You need to calculate the pin height and make sure that the rings will be in a reasonable location with the rod length you will be using. You don't want to pick a rod/stroke combo and then order pistons and find that the oil rings are encroaching on the pin bore. I agree that they may be the last thing to order but you want to have a rough idea that your plan will work before committing.
Michael 1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished! 1979 Trans Am - low-buck drag car project for when I retire |
For when things get real tight ....
This situation was fixed in the next job card .... smaller ring pack ![]() |
Good point about the rings. The pistons I am looking at for this combo are these from Race Tec.
463 4.185 0.033 4.210 6.625 1.470 12.2 11.2 10.5 -3.8 537 1000582 with a 6.660 rod, it would move the pin up .035, but would gain some of that back when trying to get to .000 deck with the pistons. I'll check with the manufacture to see how far away the pin is from the oil ring lands.
Brad Hansen 65 Cat Ventura, 66 Cat Vert, 63 GP |
Don't you mean a 6.625 c-to-c rod? Those .005 matter...
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
Rod angle comments were my understanding as well, when it refers to longer stroke and rods.
Maybe I am missing it. I am looking at a set of 6.660 rods
http://www.ebay.com/itm/H-Beam-6-660...dWltre&vxp=mtr
That's a really odd length for a BBC rod but it should be perfect for your combo. The extra .035" should theoretically give you Zero deck with the 1.470" pistons. Speed-pro pistons for 455's come in 1.497" and 1.500" and have .008" and .005" deck clearance respectively. Even at 1.470", the pin will not be into the oil rings at all.
Previous comments based on factory 4.210" stroke, of course.
Re-reading through this thread, I just noticed one possible issue. The rods are setup for .990" pins and I'm assuming the pistons are setup for .980" pins. If so, you would have the added expense of re-bushing your new rods.
I need to check with Race Tech, but believe that their stroker 1000583 piston may have a .990 pin. I am waiting to confirm that. They will make the change to a .990 pin, but if I want them to do that and CH change, it would be considered a custom piston at that time. So one change is ok with Race Tech from what I understand from their off the shelf pistons, but two changes makes it a custom and cost a bit more than the off the shelf??
Maybe someone here that sells them can inform. Also, I will be looking for a vendor for them.
"...eBay connecting rods are almost certainly generic Communist Chinese junk..."
Glanced back thru the thread and didn't see that anybody has actually used any of the Speedmaster brand rods. Since they are a bit less than half the price of RPM H-beams, it would be good to know if they are decent usable rods, or total junk ??? ![]() Hey, they're nearly a hundred bucks cheaper than the RPM 5140 rods. So, it appears that either these are total junk, or RPM is making a big profit margin on their rods. So has anybody used 'em--or even checked a set ? While on the subject, the Eagle rods are higher than the RPM rods, but lots of Pontiac engine builders say that the RPM rods are good. So, for those who don't consider all Chinese parts junk, are the Eagle rods actually any better than the RPM rods ? |
![]() Quote:
![]() Quote:
"Kinda thought they may be from Procomp. They came in a plain brown box with 'Speed Master' labeling."
"Let me start from the time I opened the box. As far as any engine builder goes the first thing to look for is the spec card so you know the rod weights for balancing and bolt specs for getting the correct torque / stretch on the bolts. Don't bother looking for this critical piece of information because its not in there." "Think ProComp for Speed Master. Actually these look like the standard Chinese, Chevy performance connecting rod sold by everybody like SCAT, Eagle and a host of others including some big American names that quietly stock them as their low cost performance rod." "Chinese machining can be a bit sloppy which is why SCAT and others only buy the forging and finish machine them in the U.S.A" Two of many entertaining threads about "Speed Master" rods..... http://www.starquestclub.com/forum/i...owtopic=106597 http://www.hotrodders.com/forum/spee...ds-257649.html .
Might as well buy some of those $149 roller lifters to go with 'em.
If only machine work wasn't so expensive. I'd be tempted to rustle up a 557 block and throw all the cheapest ebay parts I could find in it just to see what would happen.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
![]() Quote:
That would be an interesting build. Get a knockoff Nothwind intake to top it off. |
And aluminium clyinder heads assembled by KRE without hardened steel spring seat cups or shims under the valve springs.
#38
I have one of those. Came in a "Pro Comp" box. Looks fine, but haven't tried to bolt it up to anything yet. As long as the flanges aren't horrible it should work fine.
#39
not sure if anyone cares or not, but I am going to keep looking at these rods. May buy some if they work and have my machine shop check them out.
email I got back from the seller; 744 grams. Speedmaster79 Best regards, Jeff S. Customer Service Team
#40
I care, man. LOL. This thread is starting to go off course as so many seem to do. How does that weight compare to other BBC/Pontiac rods?
