Old 08-18-2022, 02:04 PM
400 4spd.'s Avatar
Originally Posted by 428ho4spd View Post
One of 914 (see attached) with the WV code HO w/A.I.R. engine. Does it have the smog equipment in place? Any engine photos to share?
I have a WW code (non-HO) survivor with all of its original CA A.I.R. stuff in place and functioning. Let me know if I can help you in any way.
Grant
Beautiful car! I know where another one of the 914 sits, and it's a convertible survivor.
The Following User Says Thank You to 400 4spd. For This Useful Post:
Old 08-18-2022, 03:47 PM
GTOh!'s Avatar
GTOh! GTOh! is offline
[QUOTE=428ho4spd;6365418]Yes, that cover was likely added at some point. The smaller billing history card would tell us for sure if you can post that. They don't always highlight all of the options on those order forms.
Thanks again! I'll get a couple pics of the console tomorrow. Is the attached pic the "smaller billing history card" you mention?
BTW, I do have the steel wheels on RWW tires and the full wheel cover s in addition tot he added Rally I wheels (including spare).
Name:	Screen Shot 2022-08-18 at 3.46.01 PM.jpg
The Following 2 Users Say Thank You to GTOh! For This Useful Post:
Old 08-18-2022, 04:02 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default 👍
After looking at your photos of the antenna base more closely, it appears that it may be the original. Perhaps the original mast was stuck (common problem) while trying to remove it at some point and the outer insulated portion pulled loose from inside the base.
I agree with this ^^^^ , as it seems the entire gut came out?
Old 08-18-2022, 04:13 PM
60sstuff's Avatar
Looks like a typo?
Your engine unit number says WW on the CBH, which doesn’t match the WV.
Your ‘67 is a WV.
The Following User Says Thank You to 60sstuff For This Useful Post:
Old 08-18-2022, 04:20 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Originally Posted by GTOh! View Post
[I] Is the attached pic the "smaller billing history card" you mention?
Yes, that's it! If the spare tire cover was factory installed you would see a "2" in box 37 of the card. Interesting that they made a typo on the card with the engine unit number. It should read WV5915, but it's correct in boxes 75 & 76 which is what really matters. FYI... Fremont was the only plant to print the engine code and first four digits of the EUN in that box. Other plants printed all six digits of the EUN.
Great that you have the original wheels & covers!
60sstuff's Avatar
GTOh!,
Hate to be a pest. You have a unique GTO, so at your convenience would you furnish a nice clear photo of the block stamp showing the two letter code and numbers.
Off course this is providing that you can see it (possible smog bracket interference).
Old 08-18-2022, 04:33 PM
428ho4spd's Avatar
And here is where your car was sold new from...
23 240 - Meridian Motors, 3300 Burnett Ave, Concord, CA 94520
The Following User Says Thank You to 428ho4spd For This Useful Post:
Old 08-19-2022, 05:49 PM
GTOh!'s Avatar
Originally Posted by 60sstuff View Post
GTOh!,
Hi all. Today, I was able to get a pic of the engine stamping by using a mirror to get around the AIR pump bracket. Because I used a mirror to capture the stampings, I reversed the attached image so that the numbers and letters read true. See attached. As suggested earlier in this thread, the engine stamping is indeed 5915 WV. What does the "48" on the end of the 5915 tell us?
What makes this car "unique" as you say in your post? I'm already fascinated with this car. For example, I am a long time Corvette enthusiast and have judged and inspected many, many C2's and early C3's. Chevrolet masked the engine stamp pad to allow VIN and engine derivative info to be stamped on a clean pad. Did Pontiac paint the area that's stamped or was this done in a re-paint of the engine on this example?
Old 08-19-2022, 07:04 PM
60sstuff's Avatar
Nice job with the mirror. I’ve used that technique many times.
The last two engine numbers were left off on the CBH card.
You will see the full number stamped on the block as you did, plus it shows on the full number on the POP.
I have posted my CBH card and my POP from the ‘67 WV I used to own.
Pontiac painted the engine color over the engine stamp when new.
The last photo is my WV when I had the engine out.
You’ll notice what’s left of the Original white paper label which had a red WV stamped on it at one time.
ID:	596805   Click image for larger version
ID:	596806   Click image for larger version
Old 08-19-2022, 07:10 PM
428ho4spd's Avatar
Your engine stamp looks good. The last two digits are just part of the entire Engine Unit Number, it looks like 46 to me. I straightened your photo and cleaned it up a bit to read it easier. If you have your Protect-O-Plate, that entire EUN will be stamped on it. I'll attach a photos of mine for reference.
Pontiac did paint over that area when painting the engines.
ID:	596808   Click image for larger version
ID:	596809   Click image for larger version
ID:	596810   Click image for larger version
Old 08-20-2022, 02:35 PM
geeteeohguy's Avatar
To the OP regarding his Hurst Equipped emblem: this emblem came with Hurst Wheels back in the day and many people installed it to their decklid after bolting on the new set of Hurst wheels. It really has nothing to do with the shifter, from what information I've run across. Your car is a knockout!
Jeff
Old 08-21-2022, 12:35 PM
GTOh!'s Avatar
Can you post some photos of the console and the plunger/switch?
That's probably a reproduction base, I've seen this issue before with others. I would try getting a new base or maybe using some epoxy around the black plastic portion and reinstall it.
I took another look at the console light this morning. I think I had tricked myself into thinking the "looped off" socket was for the console light. Nope! Had I been more attentive, I'd have noticed the wire from the switch does not link to the socket. I then looked at the AMES catalog and saw that the plunger switch is also the socket for the console light. I added a bulb to the bottom (socket) of the assembly and now have light to the inside of the console. I'm guessing that the "looped" wire and socket is part of a universal harness and used when an automatic transmission is opted. I suppose this socket illuminates the PRNDL slide. Maybe?
Thanks for the tip!!!
Old 08-21-2022, 04:04 PM
428ho4spd's Avatar
Great! Exactly right, that extra bulb socket would be for an auto shift car for the PRNDL illumination. Glad you got that figured out.
