Since it was mentioned here I thought I would post some pics of a 980 head that was done back in the 60s with the divider wall cut out. A friend sent me the pics.
Now with the correct headgasket and a bit of sealer around the head stud washers oil use should be a non-issue and as far as strength you still have the entire other 2 sides of the blt hole that is solid aluminum all the way top to bottom so I don't see clamping force as being any kind of an issue. I think I am bgoing to run my roller engine with my old 324 cfm E's and then do a midyear change to these and do a little test to see the difference. If it slows up, smokes, and runs bad then I was told but if it doesn't... Funny thing is I bought these as they were fairly inexpensive and I was making a dished piston budget flat solid engine for my Black 69 GTO since I pulled the built motor and put it in my Green 69 GTO. May have my old "Built" E-heads on the flat solid engine and these "Experimental" heads on the Roller motor by mid-summer
1969 GTO, 3370 lbs, 10.5” tire... 07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads |
selfracing.com/portintruder Self racing supplies these to Brodix. Other source may indeed offer them,as I'm not sure of all the sources for them,but I will say I dont recall moroso offering these,but that does'nt mean they dont,I've just never made a mental note to that affect about seening them listed in their catalogs or such. Pics below are from the hyperlinked website (self racing),they show how these work,the site explains them better. HTH. |
I'm wondering if those 980 heads were done like that to work with a blower? Pontiac blower intakes from that era had siamesed ports.
any info on how they ran and what application? flow and velocity numbers?
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
I have no info on them except I believe they came off of a blower motor from the 60s.
__________________ So did those Turbo 301 Heads
www.pro-touringf-body.com |
http://www.butlerperformance.com/pro.../jbp_head.html Has anyone run these with E-heads? Just wondering how well they seal up and what the longevity is? I have only been running the Fel-pro 1016's in the past.
Wouldn't that slow the velocity in an N/A application?
If you don't have enough port volume in the head available for the displacement you are running, I could see this viable. Or in a boosted combo. But would this mod have advantages over a properly sized and shaped runner for the intended displacement?
68 Firebird Are you running with the wind or breaking it? |
the bottom line is that it is not some trick mod it's just a byproduct of porting a head as far as it can go no different than breaking through the rocker stud hole or the valve cover bolt hole it's just that some of these things are new to Pontiac guys
If someone told me it MUST have a sleeve, my next question is: "Why?" Since we have dozens of these engines floating around out there with zero negative issues reported (after the "great mosquito KILL of Orange, Virginia, 2005"), I have to ask, "Why not?"
Jim |
Brodex sells Port Intruders to allow the active intake port walls to be moved. If interested there are diagrams showing their use in the catalog. Many years ago when the Edelbrock head first came out on the market Jerry Goodale did a prototype and made custom intruders and short head bolts to completly eliminate the head bolt bulge. Not related, but the port sizes ended up very inconstant and flow varied all over the map and I sold them.
(Port Intruders were invented by Kevin Self at Self Racing Heads in OK, 580-924-5866. Note, might be a old number) |
a sleeve is not a MUST but a SHOULD, I also have seen many without sleeves but it serves to spread bolt load and avoid pulse interference from the adjacent port, granted this becomes les of an issue at high RPM were time between valve events are very short
On another board a fellow who didn't think it would work called Tony at BES and asked about this and said it would not negatively effect the flow whatsoever nor cause any kind of clamping problem.
The pic is the port with a pen light shining through. The dark line is the opening on the left port and is slightly over 1/2" wide.
#38
this thread is great i will really be glad when you run those heads.
#39
A LOT of the 4 valve 4 cylinder engines have the siamese port configuration, course they are opening up both intake valves at the same time too. I would think on a NA engine there would be starving of one port. With a blower there would be a LARGE "plenum" area just a couple of inches away from the valve and the valve would like that deal a lot if the car had a trans brake and a roots blower.
Tom V.
