Old 05-16-2006, 07:26 PM
*67firebird*'s Avatar
*67firebird* *67firebird* is offline
Send a message via AIM to *67firebird*
well after about of month of contemplating i went with the AFCO aluminum radiator. 30x18.5x3.0 hopefully it does the job for my firebird its on back order tilll 6/12 so ill post some pics, ill prob take out my engine in the mean time and paint the engine bay, and install the intake at the same time. Osvaldo
463 Stroker Kit.
ross pistons. h beam rods. eagle crank.
62 heads 72cc, port matched
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 06-18-2006, 06:05 PM
well just to bring old flames alive again and because i cant wait, my new alum afco radiaitor is coming in tomm. post some pics a soon as it gets in then i will instlall it.
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 06-19-2006, 03:37 PM
well i got the radiator today, tell me what you think, oh and anyone suggest how i put the fan on, im trying to avoid inserting any pins through the core, should i fabricate my own aluminum and have it bolt on?
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 06-20-2006, 01:45 PM
getting ready to bolt on, im thinking about bolting it on to the core where the 2 holes are at the top of the radiator, does anyone think its a bad place to bolt it on? or will it do?
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 06-20-2006, 04:51 PM
well i got it on took a couple hours because i didnt know what i was doing but its on now. well now i have to wait to get a temp gauge to see how it goes with cooling, maybe in a week
what do ya think? not bad for a novice?
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 06-24-2006, 07:52 PM
OK, it started to leak from the port where the intake connects the the timing chain cover, what o i do? here is what i did not do, no sealant is that where i messed up?
i tried putting a sealant on the outside, but obviously it did not work.
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 06-24-2006, 08:45 PM
Blue '66's Avatar
Blue '66 Blue '66 is offline
You are using the thick O ring between the intake and WP inlet right?Use some sealant on each side where the O ring touches the metal.Loosen up the intake manifold bolts and tighten up the long bolt the goes into the intake,it will pull up tight.Leave it to set up for a couple of hours before trying it out.
Old 06-24-2006, 08:49 PM
i had to use the o ring it came with because the gaskets i bought did not come with the right one, and so i used it its not bad but maybe i just need more sealant. Thanks BLue
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
