-17-2023 at 10:11 AM. |
#38
Thanks |
#39
I'll say...
2 - shift, 2nd shift 05 - month, May 21 - day, 21st N - frame manufacturer 7 - year, 1977
So long, farewell. |
#40
Very close on those date numbers. Stub-frame date of March 4th and scheduled build date on the Trim Tag of March 12th.
Almost sounds like modern assembly line "supply on time" builds. |
